Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 03-27-2006, 07:40 PM   #1 (permalink)
04TurboSRT's Avatar
Member Number: 12748
Default o oh... i think my tranny just died :(
so i'm driving just normal, went did some errands and go home pulling in the driveway really slow and pull up to the mail box outside the pad and the car would not come out of 1st gear with the clutch pedal fully depressed and car would not stop so i step on the brakes and stall the motor before i hit a tree with the motor off, i was able to put it back in neutral and start up the car but it wont go into any gear when the motor is running but when i turn the motor off it goes in all the gears no problem..
so anyway, is it my tranny or just the clutch or clutch slave? what do you guys think
thanks...
S3RToys, E-Manage, Walbro 255, CTI HS pipe, JMB L/UPP w/ 1gdsm bov, DCR oil mod, AGP Race FMIC, AGP WGA, BWoody CBar, Kinetic 60mm TB, ExHone ITM, Injen SRI, CMist W/I, MaxxFab O2H, Mopar CatD/B, Prothane Inserts, PTPcheckvalve, 8mm wires, ClutchMasters Stg4 w/Alum Fly, slow4drSTS, DCS F/R STBs, PT/ACR sway/tension bars, Revitup TractionBar, Eibach Coilovers.
1/4 mile: 11.93@115mph on M&H 24.5" slicks (1.85 60ft) & HOM drop in 4th
04TurboSRT is offline   Reply With Quote
Old 03-27-2006, 07:50 PM   #2 (permalink)
jmihalchik's Avatar
Member Number: 4142
possibly the fork or the slave, doubt its the clutch since u replaced it already.
12.879@110.21, stage 0, no juice, stock fuel, stock o2 housing, stock bov, stock tb, stock intake mani.
jmihalchik is offline   Reply With Quote
Old 03-27-2006, 07:53 PM   #3 (permalink)
SRToc Member
Member Number: 10435
Sounds like the slave. Just replaced one on my girlfriends beater the other day. No problemo.
Stage3 R w/toys,Clutchmasters stg 3, Tokikos 5-way struts, Spearco direct-fit intercooler, E.D. hardpipes,Iceman TB 60 mm, Mpx 3" exhaust-02, Aem short ram, Mpx crank pulley, DCsports front-rear strut bars, MM, Progress front, rear swaybars, Eibach springs, Mopar STS,BOV, Msd 8.5 mm wires, NGK iridiums, tuner tail lights, Mpx carbon fiber fog lights, injector cover, scoop, Billet pedals, Auto meter tripple guage combo, Tint all around,
solardodgesrt4 is offline   Reply With Quote
Old 03-27-2006, 07:55 PM   #4 (permalink)
red
red's Avatar
Member Number: 2869
, does your shifter move side to side at all? From the couple of times I've had to warranty shift selectors it could be that. Similar circumstances too.
red is offline   Reply With Quote
Old 03-27-2006, 08:00 PM   #5 (permalink)
04TurboSRT's Avatar
is the fork inside the tranny? what exactly does it do? can it be fix without pulling the tranny?
the pressure on the clutch pedal seems normal not mushy or anything. i checked the clutch fluid level as well and all is good
Old 03-27-2006, 08:03 PM   #6 (permalink)
04TurboSRT's Avatar
you mean the neutral gate? it does when in neutral but not when it's in gear.. i also have an sts so it hardly moves anywhere to start with.
Old 03-27-2006, 08:10 PM   #7 (permalink)
red
red's Avatar
Member Number: 2869
, well when I broke the shift selector tab off, I could move the shifter forward into where 3rd would be. It wouldn't move left or right at all and it wouldn't go into where 4th is supposed to be. If you can move yours around and the cables ends are atached.... Most likely a slave
Old 03-27-2006, 08:23 PM   #8 (permalink)
04TurboSRT's Avatar
hmmmm, tell tale signs i noticed started about 2 months ago, sometimes i couldn't find first gear instead it would go into 3rd or from 3rd gear, i couldn't easily downshift to 2nd then just couple days ago at a light in first gear with my foot all the way down the clutch pedal i could feel the clutch very slightly catching kinda budging the car forward very softly.. those symptoms were intermittent, today without any warning it almost ran me into a tree
Old 03-27-2006, 10:45 PM   #9 (permalink)
BACARDI_DWB's Avatar
Member Number: 20780
Trader Rating: (18)
sounds like clutch to me....
SRT Sold
BACARDI_DWB is offline   Reply With Quote
Old 03-28-2006, 01:50 AM   #10 (permalink)
Member Number: 21848
kind of sounds like the infamous shift selector, hmm although u said u werent hard shifting at all...interesting?
sentraman is offline   Reply With Quote
Old 03-28-2006, 12:09 PM   #11 (permalink)
srt4ram360's Avatar
Member Number: 5448
Trader Rating: (28)
check to see if your leaking any clutch fluid under the dash from the clutch master cylidner...exactly what your discribing happened to me....i had to limp my car home ...shut it off at lights..and start it with the car in 1st gear...and then rev match shifting all the way.....with the car off i could go though gears fine...but once the car was on....clutch all the way down just wouldnt go in gear....then i noticed a stain to the left of the clutch pedal....looked under there and sure enough....fulid from the master clyinder
alex
2005 Mustang GT, intake, full exhaust, tuner, pullies, and some extra's
STOCK STOCK STOCK just the way DCX likes it
srt4ram360 is offline   Reply With Quote
Old 03-28-2006, 12:14 PM   #12 (permalink)
04TurboSRT's Avatar
well just talked to adam on the phone and he's almost certain it is the clutch.. he said it most likely welded itself to the flywheel.. weird because i wasn't driving it hard at all when it broke
before i pull my tranny and do all this work, can anyone tell me for sure it is not just the clutch slave? once again the fluid level is good, pressure on clutch pedal seems normal and it doesn't stick to the floor or anything so i think it's not the slave.. but just want to hear more opinions or maybe experiences before i pull the tranny for nothing thanks to all who responded
Old 03-28-2006, 12:21 PM   #13 (permalink)
srt4ram360's Avatar
Member Number: 5448
Trader Rating: (28)
well when mine firsted started to lock me out of gear the pedal felt fine and fluid was good...then about 3 hours later...fluid was completely gone and pedal felt like shit...so if your fluid and pedal are good the i'd say its not that
good luck,
alex
Old 03-28-2006, 06:23 PM   #14 (permalink)
04TurboSRT's Avatar
150 views and 13 responses, half of them were mine come on guys!!! help a brotha out
for more opinions
btw, adam said i should try to drive the car to the shop by shift/matching the rpms and i should be able to get it into gear without the clutch i might try this but i have to do it at night with zero traffic or i'm screwed...
oh i forgot to ask him where the new shop is, can someone give me directions? thanks..
Old 03-28-2006, 06:35 PM   #15 (permalink)
Trader Rating: (18)
hey bud come out to dinner tonight... i will pick you up and i can take a look at your car and check it out..
