Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 3 > California Forums
Old 07-01-2008, 10:17 PM   #1 (permalink)
JoHnNysSRT4's Avatar
Member Number: 34468
Default help with timing on car
wass up.. I'm looking for a shop or some one that has worked on srts? I just need the timing set back to stock. I live in LA so please let me know. Thanks every one..
JoHnNysSRT4 is offline   Reply With Quote
Old 07-01-2008, 10:37 PM   #2 (permalink)
Member Number: 40768
pm'd you.
bizman69 is offline   Reply With Quote
Old 07-02-2008, 01:24 AM   #3 (permalink)
Member Number: 25021
There is no distributor... Which timing are you speaking of? Cam timing? Ignition timing (done through the PCM)?
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Old 07-02-2008, 12:55 PM   #4 (permalink)
foxracing12002's Avatar
Member Number: 45389
Trader Rating: (20)
^^what he said.
its not a old chevy man, unless you have a sct or a piggyback you dont really "adjust" ignition timing on these cars. cams are a diff story. did it jump a tooth?
Ruthless.
TRACTION PWNS ME!!
ANTI-SWEETS CLUB MEMBER # 2
foxracing12002 is offline   Reply With Quote
Old 07-05-2008, 01:16 AM   #5 (permalink)
cam timing..because my car idles funny and the vaccum gauge on the stock boost gauge keeps moving up and down.and also my car sounds like if it has cams and it has to stock ones..it sounds like if it jumped a tooth..
Old 07-05-2008, 01:29 AM   #6 (permalink)
Roq99's Avatar
Member Number: 45983
idles funny like how? maybe its your tps sensor or there is a leak in the pcv?
Roq99 is offline   Reply With Quote
Old 07-05-2008, 03:47 PM   #7 (permalink)
well my car starts to shake.. And most of the time the rpm would drop below 1 and the car sounds like if it wants to turn off, it sounds mean.. And also on the boost gauge on the left side the vaccum needle is jumping up and down like on top of 20 vaccum .. Like two lines on top of 20...
Old 07-05-2008, 04:29 PM   #8 (permalink)
Member Number: 41700
usualy cam timing will show low vac.. sounds like sticky valve or somthing of that nature if its jumping around
Old 07-07-2008, 03:42 PM   #9 (permalink)
oh alright..well any one knows where i could go get it fixed besides the dealer? or any one knows how much they charge only to fix car timing?
Old 07-07-2008, 03:44 PM   #10 (permalink)
Buy/Sell Moderator
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (131)
this could be a list of things, not just cam timing ...
-vac leak
-tps
-tps wires (very common)
3 simple things to check, then go from there
11.9 @ 126
Page generated in 0.15966 seconds with 11 queries
