Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > Florida Forums
Old 04-06-2008, 07:30 PM   #1 (permalink)
bloodredsrt4's Avatar
Member Number: 46328
Default help needed!!!
hey guys... ok so the other day i was driving to school and my car just shut off while driving... started right back up and no probs or check engine light... so i thought nothing of it... a day later my idle rpms were normal but my safc and scan guage were showing 4-6 thottle % and i wasnt on the gas at all just sitting at a light... then while driving my a/f's would go all over the place... just cruising it would go to 10.0 and bounce to 16 and back to 14 an the car would hessitate a lil... and if im driving and a drop it into nuetral my rpm's would hang at about 2k and then once i come to a complete stop it would go back to normal idle rpm but again the safc would show 4-6 throttle %... i asked turbomatt if he had any suggestions and he said TPS wires were bad... so i put in the s&p rewire kit and a new TPS and the problem is still there.... can anyone shed some light on this at all... any sugesstions or people that have had the same prob.... this is pretty urgent as my srt is my daily driver and only car... thanks, -matt-
Flame Red SRT-4 w/148 cubic inches of pure whoop ass!
AGP S3D 44lbs./min. wheel
bloodredsrt4 is offline   Reply With Quote
Old 04-06-2008, 07:36 PM   #2 (permalink)
Jagok1's Avatar
Member Number: 14366
Have you installed any new parts on the car?
AGP GT40 -> 317@16psi -> 370@21psi -> Race #'s soon Tuned by NemoFoss
Jagok1 is offline   Reply With Quote
Old 04-06-2008, 08:51 PM   #3 (permalink)
no sir... ive had the same mods on my car for the last 35k miles.... and no check engine light at all
Old 04-07-2008, 01:31 AM   #4 (permalink)
anyone????
Old 04-07-2008, 10:35 AM   #5 (permalink)
okie dokie then
Old 04-07-2008, 09:03 PM   #6 (permalink)
necal9's Avatar
Member Number: 46270
okie dokie then
I used to have the same problem. Mine went away with time. Don't know what the problem was!
necal9 is offline   Reply With Quote
Old 04-08-2008, 06:06 AM   #7 (permalink)
KrazyRdR83's Avatar
Member Number: 55270
Trader Rating: (36)
have you tried the other threads? how bout askin redspeedfreak (howard)?
'04 Black Neon SRT-4
Stage 1, Forge WGA (19/17), DCR top end oil mod, MSD wires, K&N filter, 2.5" TBE dump w/ high flow cat, Exhaust Depot hard pipes with Greddy Type-s, fuel pump rewire...13.3@101mph
http://modcityscooters.com/index.php
http://www.myspace.com/tjvalentin
KrazyRdR83 is offline   Reply With Quote
Old 04-08-2008, 08:07 AM   #8 (permalink)
TURBOMATT's Avatar
Member Number: 27342
What do you mean thanks -Matt- are you mad at me??
TURBOMATT is offline   Reply With Quote
Old 04-08-2008, 08:13 AM   #9 (permalink)
thepowertowin's Avatar
Member Number: 13897
Trader Rating: (619)
If it starts up w/o cycling the key, then I would imagine it could be something as simple as the IAC wiring or the IAC itself. When the IAC goes open, it shuts, which would shut off all air assuming you're off the throttle. Are you off the throttle, or was it open throttle when it died?
ALL MOPAR AND MOPAR PERFORMANCE PARTS!!!!
James "Jimmy" Campbell
E-mail/Paypal: speedandpowerdevelopment@gmail.com
Email is better than PM's
http://www.srtforums.com/forums/f165...12/?highlight=
thepowertowin is offline   Reply With Quote
Old 04-08-2008, 10:18 AM   #10 (permalink)
Spyder9071's Avatar
Member Number: 22580
Trader Rating: (19)
I think he meant "Thanks. Matt" as in Thanks to anyone who can help me, sincerly Matt as him signing his name at the end of his post.
2006 TR Pontiac GTO M6 | Modded and Tuned
2006 King Ranch F250 CC Turbo Diesel | Modded
Spyder9071 is offline   Reply With Quote
Old 04-08-2008, 11:51 AM   #11 (permalink)
TURBOMATT's Avatar
i was giving him a hard time lol
Old 04-08-2008, 03:06 PM   #12 (permalink)
Spyder9071's Avatar
Trader Rating: (19)
gotcha
Old 04-08-2008, 05:24 PM   #13 (permalink)
when the car shut off on my i was just cruising in 4th gear... but as far as the hanging idle im completely off the gas and it shows 4-6 throttle %... on the IAC does it matter which way it goes in? like with the plug on the sensor pointin up or down... cuz on my 62mm throttle body it has 2 holes but the IAC has only one on it where it bolts to the tb
Old 04-09-2008, 07:25 AM   #14 (permalink)
While the car is shut off, remove the cold pipe from the throttle body. Then start it up, and put your finger over the IAC passage inside the throttle body. @ idle the only way air can get in is through that passage. If you cover it, the car should die. If it doesn't, you know you have to look for a vacuum leak.
Old 04-09-2008, 05:23 PM   #15 (permalink)
ok well i cant get to my car until this weekend cuz i am up at school.... and then if the car does die then what?
