Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Site Functions > General Car Discussion (Please say a Prayer for HemiDakota)
Old 02-19-2006, 09:02 PM   #1 (permalink)
Santorican's Avatar
Member Number: 25795
Default Vtg
Today I was on the Porsche website looking at the new 911 Turbo. They happened to mention the VTG technology applied to it. Though I understood some of was said I didn't completely understand it. Can someone explain it to me in simple terms?
Santorican is offline   Reply With Quote
Old 02-19-2006, 09:08 PM   #2 (permalink)
Santorican's Avatar
Also what other types of calipers are there for brakes other than monoblock, and what are the advantages of using monoblocks over other designs?
Old 02-19-2006, 10:09 PM   #3 (permalink)
Shifter's Avatar
Member Number: 20569
Well, the new 997(911) Turbo does have a variable geometry in the turbocharger, so I am assuming that is what VTG stands for. Basically the impeller blades adjust to give either throttle response or max boost. Basically VTEC for the turbo.
Shifter is offline   Reply With Quote
Old 02-20-2006, 12:42 AM   #4 (permalink)
blkformula95's Avatar
Member Number: 13672
exactly. except for the fact that vtg turbos suck. the variable vane set is housed inside the turbine housing and is uberly precisely machined. so when all those nasty ass particulates from the exhaust cause these to stick you lose all vtg function and who knows in what position it will be in when it sticks. they are mostly used on diesels (international, CAT,Ford) but i assume a gas motor would be less prone to these problems because the exhaust has less particulates.
=ModernMopar.net=
S3R w/toys 3" catless DP, CAI, Mopar CB, AEM uego, DC STB, mopar sts, Perrin UPP, MSD coil,
35lb CF boost gauge, Eibach pro-kit, huge nuts
Quote: Originally Posted by OrAnGe-SrT4
Don't get the condoms that numb your sh!t. You cant feel a damn thing and you just go into limp mode.
blkformula95 is offline   Reply With Quote
Old 02-20-2006, 07:49 PM   #5 (permalink)
Shifter's Avatar
Well I'd be surprised if a modern Porsche would use questionable technology, That's always been Ford and GM's domain.
Page generated in 0.16517 seconds with 13 queries
