Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
View Poll Results: Does Drastic. pwn norcal
hella yes! i <3 Drastic. so0 much i wana WOM it! 0 0%
duhh. Drastic. > Cali > Texas. 7 29.17%
Drastic. stole my gf. bang bang. 5 20.83%
Drastic. is the #1 stunnas. 12 50.00%
Voters: 24. You may not vote on this poll
Old 04-11-2008, 05:31 PM   #1291 (permalink)
Member Number: 58932
Trader Rating: (23)
ima work out. get oil. oil filter. work on a paper then holla.
what time u need me to come over?
and how far along are u?
Old 04-11-2008, 05:35 PM   #1292 (permalink)
EP3Casas's Avatar
Member Number: 62686
Quote: Originally Posted by DRASTIC. View Post
n1gga im ho0d rich.
if u got sumtin, say sumtin blo00d. i dont fuck like that. this the 925 bay yerea shit. 24/7. on mamas. holla if u tryna front crabbin ass crip
Quote: Originally Posted by 97/4.6w/fangs View Post
wrong dude bro
Casas creampied FTW
i can see him on his knee's open-mouth'd lookin like cookie monster screamin "moar, moar! moar!!!!!!!"
IMA CRIP CUZZ!!! both YALL n1ggas bout to get klacked up!!
Drastic. Best of the Best is wat we strive to be
"my car isnt ricey..its jdm"
it may b slow but it pulled ur mom
EP3Casas is offline   Reply With Quote
Old 04-11-2008, 05:36 PM   #1293 (permalink)
97/4.6w/fangs's Avatar
Member Number: 63121
u totally should just hold off on installin nething till u get all of it, and do it all at once
how much will it all cost you?
xpipes - 150-180 depending on which one I go with
gears (thought u said u wanted em - 150 for the gears 150-300 for install
bare head to port -hoping to find some for $500-800 assembled cause I want the stock 03/04 valves and springs
porting kit - 50
cams - $200-1200 depending on how I choose to do it
tune - 500
id assume all that would make it some serious heat?
maximum of $3130 depending on how exactly I go about it. I'm still researching though
I can get stock B heads for $200 and port them and stick 03/04 valve train in them probably for cheap.
The heads/cams are going to be the most expensive parts
I just had an idea though
B heads so I can roll the stock lower intake manifold and rock a ported upper intake or just port my own. That will save me TONS of $$$$. Should be able to do everything for about $1500 if I go that route and get 50+to the wheels out of it
.Drastic.
97/4.6w/fangs is offline   Reply With Quote
Old 04-11-2008, 05:37 PM   #1294 (permalink)
D-ROK's Avatar
Member Number: 50159
Its all good playa. School before play
Whenever you are done with your paper.
Bout to put the mani on.
Not sure on wich lines I need to plug and which ones to use. Trying to fugure that out right now, before I out the mani on. I have an idea just need to take a closer look
Drastic. & Assoc.
D-ROK is offline   Reply With Quote
Old 04-11-2008, 05:38 PM   #1295 (permalink)
Trader Rating: (23)
get crackin at it.
i wana hear the car/cams/nocat
Old 04-11-2008, 05:39 PM   #1296 (permalink)
Member Number: 48372
What are you planning on doing? You staying all motor?
MnM'SRT4 is online now   Reply With Quote
Old 04-11-2008, 05:39 PM   #1297 (permalink)
EP3Casas's Avatar
boost..
Old 04-11-2008, 05:40 PM   #1298 (permalink)
Trader Rating: (23)
cap the coolant return at the block w/ that lil allen stubby
cap the oil feed near the valve cover
run the oil feed line from the turbo down to the new feed supplied. just follow the oil feed down to the block. remove it, and install the new 1.
oil return...i think just pull off, install that rubber hose. clamp tite.
thats it.
Old 04-11-2008, 05:40 PM   #1299 (permalink)
get crackin at it.
if I roll with stockish cams it won't lope worth dick but I still think it will sound badass. Something about a DOHC V8 makes my weiner move a little
Old 04-11-2008, 05:41 PM   #1300 (permalink)
for now. If I run that setup up there it will be prime for boost after the fact. But that setup should put me running mid 12s EASILY and low 12s with some weight reduction
Old 04-11-2008, 05:42 PM   #1301 (permalink)
Trader Rating: (23)
and assuming the intake mani's are alum...we could port those EASILY.
u have an extra beater/daily driver?
or u gunna get intake manifold cores as well?
the head will take like 1-2weeks (figure only 1-2 runners each night).
an intake mani in about 2-3days
etc.
Old 04-11-2008, 05:42 PM   #1302 (permalink)
...So pretty much your building the motor, changing the gears, adding cams and exhaust?
Old 04-11-2008, 05:43 PM   #1303 (permalink)
Trader Rating: (23)
+1 for BIG cams
Old 04-11-2008, 05:43 PM   #1304 (permalink)
S2R0T044's Avatar
Member Number: 5620
I am SO effing tired...holy crap.
Josh - 2005 Black SRT-4
blazinsrt built.
Vendors: Exhaust: Maxxfab, STS: Maddog, General Parts: S&P, Shift Ball: Pizza Boy
Quote: Originally Posted by castrol View Post
I just traced your IP with my magic IP/address trace program. The cops should be busting
in on you at any minute. Hope you're not dead yet...
S2R0T044 is offline   Reply With Quote
Old 04-11-2008, 05:45 PM   #1305 (permalink)
D-ROK's Avatar
thats it.
hmmm k
