Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Site Functions > General Car Discussion
Old 11-05-2009, 05:33 PM   #1 (permalink)
evo77's Avatar
Member Number: 1346
Default The future: Spark Plug Lasers
Spark plugs may be replaced with lasers
By Wayne Cunningham on 17 July 2009
Say goodbye to spark plugs, a 19th century technology which, according to reports, could be supplanted by lasers.
Bye bye spark plugs, 'ello lasers.
(Credit: NGK)
London's Daily Telegraph newspaper is reporting that Ford is working with the University of Liverpool to develop a laser ignition system for internal-combustion engines. That's right: engines with lasers strapped to their heads.
The laser beam is delivered by a thin, fibre-optic cable to a focusing lens that would take up much less space than a spark plug, allowing engineers greater flexibility in designing valves and cylinders. The laser beam can be split to ignite the fuel mixture from multiple points deep in the cylinder — as opposed to a spark plug which is located either at the top or bottom of an engine — making for a more efficient burn than a spark plug can achieve, reducing emissions and getting better fuel economy. Another advantage to the laser system is that part of the beam can be reflected to a receiver and used to gather data on the fuel mixture and the quality of the burn.
And this isn't merely a research project, as there are working prototypes of the system at the University of Liverpool laboratory. Ford, which has eagerly been adopting fuel efficiency technology such as electric-power steering and six-speed transmissions, reportedly will use the laser ignition system in some of its cars over the next couple of years, then spread the technology to the full range.
Currently internal-combustion engines that don't use diesel fuel require a spark plug to cause the engine's air and fuel mixture to ignite and release its energy. Diesel, or compression ignition, engines don't have a spark plug, but instead compress their air and fuel mixture so tightly that it combusts due to the pressure.
Spark plugs may be replaced with lasers - Cars
S2 no toys, Mopar bov, AGP bfmic, 3" turboback
Old 11-06-2009, 11:45 AM   #2 (permalink)
Jagok1's Avatar
Member Number: 14366
Trader Rating: (18)
Very interesting.
AGP GT40 -> 317@16psi -> 370@21psi -> Race #'s soon Tuned by NemoFoss
Jagok1 is offline   Reply With Quote
Old 11-06-2009, 12:06 PM   #3 (permalink)
srt4crazy05's Avatar
Member Number: 54763
search firestorm spark plugs. that is great stuff. safely running a 14.7+ a/f ratio at wot and greatly increasing gas mileage. too bad they r outlawed for mass production
13.463 @ 103.71mph 3 bolt ons n street tires. stock suspension. mm inserts. no tune
srt4crazy05 is offline   Reply With Quote
Old 11-06-2009, 12:30 PM   #4 (permalink)
CJsStocker's Avatar
Member Number: 58783
Trader Rating: (40)
hmmm....
CJsStocker is offline   Reply With Quote
Old 11-06-2009, 12:56 PM   #5 (permalink)
evo77's Avatar
Member Number: 1346
Old 11-06-2009, 01:35 PM   #6 (permalink)
SRTforums Photoshop Expert
suzq044's Avatar
Member Number: 1660
.. old news, on the laser thing.. but cool none the less.
suzq044 is offline   Reply With Quote
Old 11-06-2009, 03:32 PM   #7 (permalink)
Quote: Originally Posted by evo77 View Post
ugh no embeded aloud here
YouTube - Firestorm Spark Plugs
24/1 afr
Old 11-06-2009, 03:46 PM   #8 (permalink)
csx321's Avatar
Member Number: 4534
Trader Rating: (24)
24/1 afr
You realize that's a scam, right? You can't believe everything you read. Or see on YouTube.
'04 SRT4, '87 Shelby CSX, '89 Shelby CSX, couple of others
2006 One Lap of America LER Media Crew
2009 Midwest SRT Nationals Attendee
csx321 is offline   Reply With Quote
Old 11-06-2009, 04:14 PM   #9 (permalink)
no its not. ive done my research. its not legal to manufactur them in the US
edit: here we go. my friend emailed this to me
Directory:Firestorm Spark Plug - PESWiki
Old 11-06-2009, 04:52 PM   #10 (permalink)
csx321's Avatar
Member Number: 4534
Trader Rating: (24)
Good grief! Even in that link, they claim it lets you use water for fuel! Nearly all the discussion of these spark plugs is on "free energy"- and conspiracy-type sites. It's totally and completely a scam. You can tell just from the look of that site that it's a scam.
It is, of course, impossible to get more energy from burning hydrogen and oxygen than it took to split them from water in the first place. Here's a link to an electronics experts forum, with a whole bunch of links to threads devoted to debunking the idea of using water for fuel:
All About Circuits Forum - View Single Post - Stanly Meiyer Explained with science.
Electricity takes the path of least resistance, i.e. the shortest route. Multiple-ground electrode plugs have been around for years. As the electrode wears, the spark jumps to the next closest one. These plugs do not create a hotter spark, increase mileage, or produce more power. They can, however, extend the length of time between plug changes compared to a single electrode plug.
Edit...
I just searched the entire Code of Federal Regulations for "firestorm" and got this...
This is the search report for the search you ran on Nov 6 17:55:58 2009.
It is a temporary file, and will expire about an hour after the search.
Searching /wais/indexes/cfr...
Your query was:
FIRESTORM
The database contains 196,531,761 words in 260,347 documents.
There are no fields in this database.
firestorm does not occur in the database.
The search found 0 documents. It took less than a second.
The search was performed by a WAIS Inc server: WAIS Server 2.1.6.
For more information on this product contact the database administrator.
Old 11-06-2009, 05:02 PM   #11 (permalink)
umm ok its not like u can get firestorm plugs anyways. but w/e ima stand by my info n u can stand by urs. not gonna hurt me at all cause ill never have em
Old 11-07-2009, 04:36 PM   #12 (permalink)
FunWheelDrive's Avatar
Member Number: 34041
Reposted thread is a repost.
No more sparkplugs???
FunWheelDrive is offline   Reply With Quote
Page generated in 0.15213 seconds with 13 queries
