Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 3 > California Forums
Old 06-30-2008, 09:39 AM   #1 (permalink)
Mr. Whiskers's Avatar
Member Number: 62818
Default Newb Question Re: PTP WGA
I have an 03, with a CAI on it and I have a PTP WGA in the mail. I asked the current owner what he had it set to, and he said it was spiking 20 and holding 18. This seems a little high for basically a stocker which might throw a code for over boost (I read the limit for boost is around 21psi). I'm not going to go past Stage 1 ever on this car, so I want to make sure. I'm not a huge tuner, so my modest goals for performance are below:
WGA
Stage 1
CAI
BOV
Is there anything else I need to worry about when installing this WGA?
Should I set it a bit lower (spike 18, hold 16) to make sure I don't damage the car?
What kind of gains can I expect at spiking 18 and holding 16? I'm currently holding 14psi, but I've heard our stock boost gauge is not accurate.
Thanks a ton for the help guys.
Whiskers!
Mr. Whiskers is offline   Reply With Quote
Old 06-30-2008, 09:55 AM   #2 (permalink)
tude_srt4's Avatar
Member Number: 59159
Trader Rating: (12)
WGA
Stage 1
CAI
BOV
Whiskers!
with the stage 1 you could get away with spiking 20 and holding 18. but to be on the safe side i would turn it down to spike 18 and hold 16. now if you get a check valve or a boost controller you could hold 18 more then likely.
as far as hp gains i say 20-30 hp. you'll feel the difference due to the ptb issue somewhat being solved with a aftermarket wga. just remember more boost doesnt always mean more power......
tude_srt4 is offline   Reply With Quote
Old 06-30-2008, 10:03 AM   #3 (permalink)
tamadx's Avatar
Member Number: 26290
Trader Rating: (18)
you will get more PTB (part throttle boost) with the PTP WGA.....
With the stage 1 injectors in there 17 -18 spike is all i would do and you will throw a code unless you cap the red line.
S3, WGA, Return Line, CAI, Turboback, BFMIC, 55mm TB, DTEC, Wideband, W/I, Scan Gauge, Ported Stuff
tamadx is offline   Reply With Quote
Old 06-30-2008, 10:15 AM   #4 (permalink)
As far as adjusting the PTP WGA, what is needed to make sure I'm spiking and holding? I'm not familiar with the WGA, so is it a spring I need to get for it? Or can I manually adjust it for less boost?
Thanks again.
Whiskers!
Old 06-30-2008, 10:45 AM   #5 (permalink)
Member Number: 59167
Trader Rating: (19)
Thanks again.
Whiskers!
The PTP WGA comes with a spring installed. All you need to do is install the WGA and then adjust the WGA rod using a 10mm and 11mm wrench. By adjusting it, you are controlling the maximum boost you will see (technically the spike).
The holding PSI seems to differ on each car based on PCM, boost leaks, etc. Unfortunately, not as controllable.
Recommendation is to do the following -
Install an accurate boost gauge (or better yet, a scan gauge)
Do a boost leak test
Install the PTP WGA
Do a few runs where you have someone watching the boost (or record using the scan gauge). Make sure you ease up to max boost just to make sure you don't spike to high.
Adjust WGA until you are happy with max boost and holding boost
If you throw a code, clear by unhooking the battery or pulling fuse, lower the boost and retry.
It will take a bunch of runs until you are probably happy.
jnathan68 is offline   Reply With Quote
Old 06-30-2008, 01:19 PM   #6 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (173)
Install the PTP WGA
Well said ^^^^^^
to the OP, if you still have ?s hit me up..........
PTperformance PTP's Cali CREW Mole'
co-founder of www.casrtoc.com
100% BONE STOCK.
Old 06-30-2008, 04:30 PM   #7 (permalink)
SRT4SINA's Avatar
Member Number: 30904
Trader Rating: (10)
Don't forget that you will have to modify your vacuum lines unless you want to run 25+ PSI on the stock turbo.
03 Solar Yellow SRT-4
Zero boost leaks.
Powered by: a.c.t. Energy
The healthiest and wisest choice in Energy Supplement Consumption.
actenergy. c o m/ act4abe (no spaces)
SRT4SINA is offline   Reply With Quote
Old 06-30-2008, 08:26 PM   #8 (permalink)
SlowSRT05's Avatar
Member Number: 32481
Trader Rating: (32)
wow its crazy that all the fucking retarded answers come from out of staters.
1st off your NOT gonna throw a code because your stage 1
2nd No hell in way he or you will be holding 18 on stock turbo. max 15 maybe if lucky 16 in 4th gear
3rd do not spike 20, max spike 18 If you wanna run more then you'll need a map clamp
4th a wideband and scan gauge will be useful
5th remember to reset the battery after its installed and after you've set the desired psi
6th everything jnathan68 said is dead on accurate besides the code, since your a staged upgrade you dont have to worry about it.
-Randy
Getcha Popcorn Ready! -T.O.
SlowSRT05 is offline   Reply With Quote
Page generated in 0.17429 seconds with 11 queries
