Quote: Originally Posted by
d3adboost
Stage 1 is a new pcm for the car and if you have an 03 then you get the 04 and 05 injectors.... Stage 3 is a SST turbo from mopar and some supporting mods for it but in my opion not worth the trouble their are a lot of companies that make very competive turbo kits
Guys, I try REALLY hard not to be a dick... but, its becoming more obvious to me that this dude is bound to become the next "greyghost".
Yes, stage "1" is a ECM upgrade.. all "stages" are.
Stage 1, if you own an 03 car, it comes with the PCM, and injectors. (03's had smaller injectors STOCK than 04 and 05's)
Stage 2, again, different injectors and ECM, with a different waste gate actuator. There is also the option of with, and without "toys".
Toys include an intercooler sprayer, HOM (high octane mode) and a D.A.B. or, Dial a Boost switch.
Stage 3, depending on the package. (toy's or no toys) The ECM is the same! injectors,.. are the same.. you get a new fuel pump, new rail.. new ECM.. ect. hell, google the damn thing!!
But to say "Stage 3 is a SST turbo from mopar and some supporting mods" is moronic.
Which is it? The stage 3 with supporting mods?.. or the SST with supporting mods?..
Stage 3, was designed by a MAJOR company, given the "OK" by the eggheads.. backed by MOPAR.. and you compare it to an SST.
Also, a well tuned "stage 3" can make damn close to,.. or a little over 400 HP!!!!
The SST, or the enforcer series turbo's.. are modified STOCKERS!!! The Stage 3 is FAAAARRRR different!!
I'm going to stop there.. if I don't... I'll be at this until MY grave is dug.
My .0123
Will.
