Quote: Originally Posted by
LilSparkPlug
On your radiator support, right next to the hood "bump stop" (plastic piece nearest the fender) there is a hole. Look down into the hole and you'll see a long screw with a torx head on it. Turning this with a torx screwdriver (not sure which way is which) will bring the headlight up or down for adjustments. Its the same on both sides.
This.
It's really easy to do. Just get a torx screwdriver, stick it down the hole, and start turning. Turning it right makes the light lower, turning it left makes it higher.
