Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > Florida Forums
Old 11-21-2006, 08:47 AM   #1 (permalink)
Member Number: 40273
Trader Rating: (21)
Default Cold Weather and PCM controlled boost
I know that the cold weather is the cause for my low boost, because my computer is controlling boost. I was just wondering if those of you who have boost controllers or rerouted vaccum lines are seeing a drop in boost due to colder weather. I'm only seeing 10 lbs right now, but my car is stronger than ever. If your not dropping boost, how is your car fealing?
S3Rh
Missing 04 Eblue as of 7/11/08.
98turboteg is offline   Reply With Quote
Old 11-21-2006, 09:08 AM   #2 (permalink)
12envy's Avatar
Member Number: 28991
Haven't noticed a drop in boost. Car does feel stronger but nothing worth bragging about, just a little stronger. BTW have AGP WGA and Profec B II with no spike holding 15psi to redline.
12envy is offline   Reply With Quote
Old 11-21-2006, 10:47 AM   #3 (permalink)
mpbiv's Avatar
Member Number: 42
Is your wastegate tensioned properly?
I am just wondering, because I am seeing 15-16psi peak on Stage 2 (no toys) with the cooler weather. I believe I was running 17-18psi peak a couple weeks ago when the weather was warmer.
'05 SRT-4: 366whp 388ft-lbs, 11.9@117mph
mpbiv is offline   Reply With Quote
Old 11-21-2006, 11:14 AM   #4 (permalink)
Trader Rating: (21)
I usually run 15 and then it climbs to 17 then falls to about 13 at redline. I havent had time to put more tension on the WGA, but i've been meaning to. I'd like to do that when the weather returns to normal so that i can see the real amount of boost im running.
Bt the way, your running stage 2 w/o, but are you PCM controlled?
Old 11-21-2006, 11:17 AM   #5 (permalink)
mpbiv's Avatar
Member Number: 42
Yes, I am PCM controlled with 4mm of preload.
Old 11-21-2006, 12:12 PM   #6 (permalink)
Trader Rating: (21)
I already have about 3/16 of an inch of preload on it. WTF?
Old 11-21-2006, 01:07 PM   #7 (permalink)
Bewstd04's Avatar
Member Number: 44433
Eh my car only acts up for first 15min of driving. Soon as its warmed up, woo 16-17 is no problem(S1+stock wga). I just need to have someone put my S2 wga in now haha.
S1, Msd 8.5, Hemi plugs, PsiFi CAI, Greddy Type-S, race mm inserts, PTP-Wga 18/15, Vibrant Perf. front/rear strut bars, Maxxfab 3" downpipe with dump tube.
Srt is dead as of 7/21/07. Twas a fun ride.
Bewstd04 is offline   Reply With Quote
Old 11-21-2006, 01:09 PM   #8 (permalink)
Chase's Avatar
Member Number: 34635
my boost goes up in the weather. Usually 17 or 18 in the cold its 19 or 20
I`m not perfect, but who are we kidding neither are you.
It`s Slow But Show Me Some Love
Chase is offline   Reply With Quote
Old 11-21-2006, 01:41 PM   #9 (permalink)
SRToc Member
manic_mopar's Avatar
Member Number: 25488
Trader Rating: (32)
sounds like your computer is confused.
i'm MBC controlled and i still hit 22psi even in the 40's
Pablo Tuned
380whp/396WTQ I'm a meth addict...
Stage 3R powered
manic_mopar is offline   Reply With Quote
Old 11-21-2006, 02:34 PM   #10 (permalink)
Chase's Avatar
no complaints here ran my best at the track with it cold like this. Was hitting 19lbs all night and the next day back at 18 like usual. Just got cold again was just giving it gas last night to see if it would register the same and sure enough back at 19 again. Nothing wrong with that. I like my dumb computer.
Old 11-21-2006, 03:20 PM   #11 (permalink)
RedSpeedFreak's Avatar
Member Number: 26515
Boost by gear FTW!!!!
2005 SRT-4 w/35,000 miles for sale. $14k obo PM me for details.
"Orlando's SRT whore-house garage"
What do you want installed/tuned/ported/welded? PM me for pricing.
RedSpeedFreak is offline   Reply With Quote
Old 11-21-2006, 05:33 PM   #12 (permalink)
Fluke-SRT4's Avatar
Member Number: 13101
Trader Rating: (15)
PCM Boost controlled, Stock wastegate and no BC, the car will boost less on cold weather, but will no lose any power. Just the computer ajusting cause on low temps. Super low btw, is freaking cold outside.
Best run: 12.878@107.87 2.082 60' (street tires, 2850lbs) 04/15/06
Fluke-SRT4 is offline   Reply With Quote
Old 11-22-2006, 10:09 AM   #13 (permalink)
Trader Rating: (21)
Thats what I thought. So I guess now's not a good time to adjust my WGA tension. Ehh, couple turns wont hurt...
Old 11-22-2006, 03:31 PM   #14 (permalink)
Trader Rating: (21)
Well, it turns out my boost gauge took a hot dump.
Another dead autometer.
Thats the second one now. If I cant get it replaced for free, which one should I buy?
Old 11-22-2006, 05:05 PM   #15 (permalink)
06Limit's Avatar
Member Number: 43104
I know I'm not from the area but... here in MA when it's about 25 in the mornings my boost only spikes to about 13 psi. I am running stock pcm and stock wga. 10 psi seems a little low though im not sure. the car still runs as strong or maybe slightly stronger.
06Limit is offline   Reply With Quote
