Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 06-04-2008, 10:45 PM   #1 (permalink)
master_1011's Avatar
Member Number: 3396
Trader Rating: (18)
Default Help me out here...
My car randomly has the symptoms of a bad TPS....the weird idle, revving to 3K or more on it's own, rough idle, "cruise control" when I let off the gas.
Problem is, I have a BRAND NEW TPS in there. AND the re-wire is done.
On top of that, it randomly decides to idle at 10-11 AFR's....Cruises at 12 AFR's...And I have NO tuning device what-so-ever. No SAFC, Mapclamp...nothing.
I have a brand new upstream O2 to combat this issue....but it didn't help.
For both problems, there is no certain conditions to provoke them. They are both random and intermittent...although the TPS symptoms are getting more frequent everyday...
Soooooo....any ideas?
First SRT-4 sold on Guam
master_1011 is offline   Reply With Quote
Old 06-04-2008, 10:57 PM   #2 (permalink)
Falbz's Avatar
Member Number: 22294
Trader Rating: (58)
Intake manifold gasket................i had the same tps issue for awhile. Replaced my wiring, resealed my Throttle body/spacer and turns out it was the intake manifold gasket.
Could also try cleaning your IAC sensor on your TB
Good luck
To make a purchase please go to http://www.pt-performance.com/
Falbz is offline   Reply With Quote
Old 06-04-2008, 11:09 PM   #3 (permalink)
Member Number: 3396
Trader Rating: (18)
Could also try cleaning your IAC sensor on your TB<---Did that too...
Good luck
Thanks. I'll check my intake gasket.....
Old 06-04-2008, 11:21 PM   #4 (permalink)
Orange Blast OC's Avatar
Member Number: 21478
Trader Rating: (32)
Check the t/b and intake mani for vac leaks. I had the same problem with the first ported t/b that I installed. It had a leak in the throttle plate because the fucker made it wrong.
'05 SRT-4 BACK TO STOCK!!
Orange Blast OC is offline   Reply With Quote
Old 06-04-2008, 11:37 PM   #5 (permalink)
Falbz's Avatar
Trader Rating: (58)
^^^FBM by any chance???
Old 06-04-2008, 11:58 PM   #6 (permalink)
Trader Rating: (32)
You're correct! Nice guess.
Old 06-05-2008, 12:22 AM   #7 (permalink)
Falbz's Avatar
Trader Rating: (58)
Had an issue with mine too. Not leaking problem but could have caused some damage to my car. Ended up tossing it and going with a lorenzo. No problems since
Old 06-05-2008, 12:42 AM   #8 (permalink)
Member Number: 3396
Trader Rating: (18)
I have the PTP 55mm TB on there. I'm sure it's fine.
Who (local) has a leak tester so I can figure this out??
Old 06-05-2008, 11:38 AM   #9 (permalink)
PTPerformance Vendor, Cali PIMP Mod!!!
mole''s Avatar
Member Number: 17477
Trader Rating: (179)
i have one somewhere............
or i will just make a new one.......
PTperformance PTP's Cali CREW Mole'
100% BONE STOCK.
Old 06-05-2008, 07:37 PM   #10 (permalink)
Member Number: 3396
Trader Rating: (18)
I'll hit you up soon....
Old 06-11-2008, 03:09 AM   #11 (permalink)
Member Number: 3396
Trader Rating: (18)
Mole', you have a tester found/made yet??
This is really getting on my nerves.....
Old 06-11-2008, 11:43 AM   #12 (permalink)
El-supa's Avatar
Member Number: 45462
i got the tester in my car
hit me up later u know where i work
i take of work at around 5 30 lmk
100KB file size limit.
El-supa is online now   Reply With Quote
Old 06-11-2008, 08:23 PM   #13 (permalink)
Member Number: 3396
Trader Rating: (18)
Well....I didn't see this till now.
What time will you be there tomorrow??
I get off work at around 7 am, so I'm usually back down in Eastlake by 715-730.
Old 06-12-2008, 11:23 AM   #14 (permalink)
El-supa's Avatar
im off at 5 30 pretty much every day exept for fridays (6 pm )
send me a pm i chem my box often
Page generated in 0.21424 seconds with 13 queries
