stock intake with box off = short ram.. cheap an works fine. if you dont like the short ram then get another cheap pipe to ext it down.. still add it all up = cheaper then CAI
any reason why more prople perfer short ram more then cold air.
is cold air more effecient or what.
explain why which 1 is better.
i got a k&n Typhoon Cold air and i wanna know if it even makes a difference.
Intakes make almost no difference on an SRT4 or turbo car for that matter anyway. Unless there was some big restriction in the stock intake, the turbo will suck in as much as it can anyway. It doesn't matter if the air is colder or not, the turbo is hot anyway and a few degrees won't gain you any power.
because short ram is cheaper and does the exact same thing. Also with cai's, ive sucked up water before which was real scary for about five minutes. i still prefer the cai though, i dont really have a reason why.
Stage 1, K&N CAI, AGP WGA, SD Coilpack, Crane FireWires, NGK Plugs, PSI-FI MM's, MSR 190's In Super Finish, BF Goodrich G Force Sports 225/45/17 Goldline Lowering Springs, Goldline Camber Kit, CM Stage 3 clutch, CM Aluminum Flywheel
I rebuilt a motor for a guy whose girlfriend drove the car through water 1 foot deep...his CAI sucked in water and bent the rods.
I'm still running the stock box on my latest SRT-4. Do recommend leaving it on, taking it completely off and putting some sort of filter/screen on the turbo, or doing what RobFlame05 said, remove the box? Thanks.
RUgoinUp 2 Heaven? Ever lie, steal (big or small), commit adultery (in deed or thought), use God's name in vain? Those are just 4 of the 10 Commandments, breaking just 1 condemns you to Hell. Claiming to be a "good person" won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit your guilt, and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
I'm running a huge turbo. I've always thought about making a 4" short ram and moving the battery to the trunk, but I've always been so busy I've never gotten around to it. Now I'm selling the car, so the stock turbo and stock airbox are going back on.
If I were you, I would save my money on other mods, until you decide to upgrade from the stock turbo. If you absolutely hate the stock airbox, buy a short ram and call it a day.
You can just take off the stock air box.. then you will have a short ram.. Get a hoseclamp or ziptie to keep the filter on the pipe and poof... $1.oo short ram intake
I have a CAI that can be run as a short ram. I don't feel any difference between the two. Might notice a few ponies on a dyno, but its negligible. Not worth the risk for me in storm-prone Central FL to run a CAI. Puddles get very deep, very fast in certain parts of Tampa, St. Pete, and Clearwater.
I prefer the short ram over stock box because it clears out a lot of space in the engine bay, and it's easier to access things.
