Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 06-19-2008, 02:15 PM   #1 (permalink)
SUFIZTIC's Avatar
Member Number: 945
Default Help, car Over heating?!?
Well, I have the 180 on there and did a Coolant flush about 2 months ago and my car is over heating with the AC on and off. I pulled into a gas station and coolant spilled all over the bottom of my car. The top engine bay was clean and found no busted hoses, etc. What should I check or replace?
Greg-
SUFIZTIC is offline   Reply With Quote
Old 06-19-2008, 02:17 PM   #2 (permalink)
PTPerformance Vendor, Cali PIMP Mod!!!
mole''s Avatar
Member Number: 17477
Trader Rating: (179)
did you get all of the AIR out of the system when the flush went down? did you check to make sure the RAD CAP was still good and making a good seal???
PTperformance PTP's Cali CREW Mole'
100% BONE STOCK.
Old 06-19-2008, 02:18 PM   #3 (permalink)
shanet's Avatar
Member Number: 54275
Trader Rating: (17)
check your coolant level.
shanet is online now   Reply With Quote
Old 06-19-2008, 02:24 PM   #4 (permalink)
SUFIZTIC's Avatar
Member Number: 945
Default Air
Not sure if the air was let out, how do u do that? RAD Cap might need replacing, I was thinking about that too, I'll buy a new one after work, Thanks
Old 06-19-2008, 02:29 PM   #5 (permalink)
RIP_IT_UP's Avatar
Member Number: 49844
run the car, when it gets hot, turn it off and loosen the cap just enough to let steam out, but use a towel. when all the steam is out, take off the cap and fill it with water and let the car run with heater on full blast
RIP_IT_UP is offline   Reply With Quote
Old 06-19-2008, 02:31 PM   #6 (permalink)
SUFIZTIC's Avatar
Member Number: 945
Thanks alot brotha, I'll do that as soon as I get off work
Old 06-19-2008, 02:31 PM   #7 (permalink)
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (19)
There is also a bleeder valve below the radiator cap, that will let trapped air out of the "closed" side of the thermostat.
Heading for a new track? Just want to improve your times at a track you already run?
Old 06-19-2008, 02:33 PM   #8 (permalink)
SUFIZTIC's Avatar
Member Number: 945
Do I unloosen it with the car on or off?
Old 06-19-2008, 02:39 PM   #9 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
I do it running... If there is air in that spot, the thermostat doesn't get the hot water on it, therefore staying closed and overheating the car!
How does one "un-loosen" something? Isn't that the same as tightening....?
Old 06-19-2008, 02:59 PM   #10 (permalink)
mole''s Avatar
Old 06-19-2008, 04:20 PM   #11 (permalink)
SUFIZTIC's Avatar
Member Number: 945
Ah damn ya got me lol
Old 06-19-2008, 04:23 PM   #12 (permalink)
DJOrtiz's Avatar
Member Number: 17860
Trader Rating: (20)
you could help the procedure by parking in on an incline while bleeding it out... also grab the bottom rad hose and just give it a couple squeezes...
Ghostbuster Crew Member #2
Free DOM!
DJOrtiz is offline   Reply With Quote
Old 06-19-2008, 04:29 PM   #13 (permalink)
Member Number: 40768
Trader Rating: (23)
Funny shit.
bizman69 is offline   Reply With Quote
Old 06-19-2008, 04:40 PM   #14 (permalink)
mole''s Avatar
also what mix of coolant and water you use?
Old 06-19-2008, 04:46 PM   #15 (permalink)
shanet's Avatar
Trader Rating: (17)
id prefer tonic or perrier.
