alrighty...so heres the break down tonite.
i told the vette i wasnt going to race because of some ebc issues and i was on pump, so he didnt show.
while at our meet, i called out a procharged stang...he neglected.
went to our spot and only got 1 run...security popo came twice...and the 2nd time he stopped and looked at us so we bounced.
prior to that, D raced geezer.
D-rok: hx40. 25psi. 110oct. full bolt ons. stock head/cams/tb.
Geezer: 23 psi. 47lb s3. HOM. 110. meth i believe. full bolt ons. 62mm tb.
first run: NECK AND NECK. both brake boosted...luckily it helped drok out a bit because spool woulda hurt him.
2nd run: iffy..both werent sure when to go and geezer might've gotten the pull? after both gettin on it, geezer kept pulling.
security showed after and we all bounced. drok went home w/o racing again.
every1 was standing at the gas station. no1 wanted to run. i was pretty pissed since reed drove 40min out to tape the runs on last minute call.
i get jason/geezer to agree to do 1 pull on the freeway from 3rd on his way home. i had 1 exits worth of pull to do my run since that was the last exit for quite a ways.
me: 50trim/.48ar. 20psi. 91PUMP. meth. full bolt ons. cams at 0,0.
Jason: 47lb s3. HOM. 23psi. 100oct. meth.
go on 3honks. no brake boost. DEAD EVEN. shift into 4th, still close then as we neared top of 4th he pulled about 1car total.
jason said he had trouble w/ shifting into 4th...and i believe him. his tranny is 100k+ miles.
it is what it is.
reed has video, and will post when he gets home.
sucks the runs got cut short...but it is, what it is.
hopefully next week, i will get the runs in w/ the SC'd vette, procharged stang, and against jason on race vs. race.
fwiw, jason dyno'd today. 416hp/416tq on race/hom and 23psi. (congrats BTW jason! beautiful dyno)
that will give you an idea of where im at on my 20psi/pump tune.
some changes will be done this week.
a new tune from SCT (right now is 20* rising to 25)...it will now be 22* rising to 28*. also changing my boost controller out.
just the extra timing alone should make me dead even w/ jason pump vs. meth. i will come out full swing on race gas/meth/25psi tho hopefully.
-91PUMPking
