Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > AEM
Old 01-27-2004, 11:14 AM   #31 (permalink)
cali's Avatar
Member Number: 159
Your graph makes no sense to me. Is that time on the X axis?
How is it that the speed shows 180? Also could you clarify the locations of the probes.....esp the IAT one....what are you measuring there? Also, BOOST settings should be included in that chart. (depending on what you call IAT)
someone is watching me
cali is offline
Old 01-27-2004, 11:46 AM   #32 (permalink)
AEMTech's Avatar
Member Number: 514
You can consider the x-axis time dependant.
The secondary y-axis shows speed, which maxed out around 80mph. All other values for temperature use the primary (left) y-axis.
The Intake Air Temperature (IAT) is measured at the OBDII port from inside the car.
The "Near IAT" on the graph is the probe location of the temperature sensor. This sensor was located right by the sensor located nearest the battery. Pre-turbo.
Boost is unnecessary for this type of testing.
Advanced Engine Management Inc.
AEMTech is offline
Old 01-27-2004, 12:29 PM   #33 (permalink)
cali's Avatar
Member Number: 159
One more thing, is there a mistake on the # on the secondary Y axis?
The scale is different from the primary so you follow the temps with the speed out of the way.
cali is offline
Old 01-27-2004, 12:35 PM   #34 (permalink)
AEMTech's Avatar
Member Number: 514
ok, i must still be missing something here. Going off what you said and the pdf, ambient temp is ~~65 degrees. Your IAT moves between 70-77 degrees.
Are you saying this car never went into boost?
I have done tremendous monitoring of the IAT ( the one in the charge pipe) and with ~65 outside, under boost that will register well over 80 degrees on the highway, even low 90s.
You are correct in saying boost doesnt matter(turbo car) so the charge pipe will get hot either way,but the underhood temps rise drastically with a 3rd gear pull
Trust me that car was in boost. Here is the Report from the log.
View / Trip Log / Record Trip 11
Vehicle : Dodge SRT-4
CarChip : J-2949-A
Start Time : 1/21/2004 10:32 AM
End Time : 1/21/2004 10:44 AM
Duration : 0:11:40
Idle : 0:02:13
0 to 45 MPH : 0:05:54
45 to 60 MPH : 0:00:59
60 to 75 MPH : 0:02:27
Over 75 MPH : 0:00:04
Distance : 6.3 Miles
Average Speed : 32 MPH
Maximum Speed : 80 MPH
Hard Brakes : 2 (Between 0.28 G and 0.48 G)
Extreme Brakes : 0 (Over 0.48 G)
Hard Accelerations : 6 (Between 0.28 G and 0.48 G)
Extreme Accelerations : 0 (Over 0.48 G)
Parameters
Parameter 1 : Vehicle Speed Every 5 Seconds
Parameter 2 : Intake Air Temperature Every 5 Seconds
Parameter 3 : Air Flow Rate Every 5 Seconds (Not Supported By Vehicle)
Parameter 4 : Timing Advance Every 5 Seconds
Parameter 5 : Fuel System Status Every 5 Seconds
Comments :
AEMTech is offline
Old 01-27-2004, 12:56 PM   #35 (permalink)
cali's Avatar
Member Number: 159
CarChip...as in CarChip E/X?
If so I think I now understand the #'s
cali is offline
Old 01-27-2004, 12:59 PM   #36 (permalink)
AEMTech's Avatar
Member Number: 514
I think so, I used it to monitor the IAT only. The rest were therm. couples.
AEMTech is offline
Old 01-27-2004, 01:19 PM   #37 (permalink)
alterego's Avatar
Member Number: 828
Trader Rating: (33)
Conversion kit? WOW!
Nice to see GREAT minds think a like.
You guys should make a cover that mounts under the positive terminal.
I have been in some bad rain and have put over 5k miles on my SRT with the AEM SRI converted to a CAI with no issues. I love my AEM!
SRTOC MEMBER # 105 - MY SRT-4
alterego is offline
Old 01-27-2004, 06:41 PM   #38 (permalink)
Exhaust Depot's Avatar
Member Number: 143
Trader Rating: (98)
Quote: Originally Posted by AEMTech
Hasn't been priced yet. You'll get the lower pipe and the splash shield, and a template for cutting the pipe.
Can't be too much
Your capitolising on alteregos mod. He was the first to turn the AEM into a real CAI.
Exhaust Depot is offline
Old 01-28-2004, 09:31 AM   #39 (permalink)
AEMTech's Avatar
Member Number: 514
Sweet, sorry it took so long to come out with the CAS.
AEMTech is offline
Old 01-28-2004, 09:37 AM   #40 (permalink)
AEMTech's Avatar
Member Number: 514
AEM has made this type of conversion before, but has never made it to market. I know a certain other company *cough* Injen *cough* that has been doing it for years. Since neccissity is the mother of invention, I give him his props.
Its just not fair to all the people that already have the SRS and now have modified their SRT-4 even more and aren't able to take advantage of the CAS gains. We have to address that issue as well.
AEMTech is offline
Old 01-28-2004, 10:14 AM   #41 (permalink)
Member Number: 143
Trader Rating: (98)
Its your product so do as you wish, I would. Cant blame you on that one.
Good idea with teh splash plate.
Old 01-29-2004, 01:05 PM   #42 (permalink)
AEMTech's Avatar
Member Number: 514
Looks like the Conversion with the splash shield will run between $115-130.
AEMTech is offline
Old 01-30-2004, 01:47 AM   #43 (permalink)
Less's Avatar
Member Number: 5090
when will it be available?? if there for sale now msg me an ill buy one
Less is offline
Old 01-30-2004, 01:54 AM   #44 (permalink)
topofnewyork's Avatar
Member Number: 1056
yeah me too
TopOfNewYork
NY SRT CREW
topofnewyork is offline
Old 01-31-2004, 11:38 PM   #45 (permalink)
ACRucrazy's Avatar
Member Number: 86
130s pushin it
*2003 SRT-4: 12.5 stock turbo- SOLD
*2002 ACR : Stone White 1 of 36
*2001 ACR : Silver Stripper model
*1997 ACR : 14.2s & 99.6mph NA
*1995 ACR : Celebrity Challenge #11
*1995 ACR : Celebrity Challenge #17
*1995 ACR : Celebrity Challenge #18
*1995 NYG : In the works.. SRT-4 eater
*2001 Dakota: Crap hauler 290k miles
ACRucrazy is offline
