Old 03-27-2008, 03:35 PM   #1 (permalink)
card00d85's Avatar
Member Number: 24249
Default Where are all the clamps I should tighten so I don't get a boost leak?
I'm going to do a boost leak test this weekend, but for now I want to make sure all the clamps are tight. The only ones I know of are the 2 on the intake piping. Are there any other ones I should check out and tighten?
2004 E-Blue SRT-4:
Looks- Eibach prokit, 5% tint, 4300k HID's
Performance- Forward motion wga, Mopar performance wires, Mopar STS, AEM sri, pizza boy shift ball
card00d85 is online now   Reply With Quote
Old 03-27-2008, 03:37 PM   #2 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (58)
zip tie everything, all turbo piping, not on the intake
thats fantastic
AGP S256
free mike aka aka aka aka aka aka aka aka aka aka ect....
lyncoo is online now   Reply With Quote
Old 03-28-2008, 07:58 AM   #3 (permalink)
69cuda340s's Avatar
Member Number: 36113
There is a clamp that comes off the turbo. Take your intake tube off and you can get to it. 5/16" socket with a screw driver like handle works best. One right under the engine and don't over tighten this one. One on the passenger's side going into the inter cooler; need to jack the car up to get to that one and a 5/16" socket is way easier then a screw driver. Then one coming off the inter cooler on the driver's side. Then one where the tube goes into the intake which can be reached from the top. They will be loose and leaking if you have not checked them.
69cuda340s is offline   Reply With Quote
Old 03-28-2008, 10:04 AM   #4 (permalink)
Member Number: 52407
7055 is offline   Reply With Quote
Old 03-28-2008, 10:06 AM   #5 (permalink)
Thats for the turbo pipes^^ use t-bolt clamps for those
vacuum lines
Old 03-28-2008, 10:10 AM   #6 (permalink)
card00d85's Avatar
vacuum lines
Thanks man! I have a question about those things screwed on to the filter cover (in above pic). I took off the filter cover and now they are just hanging there. What can I do to support them. What can I ziptie them onto?
Old 03-28-2008, 10:57 AM   #7 (permalink)
gt5oh's Avatar
Member Number: 40811
you have the stock airbox but you took off the cover..why?
gt5oh is offline   Reply With Quote
Old 03-28-2008, 12:11 PM   #8 (permalink)
Dev1lD0g's Avatar
Member Number: 53881
zip tie ALL vac lines and tighten down all piping clamps, don't worry too much about the intake clamp b/c boost doesn't flow inside the intake pipe.
Mike- '05 Black SRT-4
Stage 1, AGP WGA, Needswings v.5 w/e-cutout, Aaron's Mapclamp, AEM UEGO, Injen SRI, TXS RFL BOV, MM Inserts, NGK 4306, MSD 8.5mm Wires
www.myspace.com/jacksonvillencsrt4s
Dev1lD0g is offline   Reply With Quote
Old 03-28-2008, 12:16 PM   #9 (permalink)
card00d85's Avatar
Because it sounds a lot better with the K&N drop in in there.
Old 03-28-2008, 12:17 PM   #10 (permalink)
card00d85's Avatar
And what do you guys mean ziptie all vacuum lines? What do I ziptie them onto? I don't understand what you mean.
Old 03-28-2008, 01:07 PM   #11 (permalink)
Dev1lD0g's Avatar
you zip tie them to make it tighter around then solinoed, you don't tie them to anything just the end of the line
Old 03-28-2008, 01:35 PM   #12 (permalink)
bird man's Avatar
Member Number: 40943
HAHAHAHAHA......this reminds me of potty training my 2 year old.
just like the big metal clamps are around the big pipes.......
pretend the zip tie is a metal clamp but for all the tiny vac lines
Stage 2 w/o toys.....Turbo Xs DTEC.....RC 650cc injectors.....Walbro 255 w/ PTP rewire/PTP charge/hotside/coldside pipes.....Forward motion ported E1 turbo & WGA.....Ported intake & exhaust manifold.....RPM services 60mm TB.....MPx 3" Turboback exhaust & o2 housing + BFMIC.....AEM short ram intake /wideband / 35 psi Boost gauge.....BWoody oil catch can / solid mounts / check valve.....Mopar rice plate.....NGK iridium (1 step colder) gapped at .35
bird man is offline   Reply With Quote
Old 03-28-2008, 06:20 PM   #13 (permalink)
gottasrt4's Avatar
Member Number: 57792
Question dOOOOOde
dOOOOOde, I don't even want to begin thinking of how much HOTTERthe air you're bring'n in your engine is!!!
My Car Domain
Kill List:
2004 Mustang GT with a Badass flowmater exhaust - eL skiNNy bUeno drive'n
Hunting:
Porsche Boxster S, Camaro SS, Mustang Cobra, S2K, M3
gottasrt4 is offline   Reply With Quote
Old 03-28-2008, 06:56 PM   #14 (permalink)
card00d85's Avatar
Ever heard of a short ram intake? They do the same thing.
Plus, I did the hood scoop mod so I have better air flow from the outside into the engine.
Old 03-28-2008, 07:33 PM   #15 (permalink)
monstab757's Avatar
Member Number: 53422
Anyone have pics of their vac lines ziptied?
Mods:
Mopar Stage 1 PCM
Mopar BOV
Mopar STS w/Boogers
Mopar Stage 1 Springs
Forward Motion WGA
Maxxfab 3" O2 Housing
Maxxfab 3" Turboback SEE w/o cat
monstab757 is offline   Reply With Quote
