Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > Florida Forums
Old 02-14-2006, 06:48 PM   #1 (permalink)
Big_Daddy's Avatar
Member Number: 35480
Default HP estimate
AGP WGA, HKS SSQ, EBC, PRESSURE PIPES, STG1 PCM. Where would i be? ballpark?
Big_Daddy is offline   Reply With Quote
Old 02-14-2006, 06:51 PM   #2 (permalink)
Fluke-SRT4's Avatar
Member Number: 13101
Trader Rating: (15)
No FMIC and stock exhaust? 250-260 max.
Best run: 12.878@107.87 2.082 60' (street tires, 2850lbs) 04/15/06
Fluke-SRT4 is offline   Reply With Quote
Old 02-14-2006, 07:09 PM   #3 (permalink)
Big_Daddy's Avatar
thanks that is not whp right?
Old 02-14-2006, 07:25 PM   #4 (permalink)
Fluke-SRT4's Avatar
Trader Rating: (15)
WHP will be around 245-250 max. I know, because i did dyno my car long time ago with stg1 and bc only, and i got 247hp and 270 tq, but remember, that is only a spike, does not reflect the whole power band.
Old 02-14-2006, 07:34 PM   #5 (permalink)
Big_Daddy's Avatar
kool thanks how much more if i add a fmic and exhaust?
Old 02-14-2006, 07:36 PM   #6 (permalink)
Fluke-SRT4's Avatar
Trader Rating: (15)
Around 270-280, for more you will need more fuel and tuning. Because stg1 pull timing after 17psi.
Old 02-14-2006, 07:37 PM   #7 (permalink)
Brian M's Avatar
Member Number: 13958
With my mods in my sig spiking 22 and falling to 15 psi I got 283hp and 350 ftlbs when I dyno'd last saturday. Uncorrected 3rd gear dynojet.
Brian M is offline   Reply With Quote
Old 02-14-2006, 07:44 PM   #8 (permalink)
Fluke-SRT4's Avatar
Trader Rating: (15)
If you had a mapclamp or emanage, that number would be better. Stg1 pulls lots of timing at that high psi. Trust me, get a odbII reader and you will see for your self.
Old 02-14-2006, 07:47 PM   #9 (permalink)
Brian M's Avatar
Yea, with my spike from 3000 to 4000 its dumping alot of fuel. The tech told me my best be would be afc and upgraded fuel system. The a/f was good and straight about 12.5 from 4000 to redline.
Old 02-14-2006, 07:51 PM   #10 (permalink)
Fluke-SRT4's Avatar
Trader Rating: (15)
For a mapclamp or emanage, you will need more fuel, stg2 injectors or even better and more expensive a Fuel return line. Just my .02 cents
Old 02-14-2006, 08:05 PM   #11 (permalink)
Brian M's Avatar
Saving my money for the agp setup with injectors, fuel pump and safc.
Page generated in 0.18510 seconds with 13 queries
