Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 07-22-2005, 04:14 AM   #1 (permalink)
SRToc Member
The-Violator's Avatar
Member Number: 3510
Default Need Help in SoCal
Holy hell.. I just finished raising the boost after installing my new pump and return line.. I upped it to 18psi.. It's like WHAT THE SHIT fast at only 18psi, I can't imagine some of the other guys out there running 22+.
Well to the reason of why I need help.. My car must be doing something right because without even launching, I was able to break the upper motor mount bolt that goes to the engine block... Sheered right off.. And it's one of those "stronger grade" bolts that comes with aftermarket dogbone MM's.. I need to know where I can get one TODAY(Friday). I want to race tomorrow(Sat.) afternoon so I need one by then... Do you think Home Depot would carry something like this..
Adam, you wouldn't happen to have something like this would ya.. Or anyone have an extra one I can buy/borrow??
Also need to get the broken piece out of that grey thing it screws into , but I think I can handle that part. Just need a bolt extractor drill bit..
-Jason
The-Violator is offline   Reply With Quote
Old 07-22-2005, 04:29 AM   #2 (permalink)
SRToc Member
Member Number: 3510
Heeeeeeeeelp!
Old 07-22-2005, 04:40 AM   #3 (permalink)
SilverSRT4Ken's Avatar
Member Number: 498
Trader Rating: (15)
dont go to HD for that= ACE hardware usually has the better bolts selection- get grade8 SAE or (10 hardness metric)- good luck!
2003 silver SRT4: Stg3,'05 LSD,StoptechST40,3"EXH, MoparCAI,BFMIC,BCinvertCO,17x8-245/40,ELW-wing,Kaminari front,Halos,M3mirrors,difusor bottom..........
2003 SV650 'S' with GSXR750 brakes/suspension
2005 GSXR600 trackbike Allstare Corona white & silver
SilverSRT4Ken is offline   Reply With Quote
Old 07-22-2005, 04:41 AM   #4 (permalink)
SRToc Member
Member Number: 3510
Ok I'll try that.. Thanks Ken..
Old 07-22-2005, 04:47 AM   #5 (permalink)
Ferndogg's Avatar
Member Number: 26412
X2 ace always has better bolts.
Ferndogg is offline   Reply With Quote
Old 07-22-2005, 04:47 AM   #6 (permalink)
Ferndogg's Avatar
Wanna race for pinks?
Old 07-22-2005, 04:48 AM   #7 (permalink)
Dominion's Avatar
Member Number: 26655
Trader Rating: (10)
Heeeeeeeeelp!
Quote: Originally Posted by OPM
SRT4Hokie,
Upper Motor Mount: Frame to Mount ( It's the bigger bolt in the back of your picture close to the passenger compartment) - M12x90 x 1.75 Thread -torque to 50 foot pounds.
Not sure what size the big bolt is that goes through the center of the rubber.
Mount to Engine (2) - M1060 x 1.5 Thread -torque to 85 foot pounds. Not sure on Torque specs. My dealer didn't know. Info is from another post somewhere on here. Some people reccommend a stronger grade bolt (12.9 in metric) which = grade 10 I think. If you find some ARP's in these sizes please post part#'s
Grade SAE 10.6 or higher is what id personally recommend.
m14x95 with 2.00 pitch and approx. 50mm of thread upper motor mount bolt that connects it to the engine. Unconfirmed.... Use the following information as a referrence.
Napa has a good bolt section. Autozone and Kragen suck balls.
Robert S.
05 SRT-4 Flame Red
STOCK!!! No really, its stock..
Dominion is offline   Reply With Quote
Old 07-22-2005, 04:48 AM   #8 (permalink)
SRToc Member
Member Number: 3510
Serious? I could always use a beater srt4..
Old 07-22-2005, 04:49 AM   #9 (permalink)
SRToc Member
Member Number: 3510
Ok I'll keep that in mind, thanks! I'll try NAPA if ACE doesn't pan out..
Old 07-22-2005, 04:50 AM   #10 (permalink)
Dominion's Avatar
Trader Rating: (10)
Hardware store for high-grade bolts.. Oh man! Do they come galvanized?
Old 07-22-2005, 04:51 AM   #11 (permalink)
Dominion's Avatar
Trader Rating: (10)
Aztec Bolt & Nut
(619) 696-6844
318 16th St
San Diego, CA 92101
Give them a call.
Old 07-22-2005, 04:52 AM   #12 (permalink)
SRToc Member
Member Number: 3510
Wow thanks man.. Used them before, or just looked them up or something..
Old 07-22-2005, 04:54 AM   #13 (permalink)
Dominion's Avatar
Trader Rating: (10)
My friend used them once. Also, looked them up.. I use to use Ababa bolt but they went out of business..
P.S. I want a f$#king ride in your car!
Old 07-22-2005, 04:54 AM   #14 (permalink)
SRToc Member
Member Number: 3510
If your info helps me get to the races tomorrow consider it done..
Old 07-22-2005, 05:06 AM   #15 (permalink)
Ferndogg's Avatar
Yeah im serious. You can take this 03 off my hands and make the payment. Ill get a new 05 ACR.
