Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Site Functions > General Car Discussion
Old 08-23-2007, 05:31 PM   #2686 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Mechadyne's Variable Cam Timing is a means of precisely controlling the flow of air into and out of an engine by allowing the camshaft to be dynamically phased relative to its crankshaft. To be more specific, VCT allows the valves to be operated at different points in the combustion cycle, to provide performance that is precisely tailored to the engine's specific speed and load at that moment. The timing is set to allow the best overall performance across the engine's normal operating range. It is in the phaser pulley that makes it adjust....
Although it looks like one camshaft with a phaser at the left end, it's really a hollow tube-type shaft with a second, solid shaft through it, with the phaser connected to both. The intake cam lobe assembly (A) has a pin that goes through a slot in the hollow camshaft and is pressed into the solid cam. The exhaust cam lobe assembly (B) is pressed into position on the hollow camshaft.
hemidakota is offline   Reply With Quote
Old 08-23-2007, 05:34 PM   #2687 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
A good read point on what will transpire to the Hemi/Magnum engines...one of many tech toys that are coming soon.....
http://chryslercorporationllc.blogsp...am-in-cam.html
Old 08-23-2007, 05:44 PM   #2688 (permalink)
SRTforums Photoshop Expert
suzq044's Avatar
Member Number: 1660
the lattitude & new yorker have been known - the question is, will it be a design study-concept or a production-concept.
suzq044 is offline   Reply With Quote
Old 08-23-2007, 05:49 PM   #2689 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Why would I continue to post it unless there is place for it.....lol
Old 08-23-2007, 05:54 PM   #2690 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
VVT [VCT] Info for the Viper 8.4 Liter...will look familiar on the other engines
Intake & Exhaust Valves
VVT Camshaft
VVT Camshaft Phaser
Camshaft Position Senor
VVT Oil Control Valve
Roller Rocker Arms
Hydraulic Roller Lifter
Lifter Alignment Yoke
Old 08-23-2007, 05:57 PM   #2691 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Mercedes’ Composite Crash Structure
Bolted to the front of the 2008 Mercedes SLR McLaren Roadster chassis is a carbon fiber structure highlighted by conical side elements designed to progressively absorb accident energy. Each cone is approximately 24.5-in. long, and weighs 7.5 lb. The cross-section of the part varies from front to back to ensure that the structure collapses in a predictable manner and at a pre-determined rate, while using the minimum material possible in the production process. A similar structure is used in the rear on the approximately 3,900-lb. car, while its side sills are composed of multi-shell reinforced carbon fiber sections and the A-pillar wraps carbon fiber around high-strength steel.
Old 08-23-2007, 07:13 PM   #2692 (permalink)
toasteroven's Avatar
Member Number: 7373
Quote: Originally Posted by hemidakota
...In a double clutch transmission, particularly for front wheel drive cars with transversely mounted engines...
Interesting.
"This car is 100% sh*ts and giggles."A car can be a tool but it can also be so much more. It can be a heart-starter, it can be a drug, it can be a piece of art and it can stir your soul.
"Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
toasteroven is offline   Reply With Quote
Old 08-23-2007, 07:14 PM   #2693 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
CHRYSLER PLAY [Canadian motor vehicles]
Old 08-23-2007, 10:36 PM   #2694 (permalink)
UN4GTBL's Avatar
Member Number: 36137
I seen a few for sale now on eBay....the answer is yes.
are these from chrysler or just from independant companies?
Also, I can just find MyGIGs on ebay, but no adapters? Any key words you used to find the adapters? Thanks
UN4GTBL is offline   Reply With Quote
Old 08-24-2007, 06:34 AM   #2695 (permalink)
Member Number: 15332
You must have a specific head unit, there are several different types of "MyGIG" radios, running on different Bus systems, and amongst those, many different part numbers. On the enthusiast/aftermarket level, wiring harness adaptors and antenna adaptors have been made up.
So far, the units have only been tested in the Grand Cherokee and LX models, with slightly different results. Most functions have been made to work, including UConnect. Vehicles with the high end sound systems need a CAN control to operate the volume and EQ levels, a custom box is being designed for this. Work is progressing, slowly but surely. At this time it is not known how well the MyGIG will adapt to the PM/MK and other vehicles. With what is known so far, there is no reason why most functions will not work or be made able to work.
Last I checked, Mopar engineering was also working on adaptor kits to allow the installation of the MyGIG on vehicles with the 3rd gen radios (MyGIG is 4th gen). More information on this should be available before the year is out. One way or the other, via Mopar or aftermarket, most if not all installation issues should be solved for many '05/'06-up vehicles. It certainly is odd that all-new vehicles like the Caliber/Compass/Patriot are not offering MyGIG, especially since the vehicles are in typically marketed for a "younger" crowd. It possibly may have been a supply issue, since it is being made available on so many other vehicles this model year.
ResumeSpeed is offline   Reply With Quote
Old 08-24-2007, 07:21 AM   #2696 (permalink)
Member Number: 50939
What is the Latitude?
Mark_S is offline   Reply With Quote
Old 08-24-2007, 08:07 AM   #2697 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Default 2008 Dodge Viper - extreme Makeover: The 200-mph Edition
By Dan Edmunds, Director of Vehicle Testing
Date posted: 08-23-2007
"Brute strength and awkwardness" is a phrase that we heard a lot while growing up at Dad's race shop. He used it to describe a powerful yet ill-handling machine; or, more often, the driving technique of a hero driver attempting to cope with one. Both definitions rattled around in our brain as we traveled to Virginia International Raceway (VIR) to drive the 2008 Dodge Viper SRT-10.
Consider the specifications: 600 horsepower (90 hp more than before) from an improved 8.4-liter V10; 200-mph top speed; and a front-engine, rear-wheel-drive chassis with no stability control.
My God, do they even make cars like that anymore?
Brute Strength? Check
The 2008 Dodge Viper SRT-10 isn't all-new, but the signature V10 lump under the hood is. Serious, meaningful changes have increased the V10's output and improved its fuel economy (and even its air emissions, too). And yes, it really is rated at 600 hp, which peaks at 6,100 rpm. Torque is up to 560 pound-feet at 5,000 rpm — as if this descendent of a truck engine didn't have enough torque already.
Stouter pistons and rods from Chrysler's popular 6.1-liter Hemi V8 have made possible a 1-millimeter increase in the V10's cylinder bore, swelling the displacement from 8.3 to 8.4 liters — a whopping 510 cubic inches.
A substantial increase in the compression ratio from 9.6:1 to 10.2:1 results from reworked combustion chambers. The fuel injectors now reside in the heads, close to the intake valves instead of farther upstream. Each spark plug now has its own coil. And a swinging pickup in the oil pan (borrowed from the Viper Competition Coupe) prevents oil starvation in the V10 during high-g driving.
Putting the increased muscle to the pavement requires a beefed-up Tremec TR6060 six-speed manual transmission with 10 percent wider gears and triple synchronizers. A stronger twin-plate clutch copes with the power increase.
A More Radical Cam
The biggest trick here is the 8.4-liter V10's variable cam-phasing device known as Cam-in-Cam. Variable valve timing is mechanically straightforward for DOHC applications, but an OHV engine with a single cam mounted within the block cam as found in the SRT-10 presents a challenge.
Here the hollow camshaft has fixed intake lobes on its outer circumference, while the exhaust lobes are attached to separate, movable inner shaft. A computer-controlled mechanism in the cam sprocket continuously adjusts the relative phasing between the two shafts. As a result, the valve overlap can be made radical enough for maximum power or conservative enough for a smooth and clean idle.
A surprising benefit is a 17 percent increase in fuel economy for this new V10. While the 2006 Viper was rated at 11 mpg city and 19 mpg highway (adjusted for 2008 equivalency), the 2008 Viper is good for 13 mpg city and 22 mpg highway. Plus a buyer of a 2008 Viper pockets a $1,700 savings in gas-guzzler tax.
Unleash the Beast Already
Once we take to the track at VIR, we soon find that the new engine's increased grunt flings the Viper out of the slowest hairpins with even greater authority. The absence of traction control proves of little concern thanks to accurate throttle response, wide Michelin R-compound rubber and a new GKN Visco-Lok speed-sensing limited-slip differential.
The acceleration down the long straights is simply crushing, and the V10's broad torque curve smothers the gaps between the six widely spaced ratios in the gearbox and overcomes the tall 3.07:1 axle ratio chosen to deliver a top speed of 200 mph. The engine's 6,250-rpm redline might seem a bit truckish for some, and the throaty thrash of the mighty V10 isn't exactly musical, but 8.4 liters of displacement and 10 pistons get the job done in a hurry.
Once we put the new Viper on our test track in California, we found that bursts to 60 mph can be accomplished entirely in 1st gear, and the mark comes up in 3.7 seconds, a full 1.2 seconds quicker than the 2006 Viper SRT-10 we tested. A couple of shifts later, the quarter-mile disappears in 11.8 seconds at 125.3 mph — a stunning 0.8 second and 7.9 mph better than the old car.
It Gets Better
Though the performance of the reworked engine grabs headlines (and the seat of your pants), the tweaks to the Viper's suspension are arguably more significant. They make the 2008 Dodge Viper SRT-10 simultaneously more livable on the street and more corner-capable on the track.
First and foremost, the former run-flat tires have been cast aside and replaced with Michelin Pilot Sport PS2 high-performance tires — and a sealant kit. Freed from the necessity to be stiff enough to bear the burden of running without any air pressure for support, the sidewalls of the PS2 tires are less rigid, improving compliance and suppressing skittishness over bumps and cracks in the pavement.
That said, the Viper is still all about fast driving on a track. Spring rates that are 5 percent firmer preserve the overall wheel rate of the previous suspension calibration, and shock damping has been adjusted to capitalize on the capability of the new rubber. This setup also allows increased negative camber in the static alignment (now negative 1.4 degrees at every wheel). The end result increases mechanical grip and improves poise from this very heavy, very powerful car with a very short 98.8-inch wheelbase.
These improvements have also allowed the SRT engineers to address the excessive understeer that has been dialed into the Viper over the years in an effort to control the beast in its nature. By simply replacing the previously hollow rear stabilizer bar with a solid one of the same diameter, rear roll stiffness has been increased.
Awkwardness? No, Not Really
At VIR, these tweaks allow us to stab the new Viper aggressively into low- and high-speed corners alike without speed-sapping understeer. The steering is sharp and direct, and you can use a quick lift of the throttle or trail braking to make a quick entry into a corner, as the 2008 Viper seems less likely to surprise you with snap oversteer.
Within a lap or two, the predictable responses of the 2008 Viper's new suspension tuning make fast driving almost effortless. Even with 600 ponies underfoot, this new Viper is far from being the handful we'd imagined on the way here. It just hauls butt and makes no excuses.
On our testing surface in California, the 2008 Dodge Viper SRT-10 scorches our skid pad with a 0.99g two-way effort. (The counterclockwise run was 1.02g.) Had conditions been less hot and slick, Dodge's own 1.05g "performance target" seems possible.
The Viper's 72.4-mph slalom speed places it near the top of the heap of front-engine machines. Weight distribution of 49.5 percent front/50.5 percent rear for the car's 3,437 pounds helps. None of the cars in our 2006 American Exotics test (Viper included) got close to the 70-mph mark.
Down to Business
We haven't said much about the rest of the Dodge Viper because not much has changed. It's still a tight squeeze in and out, and our tallest tester complained about seat travel. A navigation system is now available, though.
Perhaps the most striking attribute of the 2008 Dodge Viper SRT-10 is its price. Despite the extensive engine do-over and the chassis refinements, the as-tested price of our coupe is actually $945 lower than a similarly equipped 2006 model.
Including destination, a roadster costs $83,995, and a coupe like ours starts at $84,745. These figures are slightly higher than last year, but that $1,700 drop in gas-guzzler tax tips the scales the other way.
The 2008 Dodge Viper SRT-10 certainly ups the ante in the brute strength quotient, but it's anything but awkward. Even the most ham-fisted hero drivers among us can now wield it. Prepare to trade in your 2006 edition. It's the best negative $945 you'll ever spend.
The manufacturer provided Edmunds this vehicle for the purposes of evaluation.
(Play clip)
Full Test: 2008 Dodge Viper SRT-10 Coupe
Photos
Slideshow
Enlarge photo)
Run-flat tires have been replaced by identically sized P275/35ZR18 front, P345/30ZR19 Michelin Pilot Sport PS2 R-compound tires. (Photo by Scott Jacobs)
Enlarge photo)
Even sticky tires, tall gearing and a limited-slip differential can be overcome by 600 hp. (Photo by Scott Jacobs)
Enlarge photo)
The new 8.4-liter V10 engine develops 600 horsepower, 90 more than before; fuel economy is 17 percent better, too. (Photo by Scott Jacobs)
Old 08-24-2007, 08:12 AM   #2698 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
(Enlarge photo)
An enlarged hood scoop funnels air directly into the airbox and throttle butterflies. (Photo by Scott Jacobs)
Enlarge photo)
A ghost view of the hood scoop illustrates its proximity to the throttle butterflies. (Photo by Scott Jacobs)
(Enlarge photo)
Six hood louvers have been added to extract the copious amounts of heat that this 600-hp mill produces at full boil. (Photo by Scott Jacobs)
Enlarge photo)
Nothing much has changed here; a navigation system is newly available, but our test car didn't have one. (Photo by Scott Jacobs)
(Enlarge photo)
Redline for the new 8.4-liter V10 is now set at 6,250 rpm. (Photo by Scott Jacobs)
(Enlarge photo)
A revised six-speed has a shorter-throw shift action, but it still feels clunky during daily use. (Photo by Scott Jacobs)
(Enlarge photo)
First is the only gear needed to get to 60 mph in 3.7 seconds — much faster than last year's Corvette Z06. (Photo by Scott Jacobs)
(Enlarge photo)
We don't have access to the kind of asphalt necessary to verify Dodge's claim of a 200-mph top speed — but we're looking. (Photo by Scott Jacobs)
(Enlarge photo)
Some of us dislike the V10's throaty rumble, others can't get enough of it; four-piston Brembo calipers and 14-inch rotors help bring the Viper to a halt. (Photo by Scott Jacobs)
Enlarge photo)
Getting in and out is still a gymnastic experience for tall guys. (Photo by Scott Jacobs)
(Enlarge photo)
GTS Blue is not one of the new colors; the painted stripes in silver or black cost $3,000. (Photo by Scott Jacobs)
(Enlarge photo)
2008 Dodge Viper SRT-10: It's all about Escape from New York. (Photo by Scott Jacobs)
Old 08-24-2007, 08:13 AM   #2699 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Special next gen Liberty model
Old 08-24-2007, 08:34 AM   #2700 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Default ech Watch: Chrysler Turns to High-Strength Steel Technologies To Improve Fuel Economy
(Enlarge photo)
Chrysler is touting the advantages of a new steel technology (pictured) that lets it build vehicles that are safe, light, and fuel efficient. (Photo courtesy of Chrysler LLC)
(Enlarge photo)
Chrysler's new lighter-weight steel is used in the 2008 Chrysler Sebring, which is 13 percent lighter overall. (Photo courtesy of Chrysler LLC)
INSIDELINE.COM - - | DETROIT — Chrysler said this week that it is managing to squeeze the best of both worlds out of new high-strength steel technologies: vehicles that are lighter and more fuel-efficient, but able to meet tough safety standards.
Chrysler, Daimler and the American Iron and Steel Institute made the joint announcement touting the success of a new project that uses "the latest advanced high-strength steels." Overall vehicle weight was cut by up to 13 percent compared to vehicles using conventional high-strength steels and design methods, Chrysler said. New engineering computer-modeling technology helps the companies determine where the material "best serves the structure." Resulting fuel savings are expected to be about 1 percent.
"Chrysler is continually developing improvements in safety and fuel economy, which are usually competing objectives," said Bill Grabowski, Chrysler director of body core engineering.
What this means to you: Your future Chrysler is likely to be more fuel-efficient, thanks to a combination of new materials and advanced design methods.
Page generated in 0.28386 seconds with 14 queries
