Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Custom Tubes, Inc.
Old 05-25-2006, 12:45 AM   #1 (permalink)
SRT4R's Avatar
Member Number: 35481
3" OČ housing... Aluminized steel or Stainless steel?
Hi Willy,
I have a big question for you! The 3" OČ housing for stock turbo... Aluminized steel or Stainless steel choice? What's the best and why? Some exhaust master like the flex of Stainless one, other one talk about the toughness of the aluminized one... What's your point about those two choice's?
I want a CTI for sure but wich one...? Help me!
SRT4R is offline   Reply With Quote
Old 05-25-2006, 11:44 AM   #2 (permalink)
Member Number: 6692
Trader Rating: (52)
The stainless steel can take more heat before it starts to break down depending on what number stainless around 1700 degrees if you had that temp at your o2 the last thing on your mind will be the o2. The turbo and your valves and pistons would be gone and the stainless is a harder material which expands and contracts more than plain steel when heated and cooled and more expensive. The aluminized will break down at a lower temp 1500 again there would be damage to other parts first. The aluminized is made to slow down the rusting of the metal and less expensive and does not expand as much as stainless. The o2 is up out of the water and salt from the roads and gets hot really fast after start up which slows down rusting. It is personal preforence. The stainless will last longer
Quote: Originally Posted by SRT4R
Hi Willy,
Custom Tubes Inc is offline   Reply With Quote
Old 05-25-2006, 06:09 PM   #3 (permalink)
SRT4R's Avatar
Thumbs up
Hi Willy,
Wow... Thank you very much for the answer! Your a MASTER Willy and a very good teacher also... ;o)
Now, I can take an easy move... CTI Stainless Steel 3" OČ Housing!
Old 07-22-2006, 02:42 PM   #4 (permalink)
selp's Avatar
Member Number: 7528
Trader Rating: (13)
something else willy.. do you offer something like the "Y bracket mounting" thing that goes in the stock o2 housing? .. you know what am i talking about?
selp is offline   Reply With Quote
Old 07-24-2006, 07:50 AM   #5 (permalink)
Member Number: 6692
Trader Rating: (52)
There is a place for you to bolt the y bracket to.
Old 01-18-2009, 01:16 AM   #6 (permalink)
uturner's Avatar
Member Number: 13844
Is it possible to get an O2 housing with an extra bung for a wideband?
uturner is offline   Reply With Quote
Old 01-18-2009, 08:12 PM   #7 (permalink)
Member Number: 31038
Trader Rating: (50)
That goes on the downpipe I believe.
raul-01 is offline   Reply With Quote
Old 01-19-2009, 12:57 PM   #8 (permalink)
Member Number: 6692
Trader Rating: (52)
Yes you can it can go either on the o2 housing or the down pipe before the cat if there is one.
Page generated in 0.16438 seconds with 13 queries
