Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 01-24-2008, 12:02 AM   #1 (permalink)
MINI VPR's Avatar
Member Number: 55627
Default P1681 Anyone know what this code means?
I tried looking for it but didn't find it, does anyone have any idea what it means?.....
MINI VPR is offline   Reply With Quote
Old 01-24-2008, 12:58 AM   #2 (permalink)
master_1011's Avatar
Member Number: 3396
Trader Rating: (18)
P1681 Driver 5 Line 1
I have no clue what that means, though.
First SRT-4 sold on Guam
master_1011 is offline   Reply With Quote
Old 01-24-2008, 02:10 AM   #3 (permalink)
Member Number: 3396
Trader Rating: (18)
I just spent 45 minutes searching the FSM...It's not there either....
Old 01-24-2008, 02:29 AM   #4 (permalink)
HMS4's Avatar
Member Number: 11228
Hmm, checked mitchell ondemand, didn't come up either. All the codes starting with P16XX were PCM related, your pcm had a brain fart or is f'd up.
HMS4 is offline   Reply With Quote
Old 01-24-2008, 02:32 AM   #5 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
Took this from one of the PTDIY boards...dunno if it'll help or not.
I have a 2003 PT with 8k miles on it, which I had serviced today because the engine light came on and fuel gauge needle dropped to empty and then back to the correct level, indicating about half a tank. The dealer indicated that the problem was corrected with TSB 18-029-02, (Software download to correct an issue pertaining to hard starts or long-crank to start the car.) which updated the controller. After the repair I was about one mile from the dealership when the engine light came back on and fuel gauge needle dropped to totally empty, then back to half-full, to empty, and finally to one-eighth tank. The technicians at the service center are clueless thus far. I suspect that after updating the software the technician did not run the diagnostics again to make sure there were no further issues and that the codes were cleared. The fault codes were PO462, PO1604 and P1681. Other than this issue, it's a fabulous car. - Rob, from USA.
It sounds like a simple intermittent circuit in the sending unit. It's a mechanical gauge wired to the sending unit in the tank. The dealer may be searching for a computer problem when it's only a mechanical defect.
P0462 Fuel Level Sending Unit Volts Too Low - Fuel level sensor input below acceptable voltage.
P1604 PCM Internal Dual Port Ram Read/Write Integrity Failure - Dual port RAM read/write error.
P1681 No I/P Cluster CCD/J1850 Messages Received - No CCD/J1850 messages received from the cluster control module.
Follow up from owner - I called the dealer on Friday, intent on taking the car to another dealership on Tuesday, since the first shop had the car for three days. When I arrived, the service advisor told me they had discovered that the problem was a faulty headlamp wiring harness. Since the repair, I have started it seven times while running errands and found no repeat of the MIL or gas gauge needle issue.
O4 PT Cruiser non GT
Stock b****es, come get me
SoCal's fastest PT Cruiser
Turbocruiser13 is offline   Reply With Quote
Old 01-24-2008, 11:04 AM   #6 (permalink)
GdnSrt4Stg3's Avatar
Member Number: 31013
hope this help, on my DTC diagnostic said P1618 is Manufacturer control auxiliary inputs auxiliary outputs.
maybe loose wires somewhere. maybe obd port?
GdnSrt4Stg3 is offline   Reply With Quote
Old 01-24-2008, 02:00 PM   #7 (permalink)
blkturbo's Avatar
Member Number: 56971
it means you need new windshield wipers.
lmao!
blkturbo is offline   Reply With Quote
Old 01-25-2008, 02:43 PM   #8 (permalink)
MINI VPR's Avatar
Well thanks everybody, i'll post an update...
Old 01-28-2008, 04:59 PM   #9 (permalink)
"THE RED ONE"'s Avatar
Member Number: 48694
Victor you mite want to get it checked at the stealer ship. Just a few weeks ago my whole electrical system got fryed. I was told it was due to the green cable that runs to the starter. I had to pay $1,000 for a new battery, starter, two different wire harness plus $200 for towing. Bro so you mite want to get it looked at soon.
"THE RED ONE" is offline   Reply With Quote
Old 01-28-2008, 05:57 PM   #10 (permalink)
05Wh!t3BomB's Avatar
Member Number: 53318
motha fucka u need jesus.. oh and stage1 pcm
05 StoneWhite
05Wh!t3BomB is offline   Reply With Quote
Old 01-28-2008, 07:22 PM   #11 (permalink)
SRT4SINA's Avatar
Member Number: 30904
Trader Rating: (12)
03 Solar Yellow SRT-4
60,000 miles and counting. Zero boost leaks.
<---------------------------Twisties Freak.
Powered by: a.c.t. Energy
The healthiest and wisest choice in Energy Supplement Consumption.
actenergy. c o m/ act4abe (no spaces)
SRT4SINA is offline   Reply With Quote
Old 01-28-2008, 10:40 PM   #12 (permalink)
damn for realz man...just think of the mods you could have had if your car didn't have some catastrophic failures every other month!
Old 01-29-2008, 11:37 AM   #13 (permalink)
Thats the reason why im selling the car soon.
Old 01-30-2008, 04:08 PM   #14 (permalink)
MINI VPR's Avatar
What up Randy hey, i've seen ur car around the corner by my house....
I'm still under factor warranty and they installed a new starter, code is not here no more.
Old 01-30-2008, 04:16 PM   #15 (permalink)
thats some fucken bull shit.. how the fuck r u still under warranty.. ima tell that dealer about u
