been a while for the bench seat
Tritec Motors
1.6L
Engine Model
Otto cycle, 4-stroke gasoline
Induction
Naturally aspirated
Layout
4 cylinders in line, 16 Valves
Displaceament (cc)
1598
Valvetrain Type, Drive & Layout
16 valves, SOHC, roller rockers with hydraulic tappets. Chain driven with hydraulic tensioner.
Bore x Stroke (mm)
77 x 85.8
Compression Ratio
10.5:1
Cylinder Blocks - Material
Grey Cast Iron
Cylinder Heads - Material
Aluminum alloy A319 - High Silicium Content
Fuel Delivery System
Multipoint Sequential Fuel Injection
Engine Management System
Siemens 2000
Valve Diameter (mm)
30.23 Intake 23.26 Exhaust
Maximum torque (Nm @ rpm)
Obvio ! special specs – original starts at 149 @ 4500 RPM
Maximum Power Output (kW @ rpm)
Obvio ! special specs – original starts at 85 @ 6.000 RPM
External dimensions Length x Width x Height (mm)
590 x 465 x 675
Weight of engine (kg)
104
Obvio ! uses the ZF Ecotronic CVT - Continuosly Variable Transmission
The easyest choice for the driver: full stepless automatic or six electronic
"manual gearshift style" with shift levers in the steering wheel.
Width: 1,800 mm (71 in.)
Wheelbase: 2,250 mm (89 in.)
Height: 1,500 mm (59.0 in.)
Overall lenght: 3,200 mm (126 in.)
Curb weight: 750 kg (1,648 lb.)
Gasoline tank: 50 liters (13.21 Gallons)
Obvio ! 012 key-tech specs
• metallic chassis + Composite superstructure bonded = the chassis enters in the "RTM Light" forms (resin Transfer Molding Light) and forms only one part, with the cell of survival with high safety rating, formed by composites structuralized for absorption of impacts, traction, compression and torsion that receives afterwards all modular components;
• the structure resulting of setting the windshield as part of the chassis structure, with an integrated roll cage being part of the structural chassis;
• the chassis doesn’t have central tunnel - the interior is a "lounge – it provides a nice, smooth floor with large space for legs – ergonomically perfect - in a pleasant ambience, with a “sofa” for three passengers;
• gearshift of the CVT transmission – front, park, neutral and reverse - located at the left of driver, between the door and the seat and electronic six speed “manual gearbox style” control in the steering wheel;
• parking brake lever located at the left of the driver also, between the door and the seat;
• rear driven with mid mounted engine;
• dettachable "Boblbee" backpack as part of the dash design;
