Here's the deal, My clutch is fine (I think).. but lately here's why my trans is doing. When I shift soft, or just cruise .. it almost never grinds or has problems going into gear. Shifts really smooth. but when I get in it.. or try to drive fast .. the gear grinds or kicks out or both. Just a 3rd gear synchro? What do you think?
Gay, well, hell I might as well replace everything else if I'm replacing that.. clutch included
its the third syncro for sure.... mine does the same. it used to only popped out when i was down shifting and now, sometimes, even when im shifting up. shift fork and syncro for sure:
New 3rd gear synchronizer and new shift fork should get the job done. Depending on how your clutch is and given mileage will determine if you should swap it out or not.
03 Solar Yellow SRT-4
60,000 miles and counting. Zero boost leaks.
<---------------------------Twisties Freak.
Powered by: a.c.t. Energy
The healthiest and wisest choice in Energy Supplement Consumption.
ay bro this job can get kinda pricy...
i got syncros replaced with fork... and a new clutch..
with install it ran like 2600...
but i got a 900 dollar clutch.
i did my car at tustin transmissions...
pm me if you need more info.
Disassemble, diagnose, and repair it yourself. Who doesn't have a set (or three) of the trans tools for the T850?
It's going to be hard to say for certain what's going on and exactly what needs replaced until you get it out of the car, which can cause quite a bit of uncertainty since you also can't plan how much it will cost you to repair until you know what's broken or worn. Kind-of like the chicken and the egg scenario. It could just be something in the clutch engagement mechanism or maybe that along with a bunch of internal components are damaged.
If you don't plan to do any work yourself including install/removal and you've got the money to cover it and can find a good mechanic/trans guy you shouldn't have any problems, but if you're watching finances and can turn a wrench you might be better off sourcing a low mileage used transaxle. It's probably going to cost less than a rebuild and you can then swap that in and drive the car while you figure out what's wrong with your current trans (if you so desire).
Didn't somebody just have a problem with Tustin Transmission???
