Quote: Originally Posted by
mark2249
what BS features, let mek now so I can turn it off also in case I run into caca when putting mine in.
wait,...did you at least get boost per gear working????
yep, boost by gear is working GREAT
keep feedback under or at 5.
having too much feedback makes the AVCR OVER adjust and causes mad surge/over spikes.
turn off auto-learn.
for the time being until you get it as close as you can be, run STATIC duty cycle.
i did a full write up just not too long ago in my other thread. take the numbers i used for gear-judge and plug them in...
110
65
45
32
25
those should work perfect.. the ones i used were calculated for 7k.
i started w/ my boost i wanted, and started w/ 50% Duty Cycle. go in 4-5% incriments, since for me...jumping from 58 to 65% gained me 7psi..
