Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 3 > California Forums
View Poll Results: Does Drastic. pwn norcal
hella yes! i <3 Drastic. so0 much i wana WOM it! 0 0%
duhh. Drastic. > Cali > Texas. 7 31.82%
Drastic. stole my gf. bang bang. 5 22.73%
Drastic. is the #1 stunnas. 10 45.45%
Voters: 22. You may not vote on this poll
Closed Thread
Old 04-16-2008, 07:38 PM   #1606 (permalink)
Member Number: 44229
i'm assuming tracy
Drastic FTMFW!
mikealicious is offline
Old 04-16-2008, 07:38 PM   #1607 (permalink)
Member Number: 58932
i think kinders opened up near that walmart/BOA area...
DRASTIC. is offline
Old 04-16-2008, 07:42 PM   #1608 (permalink)
what? and there's a sticker place over there? maybe he's talkin about the one in pleasanton. wth is a kinders anyway?
Old 04-16-2008, 07:46 PM   #1609 (permalink)
i duno man! just sayin, a kinders opened up that way...
kinders = a bomb ass semi-fast burger/steak/chicken burger place.
if you ever had armadillo willy's its like that. basically a meat deli, go tell em what you want, and they grill you a sandwich.
DRASTIC. is offline
Old 04-16-2008, 07:53 PM   #1610 (permalink)
for sure. sounds pretty good. well im off to kyles(sti) casa. be back later.
Old 04-16-2008, 07:54 PM   #1611 (permalink)
D-ROK's Avatar
Member Number: 50159
sup mayne?! how's the car runnin?
Good for only 9psi.
Drastic. & Assoc.
D-ROK is offline
Old 04-16-2008, 07:56 PM   #1612 (permalink)
did you check w/ soapy water...
maybe the tolerances on the compressor are off? if the fins arent w/in spec from the housing, itll do that as well...
im out of ideas aside from what i sent oyu.
DRASTIC. is offline
Old 04-16-2008, 07:56 PM   #1613 (permalink)
D-ROK's Avatar
Checked wg, ex. mani, intake mani, nuthin. Still at 9psi
D-ROK is offline
Old 04-16-2008, 07:57 PM   #1614 (permalink)
ouch.
bunk turbo?
that wg spring is DEFINATELY a 15psi (i ordered it as a 15)
i used it straight up when i 1st installed it on my sst, and it spiked/held 15psi, and matt can vouch.
DRASTIC. is offline
Old 04-16-2008, 07:58 PM   #1615 (permalink)
D-ROK's Avatar
hmmm... i dont know anything about that.
It will spike well over 20 if I take the line off the wg.
D-ROK is offline
Old 04-16-2008, 07:59 PM   #1616 (permalink)
D-ROK's Avatar
ouch.
bunk turbo?
hmmm...
why does it spike with no line on the wg?
D-ROK is offline
Old 04-16-2008, 08:02 PM   #1617 (permalink)
hmmm...
no boost source.
same instance as if you go pull the WG line off a stock wga. stock wga has a 4lb spring.
pull the line off and its going to spike way past 25psi.
w/ no boost source being sent to it, there is no boost to open the WG diaphram to bleed the boost off...so it just builds up in your manifold and makes you spike like crazy.
at this point only 2 things i can think of if you arent leaking is possible WG or a bad rebuild maybe
and you said the WG isnt leaking out of the vband...?
DRASTIC. is offline
Old 04-16-2008, 08:06 PM   #1618 (permalink)
D-ROK's Avatar
no boost source.
ahhh I see. Im waiting for the car to cool down and ima do another boost leak test. Hopefully something will pop up. I also noticed some shaft play. Side to side and in and out. It seems to be a bit excesive to me. I will have to have you check it out.
D-ROK is offline
Old 04-16-2008, 08:12 PM   #1619 (permalink)
side to side is absolutely normal.
in and out = bad rebuild....
just from you telling me its in and out tells me thats the problem.
if you did a boost leak check, and checked w/ soapy water and didnt find nething, i got a feeling thats it.
DRASTIC. is offline
Old 04-16-2008, 08:40 PM   #1620 (permalink)
D-ROK's Avatar
there is deff more side to side movement than in and out. In and out is only a lil to where it barely clicks.
D-ROK is offline
Closed Thread
