Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > California Forums
Old 01-03-2008, 09:40 AM   #1 (permalink)
Member Number: 35371
Trader Rating: (41)
Default 2 step + meth?
my friend has meth and whats to buy the nde tcs. would this be a good idea to use with the meth? i told him i dont know what would happen while he was boosting at a stop and spraying in meth. i dont want him to blow anything up, does anyone have any input?
mopar4srt is offline   Reply With Quote
Old 01-03-2008, 10:16 AM   #2 (permalink)
Member Number: 58932
Trader Rating: (23)
DONT hold the 2step for long w/ meth.
if your meth's engaugement point is say, 11psi and you hold your 2step long enough to build 11lb. you are looking for trouble.
and if you hold it long enough to surpass your meth's engaugement point, then you're doing it for the sounds, and not for the purpose.
Old 01-03-2008, 09:20 PM   #3 (permalink)
Garrett@FTP-Racing's Avatar
Member Number: 37401
Trader Rating: (57)
Or you could always run a arming switch for the meth inside the car, and activate it after your launch.
Garrett@FTP-Racing is offline   Reply With Quote
Old 01-04-2008, 12:59 AM   #4 (permalink)
nutz's Avatar
Member Number: 41700
if its a progresive meth kit he should have no problems, you wont build much boost on the 2 step so you should have no problems, if your concerned you can wire up a dual relay to the clutch switch and a momentary switch to turn off the meth untill the clutch is released alot of people use a similar system with a trans brake for n2o
Old 01-04-2008, 01:06 AM   #5 (permalink)
Member Number: 11681
Trader Rating: (96)
Just make sure your w/i comes on later then the amount of boost built on the 2 step. 90% of the people on here arent going to actually hook up boosting 3-5 psi much less the amount you have your w/i coming on at. If your w/i comes on via TPS switch ya better do what garrett said
Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
Page generated in 0.16234 seconds with 13 queries
