Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 03-03-2006, 06:37 PM   #1 (permalink)
godfather's Avatar
Member Number: 24924
Trader Rating: (12)
Default How much POWER to the Ground?
My car is going to be on a dyno on friday 3/10, with my new engine. I wanted to know how much you guys thought the car would put down.
All porting work,Crower cams and valvetrain and clutch was done by Fully Built motorsports (Josh)
Mods:
  • Crower camshafts
  • Crower valvetrain
  • stock ported and polished head
  • stock ported and polished turbo
  • stock ported and polished intake manifold
  • stock ported and polished exhaust manifold
  • stock ported and polished o2 housing
  • stock ported and polished throttle body and spacer
  • three inch catless downpipe with e-cutout
  • AEM shortram intake
  • MSD wires
  • NGK colder plugs
  • AGP wga
  • Hot and Cold side hardpipes
  • Quickwhips large fmic
  • turboxs boost controller
  • ACT clutch
  • turboxs bov
Mods:
JE pistons 8:5:1,Eagle rods,Atp GT35 kit,Custom 4" CAI,AGP returnline, Perrin rail,walboro 255,Rc 650's,turboxs b/c,stg1,SAFCII,Devils A/I,MSD wires,Turbonetics upp & bov,JMB HS, Agp charge pipe,iceman 60mm tb,Avid MM,3" Thermal TBE,QW FMIC,TWM sts,ACT stg4 clutch and flywheel,Crower cams & Valvetrain,Fidanza gears. FBM PORTED-stock-intake manifold and head. 412 whp 419 tq
godfather is offline   Reply With Quote
Old 03-03-2006, 06:40 PM   #2 (permalink)
SRToc Member
turbonewb's Avatar
Member Number: 21179
I'll say...little over 300 at the wheel.
turbonewb is offline   Reply With Quote
Old 03-03-2006, 06:48 PM   #3 (permalink)
boostking's Avatar
Member Number: 25195
1000fwhp easy....
on a serious note, i'd say over 300whp easy, prolly 330whp or so untuned...seems like alot of porting which will help flow and over all power...your descriptions are kinda vague though so maybe that turbo and shit is upgraded from stock instead of a ported stock part
boostking is offline   Reply With Quote
Old 03-03-2006, 07:11 PM   #4 (permalink)
godfather's Avatar
Trader Rating: (12)
Quote: Originally Posted by boostking
1000fwhp easy....
Sorry everything that was ported was stock.
Old 03-03-2006, 08:01 PM   #5 (permalink)
Daryl's Avatar
Member Number: 30117
296 to the wheels
Daryl is offline   Reply With Quote
Old 03-03-2006, 10:28 PM   #6 (permalink)
Phoenyx's Avatar
Member Number: 421
I hope I run across you someday..
We'll see about putting that power to the test..
-M
EVO VIII: 351awhp/354awtq on 91oct @ 25psi spike down to 21psi
Phoenyx is offline   Reply With Quote
Old 03-03-2006, 10:38 PM   #7 (permalink)
Member Number: 26501
330-350 easy!!!!!!!
JT
SRTPIMP is offline   Reply With Quote
Old 03-04-2006, 01:36 PM   #8 (permalink)
BACARDI_DWB's Avatar
Member Number: 20780
Trader Rating: (18)
depending of fuel and what type of management.. and what kinda of clutch do you have cause hopefully you can put all that power to the ground. what kind of intercooler? water injection? pretty much if you have a fuel setup like s2's and some type of control on it then i can easily see you in the 300-320's but if no then i would suspect 280-290's and that is running lean on the stock injectors. just my suspicion
not enough info. to make a good judgement.
also what kind of dyno are you jumping on.... good luck post up the results!!!!
SRT Sold
BACARDI_DWB is offline   Reply With Quote
Old 03-06-2006, 11:07 AM   #9 (permalink)
godfather's Avatar
Trader Rating: (12)
Bump added what fmic i have and new clutch.
Old 03-06-2006, 11:23 AM   #10 (permalink)
lunchbox660's Avatar
Member Number: 10098
Trader Rating: (31)
with that much airflow, your car is gonna run alot leaner than it would stock on the sotck fuel system. sure it iwll make more power, but if you dont have the fuel to fully utilize the airflow you are getting, you wont see the full potential. add some fuel enrichment and management to it and you will be able to get well over 300 im sure.
lunchbox660 is offline   Reply With Quote
Old 03-06-2006, 12:34 PM   #11 (permalink)
Trader Rating: (18)
i still say that without fuel you are going to find it hard to reach 300hp (safely) you need more fuel and a way to control it to get a reliable 300hp.. i would much rather be sitting at 290 with 11.1afr than sitting on the edge 315hp and 12.5-12.9afr. but that is just me..
Old 03-06-2006, 10:31 PM   #12 (permalink)
Member Number: 26920
About 330whp i would say
JohnyNFS is offline   Reply With Quote
Page generated in 0.20029 seconds with 13 queries
