Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Site Functions > General Car Discussion
Old 03-18-2008, 09:42 AM   #1 (permalink)
Santorican's Avatar
Member Number: 25795
Default BMW 135i 0-60
"From here it looks like a pot-bellied pig," says Chief Road Test Editor Chris Walton as he points to the nose and scooped-out door profile of the new 2008 BMW 135i Coupe.
"Check out the overhanging character line above the taillights," we prompt. "Is this the new BMW 1 Series or a Corvair?"
You'll have to forgive us. We're taking a break from flogging BMW's 3.0-liter twin-turbocharged wünder-coupe and, frankly, we're more than a bit giddy. Three hundred horsepower and a similar dose of torque will do that to you, especially when it's in a shrunken rear-wheel-drive coupe that weighs less than a BMW 335i that shares the same engine.
E-Speak
The peerless BMW 335i has earned endless praise from us for its solid construction, balanced handling and stonking twin-turbo engine. So far it's batting a thousand when it comes to victories in our comparison tests.
But in becoming more refined, the E92 (that's BMW techspeak for 2007 and later 3 Series coupes) has gained size and weight, so its communicative responses have been muted. Well, that's what BMW fanboys will say, anyway.
That's where the 2008 BMW 135i Coupe (a.k.a. E82) comes in. Sure, when the 1 Series comes in the guise of the 2008 BMW 128i, we'd call it an entry-level Bimmer. But the inclusion of "the Engine" (as we find ourselves saying) is proof positive that BMW knows what its core enthusiasts really want.
Anti Super-Size Me
How much smaller than a 2008 BMW 335i is the new 2008 BMW 135i Coupe? At 172.2 inches, the U.S.-spec 1 Series gives up 8.1 inches of length. It's even 3 inches shorter than the E30 3 Series of the 1980s and only 0.7 inch longer than the E21 3 Series of the 1970s.
The greenhouse of the 1 Series coupe is something of a bubble, resulting in a 55.4-inch height, ample headroom and general proportions that fall between the E30 and E36 coupes. Notable deviations from the vintage BMW formula for sport sedan proportions include a higher beltline and a wider stance.
Interior space is suitably ample up front, but unless the front seat occupants are of below-average height, the rear seats are a kids-only proposition. This 6-foot-2 editor was able to travel with his 9-year-old daughter seated behind, but only just.
So the 1 Series coupe clearly doesn't share the "too big" problem of the 3 Series.
As compact as it is, the new 135i is no lightweight. It's still a full-featured premium piece, and it shows evidence of the mass that comes from 20 years of safety advances plus the "must-have" thinking about convenience features that shapes the thinking of product planners everywhere. Our test car tips the scales to the tune of 3,399 pounds, some 172 pounds less than a 335i, but still 200 or so pounds heavier than the similar-size E36 BMW M3 of the 1990s.
Cue the Bigger Hammer
But the 135i has a not-so-secret weapon that those lighter, earlier BMWs didn't have: a twin-turbocharged, direct-injected straight-6 engine that not only produces 300 hp but also packs a 300 pound-feet wallop of torque from 1,400 through 5,000 rpm.
On the road, the power delivery of the turbo six is so smooth and relentless that it makes the 1 Series fast — very fast — but never furious. This engine simply grunts it out and pulls hard from the bottom of the tach to its redline at 7,000 rpm. And the thrill quotient goes up because all this is happening in a car that's almost 200 pounds lighter than the engine's customary 3 Series package.
So the 1 Series coupe doesn't share the "too fat" problem of the 3 Series.
At the track, the twin-turbo big hammer drove our 135i down the quarter-mile in 13.3 seconds at 104 mph. The 2008 Subaru WRX STI with 5 more hp and 48 fewer pounds does the same time in the quarter-mile, but with a slower 102.4-mph trap speed.
While the STI edges the 135i's 5.0-second acceleration to 60 mph by a fraction thanks to the launch traction afforded by the Subie's all-wheel drive, the BMW ultimately has the legs at the top end and catches the STI at the finish line.
This performance does nothing to dispel our continuing suspicion that the 300-hp rating of the twin-turbo inline-6 is conservative at best.
Sometimes the Small Numbers Are Best
A shorter wheelbase gives the 1 Series a dimension of agility that the 3 Series lacks, and it measures 104.7 inches, some 4 inches less.
The suspension layout of the E82 is similar to that of the larger 3 Series. It still carries front struts with split lower arms and dual lower ball joints, while the rear retains the latest multilink layout. But both ends have been recalibrated for the 1 Series application.
Our 135i coupe came with standard 18-inch Bridgestone Potenza RE-050A run-flat summer tires: 215/40R18s up front and 245/35R18s in the back. We're still deeply skeptical about the performance of run-flats, even after the latest improvements. The mega-stiff sidewalls of the 050As disrupted an otherwise tame ride whenever we encountered abrupt, sharp-edged breaks in the pavement or even pronounced ripples.
We wish BMW would offer us the option of conventional tires or space for a spare. But since the battery resides in the trunk to help achieve a weight distribution of 52 percent front/48 percent rear, a spare has no place to live.
Ultimately, We Drive the Machine
Spirited back-road driving proves the 2008 BMW 135i Coupe can deliver the goods, as it dispatched corners with crisp turn-in, an eager willingness to change direction and impeccable grip, without sacrificing the road-worthy poise of the 335i that we love. On our test track, this translates to a blistering 72.4-mph run in the slalom, easily outpacing the last 335i we tested (69.5 mph) and edging the 2008 STI (72.0 mph). Skid pad figures are a wash, as both BMWs generate 0.89g and the STI makes 0.90g.
Understeer has been rumored to lurk within the 135i, but it didn't rear its head until we hit the road-racing track, where high-speed sweepers at the limit work the outside front Bridgestone mighty hard. Track-day junkies might want to make changes, but we think most everyone else will have no complaints.
Our 135i came with six-piston fixed-caliper brakes and 13.3-inch rotors. These calipers (something we'll see more of, our BMW sources tell us) seem like overkill when the heavier 335i and faster M3 do quite well with rather pedestrian single-piston sliding calipers. But the advantage might come in the form of consistently firm pedal feel over several days of determined street driving and extended track testing. This 1 Series comes to a stop from 60 mph in 109 feet.
It's Nice in Here
Inside the cabin, our 135i includes the Sport package, a $1,000 option consisting of an M-sport steering wheel and Shadowline trim, plus an elevated limiter for top speed. The package also includes terrific eight-way manually adjustable seats that adjust quickly, hold on tight in corners and look great. Why spend the money for optional power seats?
Handsome textured aluminum accents are applied with strategic restraint in the interior. BMW is one of a few carmakers that have figured out that accents that have the dull sheen of hand-worn metal look more upscale than any sort of chrome. And no sunlight gets reflected back into the eyes of the driver, either.
The Bottom Line
The base price for the 2008 BMW 135i is $35,675. After adding the options (including the $1,450 Boston leather upholstery) plus a $400 iPod and USB adapter and the $600 Cold Weather Package, our car's as-tested price is $39,125. And beware, because many high-cost options lurking on the options sheet can drive the price much, much higher.
It's hard to pin down the competition for the 2008 BMW 135i. On price and track performance, this test car matches up quite well with the 2008 Subaru WRX STI we tested, which costs $39,440. It matches up on performance, too. That's not bad company to be in, but at the end of the day, the Subie is no BMW.
Is the 2008 BMW 135i Coupe worth it? It depends. It's easy to go overboard with the options and jack up the price of the 135i so it no longer makes sense.
If you value a high level of steering and handling refinement and outright twin-turbo nirvana in a package that's small enough to toss around, and you can live with limited backseat space, the 2008 BMW 135i is like nothing else.
And it doesn't matter that the pot-bellied BMW 135i isn't the most beautiful car in the world. If you're doing it right, you'll be on the inside, working the steering, pedals and shifter with a huge grin on your face, happier than a pig in, well, you know.
Santorican is offline   Reply With Quote
Old 03-18-2008, 09:49 AM   #2 (permalink)
Member Number: 49579
hmmmm... my 335i lease is up in December.
might consider one of these.
not too sure about the looks, though.
got to say the auto trans in sport mode is amazing.
srtprince is offline   Reply With Quote
Old 03-18-2008, 01:30 PM   #3 (permalink)
Santorican's Avatar
I would love to have one of these with BMW's new dual clutch and the twin turbocharged engine.
Old 03-18-2008, 03:35 PM   #4 (permalink)
It's a wonderful, refined car chock full of tasteful touches. Beautifully built.
Great DD.
But, when I drive it (which is most of the time), guess what I miss?
That's right, the crude little srt4 acr sitting home in the garage.
Of course when I drive the srt, I miss............ cruise control!
Old 03-18-2008, 03:40 PM   #5 (permalink)
MASSSRT's Avatar
Member Number: 23778
someone got one in New jersey
First 1addicts U.S. owner!! Just took delivery this morning! - BMW 1 Series Coupe Forum / 1 Series Convertible Forum (M1 / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
11.60 @ 129.8
LIFTING, NO BURNOUT, FULL INTERIOR
MASSSRT is online now   Reply With Quote
Old 03-18-2008, 03:46 PM   #6 (permalink)
bpsrt4's Avatar
Member Number: 40796
Trader Rating: (29)
Looks pretty good in white...hmm
Sell the srt and get an e46 m3 or one of these ...decisions decisions
bpsrt4 is offline   Reply With Quote
Old 03-18-2008, 04:07 PM   #7 (permalink)
Yep. Because we here in Jersey are nothing but a bunch of guidos who need bmw's, hair gel, and stupidly high maintenance woman (personally, I skip the gel).
Old 03-18-2008, 05:18 PM   #8 (permalink)
Senior Moderator
N0sferatU's Avatar
Member Number: 9266
Trader Rating: (10)
basically $40,000...I'll take a C6 for a few grand more no thanks...I loved the idea of the 135 until they bummed the price. "Fully optioned" at 39K I can see but lightly optioned at 39K...umm no. Base price should have been around 30K. Fail.
2007 Audi A4 3.2 QUATTRO
2004 Dodge SRT-4 (SOLD!)
1999 Chevy Camaro (SOLD!)
N0sferatU is offline   Reply With Quote
Old 03-18-2008, 05:31 PM   #9 (permalink)
Fade621's Avatar
Member Number: 3983
Can you really find a C6 for just a "few" grand more though? I ask because I am seriously considering the 135.
Mods:
Evil exists when good men do nothing.
Fade621 is offline   Reply With Quote
Old 03-18-2008, 05:44 PM   #10 (permalink)
Senior Moderator
N0sferatU's Avatar
Member Number: 9266
Trader Rating: (10)
starts at $46,950 for the C6
Old 03-18-2008, 06:31 PM   #11 (permalink)
acrbill's Avatar
Member Number: 1022
Check the paper for deals and you will find all sorts of c6's for $39k
Good luck finding a 135i for under sticker.
acrbill is offline   Reply With Quote
Old 03-18-2008, 09:36 PM   #12 (permalink)
MASSSRT's Avatar
right now some dealers are offering leftover C6's for like 42k,
go to corvetteforum.com, thats where I saw them
heres some good deals
Under Construction Sale @ Boardwalk Chevrolet! Every Corvette Must Go! Crazy Deals!!! - Corvette Forum
some dealers offer 0%
Old 03-18-2008, 09:50 PM   #13 (permalink)
RTShadow's Avatar
Member Number: 11888
This car is supposed to sticker from 32 to 36K. I think I'd buy this before a Lancer EVO or STi at this price, that is for sure.
Quote: Originally Posted by al2683
One of the most realistic parts of this video is that it shows two guys riding together in the Subaru, they are in love, I think it is a touching and realistic portrayal of Subaru owners and I applaud them for it.
RTShadow is offline   Reply With Quote
Old 03-18-2008, 09:59 PM   #14 (permalink)
Member Number: 6332
Really disappointed in this car. Only 170 lbs less than a 335? At least 40-50 lbs of the difference is the fact that the car doesn't carry a spare. Plus runflat tires typically suck. I can't see why anyone wouldn't just pay another couple grand for a 335. The 335 also looks much better (esp. from the side and rear views).
I second the vette opinion as well.
-2005 IBM GTO - SAP
-2004 EB SRT-4 -> sold
ricky04 is offline   Reply With Quote
Old 03-18-2008, 10:36 PM   #15 (permalink)
l3it3r's Avatar
Member Number: 5077
An E46 M3 can be had for a little more than $20K. I'll take one of those - kthanx
Canon EOS 30D|Canon EF 28-135mm f/3.5-5.6 IS
Canon 18-55mm (kit lens), Canon 50mm f/1.8 II
SanDisk 8GB ExtremeIII | Canon 580EX Flash
l3it3r is offline   Reply With Quote
Page generated in 0.25783 seconds with 13 queries
