Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 12-27-2005, 08:22 PM   #1 (permalink)
SRToc Member
mihimahi's Avatar
Member Number: 2948
Default Error code 0128
I have got this error code: 0128 .. which is for: "Thermostat Rationality"..
What the heck is that suppossed to mean?
We took a new (srt4-oem) thermostat and drilled a few 3/16" holes in it, so it would act(aproximately) like a 185 thermostat.
mihimahi is offline   Reply With Quote
Old 12-27-2005, 10:19 PM   #2 (permalink)
westup's Avatar
Member Number: 32844
you answered you own question.
Fight on for the yo movement!ONE BAD PANDA
05,S2notoys,mpshiftknob,SLOW4DR STS,teinbasic,17/7work emtions/azenis,agp mm,thermal ex,mopar cai,pt performance checkvalve,dcr tbody
westup is offline   Reply With Quote
Old 12-27-2005, 11:19 PM   #3 (permalink)
SRToc Member
mihimahi's Avatar
Member Number: 2948
Are you referring to the drilling of the holes in the thermostat?
If so, does that imply that anyone using a 185 or say a 165 thermostat, gets this code?
Or is it because of the drilled holes, that the thermostat does not work properly?
Or are you just being facetious?
Old 12-28-2005, 11:24 PM   #4 (permalink)
underSRTarmor's Avatar
Member Number: 32888
Trader Rating: (66)
:BUMP
well did u ever figure it out....?
bc i was thinkin about doing that same thing
i dont know if u remember me... but im the guy that u and your wife asked to ride in your car that day when u went get it allined...(sp) we u went pick it up from st motorsports....
Dodge Cummins 5.9L 325 hp 610 tq
Chevy duraless 6.6L 300 hp 520 tq
Ford PowerJoke 7.3L 300 hp 570 tq
underSRTarmor is offline   Reply With Quote
Old 12-29-2005, 12:19 AM   #5 (permalink)
westup's Avatar
leave the tstat stock.its best that way..search.
Old 12-29-2005, 12:59 AM   #6 (permalink)
Member Number: 5369
Did a quick check in the factory service manual and couldn't find that specific code. My guess is that the holes you drilled are causing it to not open up properly and the PCM is detecting this via the coolant temp sensor. Adding a few holes that big will not cause it to act like a 180/160 thermostat, but it can interfere with proper operation.
On my older Chrysler 16V 2.2L Turbo III engines I would drill one small hole, but that was just to maintain a little steadier temperature rise. Since those heads had a tendency to crack, thermal shocking didn't go together very well with a $4k+ bare casting. The small hole also allowed any air still trapped after bleeding to pass. This isn't a big problem on the SRT-4, so one small hole might be fine, but I'd just run a real 180° thermostat if that's what you're trying to simulate.
Old 12-29-2005, 01:09 AM   #7 (permalink)
Member Number: 7088
Trader Rating: (88)
u fd up ur plan.. get a another stocker and try agane
adrenalineaiax is offline   Reply With Quote
Old 12-29-2005, 05:47 PM   #8 (permalink)
Frankie's Avatar
Member Number: 7872
Oh Pop... are you ever gonna learn? Hope y'all had a Merry Christmas. I just may pop in this weekend. What are you guys up to?
BRING MAGGIE BACK!!!!
Frankie is offline   Reply With Quote
Old 12-29-2005, 06:37 PM   #9 (permalink)
SRToc Member
mihimahi's Avatar
Member Number: 2948
OK, that's it.. you've convinced me to put the stock 195 back in with no holes drilled.
Thank-you very much.
(Hearing from Eric is like hearing from the master )
Mike
Page generated in 0.18851 seconds with 13 queries
