Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 02-18-2005, 09:00 PM   #1 (permalink)
jamesfoster's Avatar
Member Number: 11809
Trader Rating: (12)
Default F#@$%ng Third Bolt!!!
so I got my mopar bov today, and for some reason decided that starting the install at around 5pm is a good idea...
The stupid thing is on, but I can't get the third bolt tightened, At all. I guess I need to bend that oil line or something? I also need a ratcheting box end wrench, which I don't have. Oh and it's freezing outside, and it started to rain.
And I absolutley HAVE to finish this tonight somehow because I'm going to CBD tomorrow. It better stop raining...
2004 SRT-4 DD
Race car: 1990 Mitsubishi Eclipse GSX, caged, Built 2.3 Stroker, TRE Trans, JMF Intake Manifold, DSMlink, Turbonetics RS60T, DNP manifold, Tial 38mm, Slowboy Fmic, Tein SS coilovers, GT35r and 44mm tial not in yet.
Other toys: 2000 F-150, Bagged and Shaved 2000 Chevy Astro, 2007 Kawasaki Ninja ZX-6R, 2000 Kawasaki KX250. Too many toys...
jamesfoster is offline   Reply With Quote
Old 02-18-2005, 09:09 PM   #2 (permalink)
hammer4x's Avatar
Member Number: 14441
Why don't you try taking the front 2 bolts back out...rotate the bov to give you better access to the back bolt...tighten that almost all the way but yet give you enough play to rotate the bov to install the other 2 bolts and then try and tighten the back bolt those last few threads...either that or put it back to stock untill you get what you need to get back there easier with....I don't know if that will help but that's what I would try.
hammer4x is offline   Reply With Quote
Old 02-18-2005, 09:17 PM   #3 (permalink)
GERRY's Avatar
Member Number: 3996
Trader Rating: (23)
I was able to tweak that oil line ever so slightly. Helped alot. Be careful not to kink it thiough!! Good luck!
'03 Red 17x7.5 Alessio Turbos (hyperblack) Progress springs, s2 w/toys, MaxxFab 3" o2 housing,DP, and cat, Mopar/Borla catback,Mopar BOV, Mopar STS, Gerry's Custom shift knob and door sills, JMB ultimate 3" CAI 12.853@105.44
GERRY is offline   Reply With Quote
Old 02-18-2005, 09:44 PM   #4 (permalink)
BigPowerfulMachine's Avatar
Member Number: 3512
Why don't you take the oil line off?? That's what I did, just make sure you don't lose the washer underneath the fitting, cuz then you're reeeally screwed.
BigPowerfulMachine is offline   Reply With Quote
Old 02-18-2005, 09:45 PM   #5 (permalink)
CoreyR's Avatar
Member Number: 7068
you must have big hands cause its not that hard to do. that or the cold is makin gyou way impatient. just take your time and dont rush it. you gotta find just the right position to put your hand it and be able to turn the wrench.
WWW.CCFABONLINE.COM
03 SRT-4 SOLD
97 Neon SOLD
91 Civic Si D16Z6 Turbo
89 CRX B18C Turbo
02 CBR 954RR
CoreyR is offline   Reply With Quote
Old 02-18-2005, 09:46 PM   #6 (permalink)
CoreyR's Avatar
Member Number: 7068
cause your supposed to replace that washer everytime you take it off cause it can leak. they are 1 time use.
Old 02-18-2005, 09:47 PM   #7 (permalink)
Trader Rating: (12)
DAMN that was a pain in the ass. I got it all done though, I just bent the oil line a tiny bit, just enough to be able to move my little 10 mill wrench in there.
haha, 2 and a half hours later, with one 10 mill wrench and one 10 mill socket forever lost in my engine compartment, my mopar bov is done.
ok time to go play...
Old 02-18-2005, 09:50 PM   #8 (permalink)
Farani's Avatar
Member Number: 8429
Really? I took mine off and put it back on and I've had 0 problems.
Farani is offline   Reply With Quote
Old 02-18-2005, 09:51 PM   #9 (permalink)
NogaBlitz's Avatar
Member Number: 6194
Trader Rating: (26)
get a 10mm ratcheting wrench. I did it once without and it was a pain. Second time I had it done in 20 minutes at most. I found that putting the bottom right bolt in first, then the bottom left and tightening it all the way, then the top bolt is the easiest. Ratcheting wrenches rock.
NogaBlitz is offline   Reply With Quote
Old 02-18-2005, 10:01 PM   #10 (permalink)
Member Number: 3512
Blah blah, lots of things are considered one time use. Cylinder head bolts, caliper banjo bolt washers, various types of gaskets... Tons of shit. It is reccomended, and it's a good idea to replace them, but you don't really have to in most cases.
Old 02-18-2005, 10:04 PM   #11 (permalink)
Member Number: 3512
Puh-leaze! It was -45 last month in my area, and people still work on their cars outside in the snow and ice. Sorry, I have no sympathy for you.
Old 02-18-2005, 11:55 PM   #12 (permalink)
SRToc Member
sphinx's Avatar
Member Number: 13267
Seriously dude...Im Canadian....but living down here....you get ..well...spoiled..
Disclaimer: All DaimlerChrysler employees: This Post or any other post by the screen name SphinX no way constitutes an admission of tampering, modification, usage, or alteration of my SRT-4 in such a fashion as to void, deny or otherwise refuse service on any service contracts or warrantees. Any posts made by SphinX are merely fictional. SRToc #624 Member of the .2 Mach Club
sphinx is offline   Reply With Quote
Old 02-19-2005, 02:38 AM   #13 (permalink)
Trader Rating: (12)
hahaha man that thing is fun
Old 02-19-2005, 02:45 AM   #14 (permalink)
melmsrt4's Avatar
Member Number: 9605
Trader Rating: (13)
Get to bed, I don't want you to be late. See ya tomorrow (or should I say later on this morning). The rain flooded my horn. Now it sound really sick. I guess that's what BOVs are for.
Soon to be on the block
melmsrt4 is offline   Reply With Quote
Page generated in 0.21106 seconds with 13 queries
