Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 01-09-2008, 09:11 AM   #1 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Default LOOKING FOR GM Certified Mechanic [sideline work]
Looking for a GM certified Goodwrench mechanic in the San Diego to Mission Vejo area to do some engine work on the side.
2004 Chevrolet Tahoe 5300 Vortec
hemidakota is offline   Reply With Quote
Old 01-09-2008, 10:54 AM   #2 (permalink)
edgeandink's Avatar
Member Number: 39262
Why a "Goodwrench Certified" mechanic?
edgeandink is offline   Reply With Quote
Old 01-09-2008, 11:03 AM   #3 (permalink)
TurboSrt_4_Jeramey's Avatar
Member Number: 55223
I will be going to school soon in Orlando for the GM ASEP program and will be certified. I am just curious how much you pay?
50 trim Turbo.......22psi......380WHP / 402WTQ corrected/s5.
TurboSrt_4_Jeramey is offline   Reply With Quote
Old 01-09-2008, 01:52 PM   #4 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
It seems there is an internal water leak...most likely a crack head or block. However, in the end, it would be better to replace the current motor with a same low mileage version.
How much and how long?
Old 01-11-2008, 11:54 PM   #5 (permalink)
Matterbaiter's Avatar
Member Number: 28849
Does ASE certs. count? I think I've got a few of those bad boys...
Do you have the motor? Do you have a place to do it?
Moo.
Matterbaiter is offline   Reply With Quote
Old 01-12-2008, 02:29 AM   #6 (permalink)
Member Number: 5369
Have you ruled out the lower intake manifold? I can't remember if the truck variants had the composite intakes but a lot of the GM's have sealing problems that leak coolant down into the engine. Many times when the Dexcool hasn't been changed sooner than the factory spec 5/100 it starts eating the gaskets.
Old 01-12-2008, 05:28 PM   #7 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Will check this first....if not, we have a low mileage 5.3 that will require an install. ASE is good enough. Name the cost of replacing the motor...
Eric, are you still working at MCTSSA? I can bring in the Tahoe.
Old 01-12-2008, 06:26 PM   #8 (permalink)
rasp's Avatar
Member Number: 56076
x2! Dexcool is crap coolant, imo. I've seen multiple GM motors have large sludge buildups from that crap and it's nowhere near "maintenance free" like GM likes to state. It's also gunks up with any sort of leak in the coolant system or when mixed with other types of coolant.
rasp is online now   Reply With Quote
Old 01-13-2008, 11:36 AM   #9 (permalink)
Member Number: 5369
Yep, got back from Germany a couple months ago. I'm currently bouncing around and covering different shifts though, but if you're working next week stop by Wednesday morning when you get in.
Page generated in 0.18941 seconds with 13 queries
