Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 06-11-2007, 10:00 PM   #1 (permalink)
ORANGE WHIPPEN's Avatar
Member Number: 41215
Default Installed 3 Inch O2 Housing
i cant believe i finally did it, it took 6 hours, and dont think i will be doing it again. the o2 housing from ebay fit perfect, and he did an excellent job making it. the feels very strong especially since i put new t bolt clamps on . spools up very fast.
ORANGE WHIPPEN is offline   Reply With Quote
Old 06-12-2007, 01:33 AM   #2 (permalink)
o5socalsrt's Avatar
Member Number: 45816
Trader Rating: (13)
Dang! Did you cut the heat shield or try and get it off without cutting it? 6 Hours?? Thats a long time
Quote: Originally Posted by Savior1974 View Post
bs, josh > all other 50trims
o5socalsrt is offline   Reply With Quote
Old 06-12-2007, 03:10 PM   #3 (permalink)
getnpsi's Avatar
Member Number: 14911
Trader Rating: (68)
I really need mine to arrive dammit. Ill get mine done in 5.75 hours because i wont get out from under the car to pee.
2004 Black. SSTv1, Stage 2 with toys, 3" exhaust with cat, Slow4DR shifter, CBD vented hood.
WTT: CBD vortex generator for a w/i kit.
getnpsi is offline   Reply With Quote
Old 06-12-2007, 06:03 PM   #4 (permalink)
There Was One Bolt That Came Crossthreaded From The Factory . I Had Really Bad Time Gettin It Out. I Mangled The Heat Shield Taking Out.
Old 06-12-2007, 11:49 PM   #5 (permalink)
Overcome's Avatar
Member Number: 24451
Trader Rating: (20)
O2 housings are always loads of fun the first time.
“Believe in yourself. Believe in your own potential for greatness. Believe that you can change the world. It is something that is within each of us.”
– Evan Michael Tanner 1971-2008
Old 06-13-2007, 09:41 PM   #6 (permalink)
"THE RED ONE"'s Avatar
Member Number: 48694
Is there a easy way of doing this?
"THE RED ONE" is offline   Reply With Quote
Old 06-14-2007, 03:06 AM   #7 (permalink)
Overcome's Avatar
Trader Rating: (20)
Power tools, a lift, and experience will make it easier.
Old 06-14-2007, 03:19 AM   #8 (permalink)
rolla4now's Avatar
Member Number: 2195
Trader Rating: (19)
paying someone 50-100 bux to do it! lol I honestly dont think I will ever do it again... unless u baught me a 12er of coronas!
rolla4now is offline   Reply With Quote
Old 06-14-2007, 03:38 AM   #9 (permalink)
zx2srt's Avatar
Member Number: 43315
I payed some poor sap at a local exhaust shop to do it. Took him 4-5 hours and he tried charging me 70 bux. I felt real bad cause I saw him really struggling to get it right. (he didn't know what he was in for I don't think) so I gave hime $175. best money I ever spent.
"Line up and race or shut your face"
Stage 2
Port&polished,ceramic coated E1 Turbo
Port&polish,ceramic coated "mamoth" exhaust manifold
Port&polish ITM,TB,Spacer
Forward Motion Waste gate @19 psi
BFMIC & Full hard pipes
3" Perrin Catless Turbo Back
3" 02 Housing
FULL BOLT ON
zx2srt is offline   Reply With Quote
Old 06-14-2007, 04:33 AM   #10 (permalink)
qwiksilvertrav's Avatar
Member Number: 360
It's really not that bad after you've done if a few times! I've done the O2 housing on my car about...4 times. lol The first novice install cost me 100 bucks at my buddies shop...I didn't complain.
The only PITA is the bottom heat shield which was thrown in the garbage the first time I did it. After that it's a piece of cake. The shield is the only thing that really gets in the way and is a pain to take out. No problems after no bottom heat shield after 25k miles.
If you have a S3 O2 housing it's a different story, you have to undo the exhaust brace to get to the last bolt and thats another PITA. If you get S3 it gets worse basically.
BTW what O2 housing did you get? A random one off of ebay sounds a bit iffy. Make sure it has the exhaust mani support and stuff...or you may be shopping for a new head cyl in the future.
DCR Stage 3 w/ TT's
Form & Function EM Port + Cer Coat
AGP DFFMIC
AGP S3 wga
DCR Intake manifold
DCR TB
ED hardpipes
Greddy Type RS BOV
B&B's TB 3' Exhaust no cat
Maxxfabb S3 O2 housing Cer coat
Psi Fi Intake
Perrin STS w/ BB's
Prothane MM inserts
AEM Uego Wideband
Interceptor Scan gauge
Drag DR2 Gunmetal 18's
Blitz Fatt-3 TT
Phillips Ultinon 6k HID's
Eibach Springs
More!
www.mnsrt4.com
qwiksilvertrav is offline   Reply With Quote
Old 06-14-2007, 10:39 AM   #11 (permalink)
srt4mamae's Avatar
Member Number: 41590
omg 6 hours dang bro thats why i payed for mine it took only 2hrs but pretty expensive lol .
srt4mamae is offline   Reply With Quote
Old 06-14-2007, 04:17 PM   #12 (permalink)
sactown04's Avatar
Member Number: 51855
It also took me about six hrs the first time.
sactown04 is offline   Reply With Quote
Old 06-14-2007, 04:20 PM   #13 (permalink)
Member Number: 53751
takes about an hr for me. doing most of the work from up top simplifies life.
christian! is offline   Reply With Quote
Old 06-14-2007, 06:27 PM   #14 (permalink)
Garrett@FTP-Racing's Avatar
Member Number: 37401
Trader Rating: (57)
It took me 12 hours to do the last one i did...........one of the nuts from the manifold decided to take half the stud with it so it ended up basically being a turbo/mani swap(not litterally). I tried everything you could think of to take the stud out without taking the manifold out and it wouldn't budge. I even welded a nut on the end of it and the stud just broke of closer to the mani. Once it was out i had to machine the rest of the bolt out and make a new stud for it. I ported the turbo while it was out also. Then worst part about the whole ordeal was the maxfabb o2 housing that we were putting in, one of the flanges on it was welded crooked so the downpipe wouldn't line up with the rest of the exhaust so we ended up putting the stock o2 housing back in. What a nightmare that was..........
Garrett@FTP-Racing is offline   Reply With Quote
Old 06-14-2007, 06:29 PM   #15 (permalink)
It Is The Polished One , And Yes It Had The Mount For The Lower Bracket. Your All Right , With Out A Lower Heat Shield It Can Be Done I Alot Less Time... It Was Worth It Though
