nitrous kit is in great shape......i am very anal about anything but nitrous going though the lines or solenoids....i used a nx filler (bottle filter) when getting the bottle filled......kit has been on the car for about 20K miles...i'd say...about total of 8 full bottles....(would refill when @ 5 lbs left)
comes with
nitrous and fuel solenoid complete with fittings
relay
solenoid braket
wot switch w/ bracket
10 lb bottle w/ brackets, (bottle will come with 7lbs of nitrous)
nx nitrous guage
main nitrous line, fuel line, and lines to run to fogger
nx nozzle
35,60,75,80,90,100 shot combo jets
NOS purge kit
NOS nitrous filter
all wiring to run everything
1 activation switch
MSD 8969 digital window switch ( no tach adapter needed)
450 for my cali folks .........nx kit, window switch and purge kit
also have my 3" side exit......origionally it was a maxxfab 3" catless downpipe.....then my flex pipe broke...so i had it replaced with a 3" solid piece....the side exit part was custom made and has a 23" dynomax bullet race muffler
the-violator also had his exhaust made at the same place but he used 2 18" resonators.....and srt-monster has the same exact ehxaust as me.........the exhaust has a extra bung for a wideband sensor.
BEST part of this exhaust is that the exit part is cut flush with the underside of the car and has a slight turn down to it...so it cant be seen unless you look under the car....if you look in the pic in my sig you cant tell i have a side exit but its there !!!! this way you can leave your tips in the rear and look 100 percent stock to the cops
300 delived to sd or will meet in sd
thanks,
alex
