Hello,
It appears that my cti hardpipe is leaking around the flange, any ideas on what to do about this? it might need to be rewelded...im not 100% sure tho - i am going to replace the o-ring inside the hks to see if that helps any but i do feel a good amount of air leaking out of the flange area...
Best 1/4: 13.0 @ 112.9
Best Trap: 115.9
352 whp / 354 tq -> AFR's around 10:1
AGP 50 trim + goodies
The flange is in two pieces the aluminum part is threaded make sure it is tight if louse remove and put some formagasket on the threads and put back on let me know thanks
Quote: Originally Posted by chzoom
Hello,
oh ok, i thought the flange was welded on and i could not unscrew it? ... ill try that and also the oring on my bov is stretched and i think thats adding to it. all of a sudden i cant boost past 10psi - ill check the flange today and let you know whats up willy. thanks!
bump on this , willy i finally had a chance to pull the pipe off and check it, the flange was screwed on crooked. Took the flange off and screwed it back on as tight as possible but it looks like the flange still sits too high off the threads...there is a gap between the threads/flange. Looks possibly like it wasnt threaded far enuff down. Put some sealant around it but it would require a good amount of it..any suggestions?
and i actually pulled the pipe off a month ago..but im tryin to find out why my car is slow sigh..and i feel a crapload of air comming from the flange ;/
if i sent u the pipe i wouldnt be able to drive! i work like 6 days a week...i could always make a drive up and you could take a peak at it? i dont expect you to fix it free or w/e i just need to clear up all my boost leaks and i think this one is killing
If you can drive up we will fix it let me know when.
hey willy did you wanna setup a time for fri or sat? my cell is dead and i lost my charger...so i cant really call you right now!
i have a dr's appt at 10:15 in newport on friday..should be out by 11 but i think its like a 2-3 hour drive to your place from my house..i need an address so i can punch it into the navi..LMK...worse case we can set it for next friday...
bump, did you wanna take a gander this friday willy? like i said its minor..a few welds around it might resolve it, unfortunatly im not good with that sorta stuff so i dont really know..
