Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > Florida Forums
Old 02-01-2005, 10:42 PM   #1 (permalink)
Member Number: 5814
Default s2 wga problem
i installed a s2 wga on sunday and gave it a few days to see what kind of boost i would make after the s0 ecu corrected itself a little bit. its boosting way to high still so i need to adjust it down but when i went to take a look at it earlier to see if it was cool enough to adjust i noticed the arm isn't coming out of the can straight, its kind of angled down almost touching the can. i had a hard time getting it on the flapper arm but didn't notice arm not coming out straight because it was already adjusted for 4mm. i had to turn the arm to get it to align right, i guess it got turned when it was packaged to ship. is the wga damaged or is this a sometimes normal thing?
maalanar is offline   Reply With Quote
Old 02-02-2005, 12:31 PM   #2 (permalink)
Member Number: 5814
i got the arm to come out of the can straight, i guess the arm turned some when i put it on there and caused it to not sit straight. loosened it 2 turns so hopefully its not hitting 20psi in 4th anymore with it being 40 degrees outside
Page generated in 0.14361 seconds with 13 queries
