Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > Florida Forums
Old 08-04-2004, 12:41 PM   #1 (permalink)
Ghost22's Avatar
Member Number: 13666
Default HKS BOV Help
I need some help i have a perrin upper pipe and a apg BOP and hks BOV, So if any one can help a bit , I was planning on running the Pink line to the Hks BOV after i install the BOP . if anyone can offer some it would be great
Ghost22 is offline   Reply With Quote
Old 08-04-2004, 01:27 PM   #2 (permalink)
srtowner's Avatar
Member Number: 4573
Trader Rating: (78)
I have ED hard pipe kit with HKS SSQ and this is how I run mine. On the #3 solonoid there are 3 vac lines BLUE,PINK,and BLACK disconnect all 3 from solonoid. The small black line goes to a T one side goes to throttle body I cannot remember what the other side of this T goes to but disconnect this line also. The pink line goes to the mopar BOV remove this line.The blue line goes to the turbo, but before the turbo there are 2 T fittings with on line going to the intake and the other one going to something cannot remember just remove all of these line and throw them in a box. Now run a 6mm line from the throttle body put a 6mm x 6mm x 4mm T in line run the 4mm line to the HKS BOV and run the 6mm towards the turbo, before the turbo you will need to put another T 6mm x 6mm x 6mm. This T will connect to the brakes vaccume and to the turbo. It will be much eiser to work in this area if you remove your intake and the battery. Also remove the battery tray. I have been running this set up for 2 weeks with no CEL or any problems at all. If you need further help when I get home I can post pictures of the removed vac. lines and maybe a pic of the new line.
FOR ALL YOUR PERFORMANCE NEEDS
srtowner is offline   Reply With Quote
Old 08-04-2004, 01:54 PM   #3 (permalink)
Ghost22's Avatar
Thank for the help, may be the pics will help me better if u can post them if not dont worry Thx anyway
Page generated in 0.15614 seconds with 13 queries
