Old 04-03-2004, 08:41 PM   #1 (permalink)
ryedizzel's Avatar
Member Number: 8420
Default Understanding the acronyms...
Hey all, not sure if this has been done before but I was thinking about starting a thread to explain what all these commonly used acronyms mean (for the newbies like me and the non-technical people that read these forums).
2DR = 2 door
4DR = 4 door
A/F = Air/Fuel Ratio
A/C = Air Conditioning
ABS = Anti-lock Braking System
ASD = Auto Shut Down Relay
ACG = Adjustable Cam Gears
ACT = Air Charge Temperature Sensor
AFC = Automatic Fuel Controller
AFPR = Adjustable Fuel Pressure Regulator
AWD = All Wheel Drive
ACM = Airbag Control Module
AFR = Air to Fuel Ratio
BCM = Body Control Module
BHP = Brake Horsepower
BOP = Block off plate
BOV = Blow-off Valve
BPV = Bypass Valve
CAI = Cold Air Induction/ Intake
CB = Catalytic back (cat-back)
CC = Catch Can
CEL = Check Engine Light
DAB = Dial-a-boost
DCX = Daimler Chrysler
DOHC = Dual Overhead Cam
DP = Down Pipe
EBC = Electronic Boost Controller
ECU = Engine Control Unit
EGT = Exhaust Gas Temperature
EM = Exhaust Manifold
EMS = Engine Management System
FI = Force Induction
FMIC = Front Mount Intercooler
FPR = Fuel Pressure Regulator
FSM = Factory Service Manual
FWD = Front Wheel Drive
HID = High Intensity Discharge lighting
HOM = High Octane Mode
HP = HorsePower
I/C = Intercooler
I/H/E = Intake/Header/Exhaust
IM = Intake Manifold
LCA = Lower Control Arm
LSD = Limited Slip Differential
MAP = Manifold Air Pressure Sensor or Manifold Absolute Pressure
MBC = Manual Boost Controller
MM = Motor Mounts
NOS = Nitrous Oxide System
OEM = Original Equipment Manufacturer
PCM = Power Control Module/ Primary Control Module
PCV = Positive Crankcase Ventilation
PP = PowerPaq
PTB = Partial Throttle Boost
PVO = Performance Vehicle Operations
RWD = Rear Wheel Drive
S-AFC = Super Airflow Converter
SOHC = Single Overhead Cam
SMIC = Side Mount Intercooler
SRI = Short ram intake
SRS = Supplimentary Retraint System
SRT = Street and Racing Technology
STS = Short Throw Shifter
SV = Surge Valve
TB = Throttle body
TID = Turbo Intake Duct
TIP = Throttle Inlet Pressure Sensor
TPS = Throttle Position Sensor
TT = Turbo Timer or Twin Turbo
UDP = UnderDrive Pulley
UP = Up Pipe
VC = Valve Cover
WGA = Wastegate Actuator
WHP = Wheel Horse Power
WOT = Wide Open Throttle
Didn't find what you were looking for here? Check out this thread:
Sports Compact Frequently Used Abbreviations
Feel free to submit more below and I will keep editing this original post to include the real ones. I can already see people submitting fake ones. So I guess we will see where the maturity level is on this one.
Thanks in advance for your input.
ryedizzel is offline   Reply With Quote
Old 04-03-2004, 09:11 PM   #2 (permalink)
13B
Member Number: 9633
for the SHORT RAM SYSTEM, you might want to think that over. how about
SRI = Short ram intake (if thats what you are referring to)
some people might get SRS confused with SAFETY RESTRAINT SYSTEM
and also
13B is offline   Reply With Quote
Old 04-03-2004, 09:14 PM   #3 (permalink)
quickysrt's Avatar
Member Number: 4687
tt=turbo timer
05 red srt4 (stock)
05 suzuka blue s2000 (inline-pro stg2 turbo & sleeved block p/p heads etc... to many mods to list)
04 blk srt10 ram (navigation+bedliner-no power mods)
04 srt10 viper red stock(got rid of the black one)
quickysrt is offline   Reply With Quote
Old 04-03-2004, 09:40 PM   #4 (permalink)
Down8's Avatar
Member Number: 831
Did the original thread on this, that was started back when the site first started get lost? It was many pages long with definitions.
-bZj
2002 GMC Sierra 1500 SLE - Extended Cab/Regular Bed
5.3L Vortec V8, Z71 Off-Road package, AutoTrac transmission,
Airaid intake & TB spacer, MagnaFlow exhaust, Edelbrock shocks,
Centerline alloys, 33" Dayton tires, rear load-leveling air bags,
debadged bed/tailgate, billet grill & emblem, black Rhino Lining
Down8 is offline   Reply With Quote
Old 04-03-2004, 09:55 PM   #5 (permalink)
srt4police's Avatar
Member Number: 6575
srt4police is offline   Reply With Quote
Old 04-03-2004, 10:42 PM   #6 (permalink)
ryedizzel's Avatar
Member Number: 8420
Ok, good idea.
My Neon keeps them humble.
Old 04-03-2004, 10:44 PM   #7 (permalink)
ryedizzel's Avatar
Member Number: 8420
All suggestions so far have been updated. Any more?
Also,
-bZj
Do you think you could find it? Rather than duplicate our efforts maybe we can just get an admin to make that one a sticky, or just bump it to the top again. Thanks.
Old 04-03-2004, 11:29 PM   #8 (permalink)
LowNSlowNeon's Avatar
Member Number: 3397
Trader Rating: (18)
OMG = Oh My God
I can't think of any more technical ones
R.I.P Nightshade
LowNSlowNeon is offline   Reply With Quote
Old 04-04-2004, 12:19 AM   #9 (permalink)
Vooduguru's Avatar
Member Number: 944
Trader Rating: (13)
IMO= In My Opinion
IMHO = In My Humble Opinion
IMAO = In My Arrogant Opinion
TTIWWP = This Thread Is Worthless Without Pics
Vooduguru is offline   Reply With Quote
Old 04-04-2004, 12:57 AM   #10 (permalink)
ryedizzel's Avatar
Member Number: 8420
thx for the suggestions but im trying to stick to the commonly used car acronyms used here.
Old 04-04-2004, 10:26 AM   #11 (permalink)
Member Number: 5062
Trader Rating: (10)
DP=Down pipe
UP=Up Pipe
AFR=Air to Fuel Ratio
'04 SRT-4 Bone stock.
Except for S1, STS, Booger bushings, AGP .50 Trim, Turbonetics Wastegate, AGP return line, ED Hardpipe with Greddy type S, NGK 4306s, Greedy ProfecB II, Apexi SAFC II, RC 750s, Walbro 255, AGP 3" intake, DEFI Boost guage, 8.5mm Magnecore Wires, STOCK Coil pack, Upper/Lower ES mounts, stereo, lighting, etc. **Soon to come Big FMIC, Wideband...Stay tuned!
Gameguru is offline   Reply With Quote
Old 04-04-2004, 11:25 AM   #12 (permalink)
Member Number: 1444
EBC- electronic boost controller
MBC- manual boost controller
Chris
2004 Electric Blue Srt-4 w/sunroof
(First in SoFla I think)
Traction is offline   Reply With Quote
Old 04-04-2004, 11:52 AM   #13 (permalink)
turbo4life's Avatar
Member Number: 666
Quote: Originally Posted by Dale Seeley
turbo4life, are you related to lifeisdeath?
If you have nothing to offer the thread, other than your incredible ability to toss around inane opinions, please step up to the plate...
Dale
Quote: Originally Posted by bodizapha13
The first night wasnt to bad. He had on all his clothes during back rub. It was the next day when he came out in a thong already oiled up that I had to call in Tim's help. He knows how to "handle" Dale.
turbo4life is offline   Reply With Quote
Old 04-04-2004, 02:59 PM   #14 (permalink)
_-]ReDrUm[-_'s Avatar
Member Number: 7800
I think TT can stand for more than just turbo timer. It can stand for turbo toys or twin turbo.
_-]ReDrUm[-_ is offline   Reply With Quote
Old 04-04-2004, 03:04 PM   #15 (permalink)
Super Steve's Avatar
Member Number: 2089
PP= Power Pax
SAFC= Super Air Fuel Control
My little .02
"485hp@453tq 11.8@123mph"
Super Steve is offline   Reply With Quote
Page generated in 0.20290 seconds with 13 queries
