Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > Florida Forums
Old 11-06-2009, 04:05 PM   #6601 (permalink)
Member Number: 67038
Quote: Originally Posted by JPG View Post
how old is your fuel pump?
5 month......im leaning towards aids.... i will check the plugs.
Delta 55 Turbo kit, agp catch can, agp solid motor mounts,scangauge and wideband, 3 bar map and tip, Injen Sri, Jmb with hks, stage 1, exhaust depot custom undercar dump, grantelli wires,DW 750's, walbro. rescale by turbo 666
AllBoost is offline   Reply With Quote
Old 11-06-2009, 04:30 PM   #6602 (permalink)
PsychoSRT05's Avatar
Member Number: 28174
Trader Rating: (12)
He says the aids, I'm thinkin herpes. you could haz the herpes...
PsychoSRT05 is online now   Reply With Quote
Old 11-06-2009, 04:49 PM   #6603 (permalink)
JPG
JPG's Avatar
Member Number: 41528
Trader Rating: (24)
aids isnt good mang
Quote: Originally Posted by Pizza Boy View Post
You can solve that with NRA and SWAT while listening to NWA and hooking up your WGA. OMG WTF BFF just STFU and im like IDK.
Mopar s3 w/toys + delta44 =
┌∩┐(O_o)┌∩┐
JPG is online now   Reply With Quote
Old 11-06-2009, 04:52 PM   #6604 (permalink)
actually............. lol heres the log
flat idle
Old 11-06-2009, 05:57 PM   #6605 (permalink)
JPG
JPG's Avatar
Trader Rating: (24)
Old 11-06-2009, 05:59 PM   #6606 (permalink)
Trader Rating: (12)
lulz ahahahaa
Old 11-06-2009, 06:08 PM   #6607 (permalink)
i knew something was up.............well my o2 sensor was only finger tight and the voltage of it is jumping from like 800s where it normally is and then it falls to like 200 and then it jumps back up and is doing that constantly. i think that maybe the problem.
Old 11-06-2009, 06:16 PM   #6608 (permalink)
Trader Rating: (12)
did u get any cels?
Old 11-06-2009, 08:09 PM   #6609 (permalink)
MoxhairR/T's Avatar
Member Number: 17662
new wheels look good dude!
Thank you, I'm going to try to get some better pics tomorrow.
MoxhairR/T is offline   Reply With Quote
Old 11-07-2009, 09:36 AM   #6610 (permalink)
Trader Rating: (12)
So let's all get together, whoever is going to the hybridkid meet, and show up with a nice convoy.... huh? what do you guys think?
Ft.Myers and Cape Coral peeps can meet up with the Naples guys. Then all together we rollllll. There are still some maybes, I totally understand. I'm just getting it all started. Let's go
Old 11-07-2009, 09:46 AM   #6611 (permalink)
Slow4D00R's Avatar
Member Number: 64409
Quote: Originally Posted by bloodredsrt4 View Post
well guys im not for sure going to the hybrid meet... i totally forgot Fixx Fest was the same day at Bradengton.... its a toss up right now on which one i wanna go to
fixx fest
Slow4D00R is offline   Reply With Quote
Old 11-07-2009, 09:50 AM   #6612 (permalink)
Slow4D00R's Avatar
ok guys. got a problem. so out of nowhere the car idles and cruses really lean. like around 15.7. just started to happen out of nowhere. the short term fuel trim is going nuts trying to correct. but one thing i noticed right when it started is that my ground wire for my wideband is loose. it still is but idk if that would cause this problem. but it is def running lean. i have a broken injector clip also so i jiggled it around and pushed down on it to make sure it was on and its good to go. any idea what is causeing my problem. also as far as i can tell, WOT fuel has not been effected at all. am i maybe loosing fuel pressure.
you need to just get the tune and stop fucking with it, every single page your changing something...just set it! and forget it! (lol) but yeah my car idles at 14.8-15.7 and it goes back and forth and when driving its at like 14something just crusing
Old 11-07-2009, 09:51 AM   #6613 (permalink)
did u get any cels?
nope no cels. and my spark adjust is going pretty crazy to. as you can see in the datalog. cant figure out whats going on. i swapped the o2 and nothing changed. still is reading 15.7-16.0 at idle and cruising.
Old 11-07-2009, 09:58 AM   #6614 (permalink)
well i think the scangauge is on the fritz. even when i pulled the key out of the ignition it is staying on and still drawing current.....what could cause this. also whenever i go to look at long term fuel trim it shuts the gauge off and reboots it.
Old 11-07-2009, 10:29 AM   #6615 (permalink)
JPG
JPG's Avatar
Trader Rating: (24)
gauges is definately going out. also, ur fucking afr's are supposed to be that high when cruising! want me to come get you and show you? LOL
Page generated in 0.82570 seconds with 13 queries
