Quote: Originally Posted by Calcity_SRT4
Ok so to fix this.. P0234 turn boost down. P1188 just check my pink line. P2074 i'm not sure i follow to to do that one. and P1697 my Odometer broke??
How would i fix P 2074 and P 1697?
About the P0234 is it because too much boost not enough fuel? or when i put in the injectors and tune it with enough fuel it will still throw it? pfff...
to get rid of the overboost code either have to get the tip mod for the 05 or get s1 pcm...the s0 pcm dont like to much boost goin to it.. so it is programmed when it sees about 18 or so psi it goes to overboost... it uses the tip sensor(pink and white line) on the soleniods...one of the other ones have to do with over boosting too cant remember which one.. ill look it up...umm about the odometer i have no idea... try to keep your car in reset mode all night... open your fuse box, if you stand on the driver quarter panel theres a 15amp fuse on the bottom left side its the 20 right above that. pull it for 10 secs try that for a night.....see what happens....
GET S1 OR THE TIP MOD... or u will keep gettin codes....
i use to run 19-16 psi no prob on s1...(used s2 waste gate) look at my s1 dyno in sig..
