Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > AEM
Old 04-30-2004, 06:51 PM   #16 (permalink)
DoubleB's Avatar
Member Number: 10586
Hey everyone I am also having the same probs. somebody told me to post in this board so I'll just send the link.
http://srtforums.com/forums/showthre...3&page=2&pp=15
DoubleB is offline
Old 05-01-2004, 05:11 PM   #17 (permalink)
KrayZNutz420's Avatar
Member Number: 9965
Yeah, just installed the AEM CAI and having the same prob with it rubbing the hood, the portion of the hood it hits seems to only be an extra part of the cowl ducting, its probly only there for a sound deadening for the ducting, but im not sure, I dented that part lightly with a rubber mallet and put simmilar rubber material that comes with the kit (for the battery terminal area) on both the hood and intake, doesnt leave any marks, and only hits SLIGHTLY when i spin tires or durring that ever-so-dreadfull wheel hop. I work for a local speed shop here in Long Island, NY and called AEM and they say i need to speak with the guy there that designed it, and he has fixed 3 or 4 of these himself, that it was only adjusting issues. Im still waiting for his call back.
Chris is my name, you can call me Junior.
Less Talking, More Racing Please.
"That was a NEON???"
KrayZNutz420 is offline
Old 05-01-2004, 11:57 PM   #18 (permalink)
DoubleB's Avatar
Well, it started to rub again this time it was really bad. I think pretty soon I will have a couple of holes in my CAI pipeing I think I am going to cut out the part of the cowl on the frame of the hood. If this isnt a good idea somebody please say so. Also I think I am going to try and reinstall the CAI. If I can get it to not rub ever again thats great but I will always be mad about the CAI pipe because it looks like sh#t now. Maybe some High temp touch up paint will do the trick or maybe AEM could let me exchange for a new one.
DoubleB is offline
Old 05-02-2004, 12:09 AM   #19 (permalink)
DoubleB's Avatar
how does everybody else feel
DoubleB is offline
Old 05-02-2004, 06:44 AM   #20 (permalink)
SRToc Member
cal_srt_4's Avatar
Member Number: 10368
DoubleB
If you haven't already, go to the following thread. The advice on that thread worked for me.
People w/ AEM CAI, Help
The only thing I have to add is, buy better hose clamps. Mine would come loose and the intake would start rubbing.
I think I have the problem solved. (knock on wood) It's been a couple of days and the intake is not rubbing.
I would still like if AEM could make a shorter rubber connector for the battery tray. I don't like the idea that a wire tie is holding it together.
cal_srt_4 is offline
Old 05-02-2004, 12:22 PM   #21 (permalink)
Forcefed24's Avatar
Member Number: 8437
Hello all and AEM! IT IS NOT JUST AN ADJUSTMENT ISSUE. I am to the point that everyone is entitled to their opinion and on some SRT's it is just an adjustment issue but others it just does not fit period. I find it very interesting that it has been stated there are fitment issues because not all SRT's are the same but when you call you get different information. The first eye opener should have been when many customers complained of the same thing. From the west coast to the east and from I am sure young teenagers to well seasoned adults. I was told that the first batch made had fitment issues but now AEM has fixed that. If that is the case then why is their not a recall. So spending hours too days "trying" to get it to fit is the norm, not in my book.
Forcefed24
04 SRT-4
Forcefed24 is offline
Old 05-04-2004, 01:04 PM   #22 (permalink)
Member Number: 5690
ben/ AEMtech just got off the phone with me. i am taking my car to AEM on friday and we are going to try another CAS on my car and take more pics so that we can see where all the potential problems are and get them fixed. i will post again on this thread after we are done working on it on friday. hope this helps ease everyones mind knowing that he has aknowledged that there may be a problem and if so he is going to fix it.
12.712@108.92 what else matters?
stillslow is offline
Old 05-04-2004, 01:23 PM   #23 (permalink)
AEMTech's Avatar
Member Number: 514
Hello everyone,
As you all know, fitting a 3" pipe in this engine bay is going to be tight, so there is little room for error. Below are two important steps you can take to improve fitment and make sure that the pipes will not rub against the hood.
There is a hard line underneath the upper intake pipe. Rotate the spring clamp so that it is facing down toward the ground. Since all cars are not built the same, that hard line might be higher or lower on different SRT-4's. If your hard line is placed high in the engine compartment, it is possible for that line to push up on the upper intake pipe. If your pipe is close to the hard line, then you will need to lower the hard line no more than 1" for clearance.
Make sure that the upper intake pipe is in deep enough into the rubber elbow at the turbo. This will pull the pipes back away from the hood.
Someone mentioned that there were a bad batch of pipes and that AEM is revising them, but this is false. I have personally checked production pipes against the original and its fixture and found no differences, and we have test fit this system on a few different SRT-4s.
I am however getting another SRT-4 (stillslow) in so that I can provide more pictures of the installation, detailing the close fitment of the system and how to make sure your pipe does not rub on the hood or hard line. I will post these as soon as we get the car in, and will advise everyone of the status. Thank you for bringing this to our attention, and for your support.
Advanced Engine Management Inc.
AEMTech is offline
Old 05-04-2004, 03:14 PM   #24 (permalink)
Roc
Member Number: 9239
Quote: Originally Posted by AEMTech
Hello everyone,
Ok, my problem is the instructions do not allow for proper installation. Have these been revised? Is that what you are going to do after installing it into stillslow's car?
It's all well and good that someone at AEM can install the intake properly. Who cares. If a good number of your customers are having installation issues, then there is a problem, regardless of how well an AEM technician can "force" it into the engine bay.
We all can't take our cars into AEM and have them install it for us.
Roc is offline
Old 05-04-2004, 03:33 PM   #25 (permalink)
MikeCandler's Avatar
Member Number: 5521
Trader Rating: (52)
Thanks for looking into this AEM!!! Some companies would simply say "it fits...too bad"
You will keep my business in the future!! Please let us know how it works out and make sure that new systems get a revised instruction sheet!
2007 Subaru WRX stock with some Buschur Racing parts
MikeCandler is offline
Old 05-04-2004, 05:35 PM   #26 (permalink)
AEMTech's Avatar
Member Number: 514
We'll have the final word on Friday.
AEMTech is offline
Old 05-05-2004, 11:59 AM   #27 (permalink)
Member Number: 6471
i just installed my aem cai on the 3rd and mine is rubbing the hood to. My intake also didn't come with the rubber piece to protect the piping from the battery.
S1, BDJ's 3 in dump, Forge WGA spike 20 holding 16, Eo1 and emanage, AEM cai, NGK plugs gapped at .35, Spark plug.com wires, AGP fuel return, Greddy catch can, dynoworks mm, Greddy turbo timer, 160 thermostat, external fan switch, goldline springs, i think that's it
Trueplayaz114 is offline
Old 05-05-2004, 09:52 PM   #28 (permalink)
DoubleB's Avatar
Thumbs down
readclose Well all I know is that my pipe looks like crap because the paint is missing and its also dented. Not to mention my hood is missing paint also. Thanks for mentioning anything about the hardline in the instructions!! I think that they should have been more detailed
DoubleB is offline
Old 05-07-2004, 07:44 PM   #29 (permalink)
rockitwerks's Avatar
Member Number: 2664
[quote=stillslow]ben/ AEMtech just got off the phone with me. i am taking my car to AEM on friday and we are going to try another CAS on my car and take more pics so that we can see where all the potential problems are and get them fixed.
Well so how did it go?
rockitwerks is online now
Old 05-08-2004, 08:36 AM   #30 (permalink)
Forcefed24's Avatar
Member Number: 8437
Oh Ok! So move the hard line to get the upper intake pipe to sit lower and yet............................. their are no fitment problems. (I DONT THINK SO) I certainly get it as that makes perfect sense. Sorry for the negative attitude but this is just wrong. What is the ratio of................... no fitment problems : fitment problems ???
