Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Off-Topic Area > Off-Topic
Old 07-01-2008, 04:53 PM   #1 (permalink)
Block Head's Avatar
Member Number: 47920
Default Where would one post a build thread here?
Well? I've been busy the last 2 weeks and thought it'd be neat to show what I've been up too.
Quote: Originally Posted by SpeedEuphoria View Post
Lesson learned from this thread: Don't believe everything you see/hear/read. Investigate/research the topic at hand so next time you can make the judgment for yourself and not be as gullible. This is a benefit because then you can be informed and vendors cannot pull one over on you.
Block Head is offline   Reply With Quote
Old 07-01-2008, 04:59 PM   #2 (permalink)
sphipps's Avatar
Member Number: 19187
less blabbing and more posting pics.
if a Moderator doesn't think it belongs here then he/she can move it.
ANTI-SWEETS CLUB MEMBER # 1
sphipps is offline   Reply With Quote
Old 07-01-2008, 05:02 PM   #3 (permalink)
Elected Moderator
05Flame red's Avatar
Member Number: 37340
Post that shit up.
05Flame red is offline   Reply With Quote
Old 07-01-2008, 05:18 PM   #4 (permalink)
Block Head's Avatar
These are a couple days old.
Oh Hi. I'm Napoleon. For some reason I can't close my hood.
Oh this is why.
Still a ways to go
Seems to keep the angles acceptable for the trailing arm
SRT fuel tank and pump.
Just threw the neon tires on tonight. I think I may need to cut the control arms and thread a turnbuckle for it to get the right camber. It may settle once the car moves. I also have to bend the filler neck a bit.
My fancy subframe mounts that took 3 days.ops: Keep in mind those cross bolts have no load, the just squeeze the mounts to keep from shifting.
Everybody said that mounting a SRT subframe couldn't be done without cutting it up. Well there it is, done. That is the SRT frame rail that is blocked and bolted there.
The motor is high and ahead too. I'm just waiting on a bolt I lost to come in to mount it right.
Since then I've mounted SRT pedals, 1 gen dash bars, and figured out the motor was 1 inch to the drivers. I have a 1/2" chunk of aluminum to slide it over. If I had only ground down the mount on the inside, not evenly.
Today was wiring, did I mention?
I hate wiring.
Stopped early because of rain today though, so wiring is not done.
Car is a s3 car made 350/370 on pump at wheels. It'd cost me more to beef up 1st gen stuff.
Any questions I will answer.
Old 07-01-2008, 05:24 PM   #5 (permalink)
sphipps's Avatar
nice start....can't wait to see the finished product.
Old 07-01-2008, 05:31 PM   #6 (permalink)
Block Head's Avatar
Should be soon. I got 2-3 days work and 1 day finishing wires. I'm off work right now so I got time
Old 07-01-2008, 05:35 PM   #7 (permalink)
lifeisdeath's Avatar
Member Number: 61
how much $$$ so far?
Dodge SRT-4, the fastest car evar!
64,999,987 firearms owners killed no one yesterday.
"The People" in the First Amendment means The People; "the People" in the Fourth Amendment means The People; but "the People" in the Second Amendment (ratified in 1791) means the National Guard (created by an Act of Congress in 1903)?
lifeisdeath is offline   Reply With Quote
Old 07-01-2008, 06:06 PM   #8 (permalink)
Block Head's Avatar
SRT was mine. Bought back from insurance for 3k. Most of it is a few tools I needed, 500 bucks I'd say. Needed a 16mm x 2 tap, had to buy 90 dollar set. (or 30 bucks for 1 tap) 17/32 drill bit. New drill bit set, 80 bucks. Borrowed friends grinder, but I broke it, 75 bucks. 50 bucks in grinding wheels. Welding done by a guy I work for that's licenced, free. (About 1 hour TOTAL). Neon was 5 bills. Sold that many parts over winter. Repaired wheel, 150. Repainted a couple others, 50. 5 pass 26" M&H slicks, 200. Need steelies 50. 1 bent rear control arm. Had to cut off both and replace about 150 bucks. 2 rear struts, 50 bucks. (mine were bent.) Various bolts, 50 bucks. Most I didn't end up using. I changed subframe ideas 7 times. Mag Protractor$, dropped car and fucked some jackstands day one$. 60 bucks in steel, most I didn't use. (better to have extra.)
I think I spent more on gas and food. It's 1:15 round trip to car.
The 2 door rear discs are the same as ours. Saved money there and swapped over my brakes. My hubs and bearings were done!
Old 07-01-2008, 06:12 PM   #9 (permalink)
FUELED70's Avatar
Member Number: 44621
good christ man, that's a hell of a project. definately keep that shit posted
FUELED70 is offline   Reply With Quote
Old 07-01-2008, 06:28 PM   #10 (permalink)
Bthomp21's Avatar
Member Number: 54990
Nice project you got there
I don't aim high in my life.
Bthomp21 is offline   Reply With Quote
Old 07-01-2008, 07:24 PM   #11 (permalink)
wannasupra's Avatar
Member Number: 32741
cool man, should be pretty quick.
"Scoff not at my vile remarks horny fiend"
Quote: Originally Posted by Sweets View Post
^^ Im with supra..
wannasupra is online now   Reply With Quote
Old 07-01-2008, 08:23 PM   #12 (permalink)
RTShadow's Avatar
Member Number: 11888
Dammit all, I thought you were building a HUGE INFLATABLE SHEEP!!!!
Quote: Originally Posted by Bella Lugrossi View Post
good thing this isn't a race to see who's smarter.
RTShadow is offline   Reply With Quote
Old 07-01-2008, 08:33 PM   #13 (permalink)
Block Head's Avatar
You've been out in the Desert too long.
Page generated in 0.29124 seconds with 11 queries
