Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > Florida Forums
Old 09-23-2006, 11:57 AM   #1 (permalink)
nascarguy's Avatar
Member Number: 40031
Default huge problems need help asap
ok tried to sell my stage 1 computer. took it out put in my stock 1 and car would not turn over. so i put the stage 1 back in and now it wont turn over at all. it isnt even trying to . any1 any1 i need HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
'05 Flame Red
Mods;
Mopar stage 1
Turbo XS HP Boost Controller
Mopar BOV
AGP WGA
Prothane MMI Race
MPX Oil Cap Powdercoated Red (cuz my wife thinks its cute! )
nascarguy is offline   Reply With Quote
Old 09-23-2006, 12:07 PM   #2 (permalink)
Jagok1's Avatar
Member Number: 14366
Did everything "snap" into place? Did you put the battery back on? Did you disconnect the battery before changing out PCM's?
AGP GT40 -> 317@16psi -> 370@21psi -> Race #'s soon Tuned by NemoFoss
Jagok1 is offline   Reply With Quote
Old 09-23-2006, 01:23 PM   #3 (permalink)
nascarguy's Avatar
yes , yes and, yes !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!! sorry guys im so dejected right now
Old 09-23-2006, 01:33 PM   #4 (permalink)
Member Number: 23318
I would guess you mixed up the connectors.
john05srt4 is offline   Reply With Quote
Old 09-23-2006, 01:33 PM   #5 (permalink)
t3turbo's Avatar
Member Number: 35136
Trader Rating: (35)
Default Sounds like a fuse to me
Hey man,
Check your black fuse box by the driver's side fender-check these locations (read the chart on inside of fuse box lid to see the location of each fuse):
#4 fuse
#9 fuse
It also COULD be your #24 starter relay, but I doubt it.
Also, make sure you didn't accidentally cut the wire that goes to your starter--that would be a problem--but an easy fix.
Let me know
-Tim
AGP Garrett DBB 50 Trim
362 whp-371 torque @20 psi on 92 Octane
423 whp-434 torque @24 psi on 109 Octane
(freaks out the guys in Z06's )
t3turbo is offline   Reply With Quote
Old 09-23-2006, 01:34 PM   #6 (permalink)
t3turbo's Avatar
Trader Rating: (35)
Default Oh....
and I am assuming you connected all plugs to the PCM properly (they are color coded) and also connected your battery correctly.
Let us know what you did wrong. We really want to know, so we can laugh. JUST KIDDING, man.
Old 09-23-2006, 01:39 PM   #7 (permalink)
OTownSRT4's Avatar
Member Number: 38911
Trader Rating: (13)
Man i had the same problem when i put my stage 1 in.........pull all your connectors and look at the pins inside, some of them may have been pushed in a little and are not making contact. I had to take 1 connector apart and put all the pins back in place. then the connector wouldn't "click" in so i got an ECU strap from PTP....good luck....and again they don't have to be pushed in very far to not work.
OTownSRT4 is offline   Reply With Quote
Old 09-23-2006, 01:51 PM   #8 (permalink)
nascarguy's Avatar
everything is hooked up properly. onething that is happening is my security light is coming on and staying on not shutting off like it should. i have checked every fuse w/ a tester and all good . my battery gives no volts when trying to start it stays at 12
Old 09-23-2006, 02:00 PM   #9 (permalink)
OTownSRT4's Avatar
Trader Rating: (13)
You talking about the little red light? If so it's the same as my problem man.....give it a real close look
Old 09-23-2006, 02:03 PM   #10 (permalink)
nascarguy's Avatar
just tried what u said to do and nothing !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! im so tired of this any1 know where i can get some dynomite ?"???????
Old 09-23-2006, 02:05 PM   #11 (permalink)
nascarguy's Avatar
yea the little red light i am not good with electrical shit and now i am haveing to learn i guess man im so tired of this any1 have any other ideas ?
Old 09-23-2006, 02:08 PM   #12 (permalink)
OTownSRT4's Avatar
Trader Rating: (13)
I wish i could remember what pin it was, I ended up talking to a guy at flight systems and he told me which connector and what pins to look at and sure enough the were not flush with the rest. I'm willing to bet my next paycheck this is your problem. I wish i still had the diagram he emailed me, sorry. Good luck man, I'm off to Tampa to watch some Devil Ray beat down, tonight and tomorrow .
Old 09-23-2006, 02:27 PM   #13 (permalink)
gatekeeper's Avatar
Member Number: 13391
Security light being on could indicate that the Chasis Control Module (CCM) isn't getting power (or isn't connected to the PCM correctly).
My roomate had a similar issue which stranded him at work. In his case, the power wire running to the CCM wasn't grommeted properly, chafed against a sharp piece of sheet metal and shorted out. Fix was to splice in a new piece of (grommeted) wire and replace the fuse.
The Sentry Security key system is part of the CCM subsystem. If it isn't getting power, it failsafes to theft mode (no start, no run).
2004 E-Blue SRT-4
2006 S-Yellow Kawasaki ZX-10R
2008 U-Silver Cobalt SS/TC
gatekeeper is offline   Reply With Quote
Old 09-23-2006, 02:30 PM   #14 (permalink)
nascarguy's Avatar
where is the wire at ?
Old 09-23-2006, 09:36 PM   #15 (permalink)
nascarguy's Avatar
thanx all of u for ur help today in my time of need. it is now 14hrs later and i have a running car. i kindof dont wanna tell u alll what was wrong but in my defence . all fuses and relays were checked tiime and time again.in all about 4 times. now. the fuse in the 21 slot. it blew. dont know why or how but it was done. y it came up good when we checked itdont know but i replaced it and fire !!!!!!!!!!!!!. if u ever have my problem my advice is check the fuse in the 21 slot and more then likely yu will find ur problem
