Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > US Regional Forums > California Forums
Old 04-06-2009, 12:21 PM   #1 (permalink)
XXxx_Totmacher_xxXX's Avatar
Member Number: 9649
My boost problem
Completly forgot about this... So yeah, remember when i dynoed and my boost was fluctuating between 20 and 25psi, causing the shitty dyno run?
So I figured it out the other day while uninstalling my MSBC-01. The "push-to-connect" fitting on the bottom of the gate, the push lock hose going in there was not properly cut with a razor knife, so it had a bad edge on it. It wasn't sealing right in the fitting so it was leaking intermittently from that fitting.
That explains why my car could run fine on 100% gate presure (air ontop of gate) with just Exhaust pressure pushing the gate up and controlling boost. but the second you went over gate pressure (16psi) problems started. the EBC would put manifold pressure to top of gate based of boost level, well manifold pressure to bottom of gate would fluctuate causing a inbalance from the EBC to the top of the gate vs the bottom of the gate. this caused the gate to move around causing the eratic boost levels.
Leson learned, just because you run all "Push-to-connect" fittings dosen't mean you are exempt from boost leaks
11.431 @ 123.61 BEFOR 90% OF YOU OWNED A FRICKIN NEON.
"MOLE' IS GAY"
If you didn't buy your neon new, have a 4+ year member status or don't know me personally don't bother to PM me questions.
Quote: Originally Posted by mole' View Post
i should be ready for this next Dyno Day.
XXxx_Totmacher_xxXX is offline   Reply With Quote
Old 04-06-2009, 12:24 PM   #2 (permalink)
CRZYCUBAN2's Avatar
Member Number: 37304
1st...
05 White NSRT4 44lb S3R and bolt-ons: SOLD
08 Silver CSRT4
CRZYCUBAN2 is offline   Reply With Quote
Old 04-06-2009, 12:28 PM   #3 (permalink)
nutz's Avatar
Member Number: 41700
good heads up
thanx
JDP
Dynomite tuning
