Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Site Functions > General Car Discussion (Please say a Prayer for HemiDakota)
Old 02-20-2007, 12:51 PM   #1 (permalink)
jcrsrt4's Avatar
Member Number: 33655
Question jeep wrangler question
trying to help my buddy out...his jeep has a heavy "shimmy" when braking up around 50mph...you can also feel it at lower speeds also....he already had his rotors cut once before and nobody from jeep seems to be able to give him an explanation....is this a notorious or common problem with jeeps...any help and info would be great
jcrsrt4 is offline   Reply With Quote
Old 02-20-2007, 01:17 PM   #2 (permalink)
Senior Moderator
stowaway's Avatar
Member Number: 3286
cut rotors = warped rotors
replace them, cheap and easy.
warped rotors are fairly common on jeeps.
Old 02-20-2007, 01:35 PM   #3 (permalink)
jcrsrt4's Avatar
^^^warped rotors are common on jeeps?....how many miles do you think new rotors should last on a jeep?
Old 02-20-2007, 01:41 PM   #4 (permalink)
Senior Moderator
stowaway's Avatar
Member Number: 3286
i've heard more than a few reports of warped rotors in 12k miles.
Old 02-20-2007, 02:02 PM   #5 (permalink)
jcrsrt4's Avatar
thanx man
Old 02-20-2007, 02:17 PM   #6 (permalink)
thepowertowin's Avatar
Member Number: 13897
Trader Rating: (615)
Also a new problem that has surfaced since the removal of asbesotos brakes is "thickness variation" which feels the same as warping, but what is actually happening, is some of the metal from the bi-metallic pads is adding to the thickness of the rotor, but doing it inconsistently. That is what happens to a lot of the newer Grand Cherokees. New rotors and pads at the same time is the best... and Mopar makes a make-it-new kit to replace everything. There is also ceramics available which I don't think are quite as good stopping wise, but will stop a problem if it's adding metal to the rotor, and get rid of that pesky brake dust.
ALL MOPAR AND MOPAR PERFORMANCE PARTS!!!!
James "Jimmy" Campbell
E-mail/Paypal: speedandpowerdevelopment@gmail.com
Email is better than PM's
http://www.srtforums.com/forums/f165...12/?highlight=
thepowertowin is offline   Reply With Quote
Old 02-20-2007, 02:50 PM   #7 (permalink)
Member Number: 12491
Probably warped rotors... 99-04 Grand Cherokees eat rotors like cookies, other Jeeps as well.
It's almost guaranteed to be warped rotors - assuming the Wrangler's stock.
veritas is offline   Reply With Quote
Old 02-20-2007, 02:58 PM   #8 (permalink)
The grand cherokees have the thickness variation issue, not warped... but the wranglers typically don't have that issue. More likely a warped issue, but then again, you could have something wrong that is not properly distributing the braking force to wear one side out. Maybe rear brakes are out of adjustment?
Page generated in 0.19459 seconds with 13 queries
