Old 11-04-2009, 02:10 PM   #1 (permalink)
lil_hub_cap's Avatar
Member Number: 75014
Default um AFR not right at all. please help
hey so im worried about my car at this point. I moved up to wyoming for school, and now thats its officially winter, im running leaner. Yes i do realize that its a very typical thing to run leaner in winter, but not like this. During dummer my afr was roughly 14.7 and wot 11.8-11. now thats its winter, my wideband has been spazzing out, and even just idaling, goes from 14.7 - 15.6 and when i drive and accelerate it rarely drops below 14. its really strange. Im not sure if my wideband is just completely fucking up, but idk.
For the most part it ran just fine, i took it up to quick speeds, running 19lbs atm. there was a bit of a drag, but im really not sure what the cause is, i thought 02 at first, replaced and nothing. any thoughts would be great.
thanks!
EDIT: Well i started work on my car yesterday, and checked into the codes. As it turned out, it kept yelling at me about a problem with my MAP sensor, and i couldnt figure it out. Ended up volt dropping the Bulkhead connector going into the map and i had a bad ground.
All is well....for now at least haha.
thanks guys
lil_hub_cap is offline   Reply With Quote
Old 11-04-2009, 02:12 PM   #2 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (40)
sounds like its working fine. the numbers will be a little off for a while weather depending but 14's and 15's is normal.
bene is online now   Reply With Quote
Old 11-04-2009, 02:36 PM   #3 (permalink)
m4ster_chef's Avatar
Member Number: 74316
No... he said when he accelerates it doesn't drop below 14.x... that's not good. If it's IDLING at that you're fine. But if under WOT it's not going below that you're in need of some help.
2004 NSRT
Full S3 w/o toys
Spiking 24, hold 22
AEM Wideband & Pyrometer
Mopar Short throw shifter
Motor Mount Inserts
Prothane LCA bushings
COMING SOON: N2MB toybox, DSP, scangauge & SOLID MM's.
m4ster_chef is offline   Reply With Quote
Old 11-04-2009, 03:05 PM   #4 (permalink)
bene's Avatar
Trader Rating: (40)
accelerating and WOT are 2 different things... he used both words so im assuming he knows what to use
accelerating at 14-15 is normal
Old 11-04-2009, 04:37 PM   #5 (permalink)
Ok... yeah.. that's true. Accelerating (meaning here 1/2-3/4 throttle) AFR's in the 14.Xs are ok, but he had been talking about his WOT AFR's so that's what I was going by. I understand what you're saying. I just took the SRT for a drive and to get some new plugs (had to go to 5 parts stores to find some 4306's) and I paid close attention to the AFR. I don't guess i ever paid much attention to the afr's when under partial throttle. I will be granny driving or WOT from now on. I can't believe that partial throttle won't hurt the motor.
Old 11-04-2009, 04:42 PM   #6 (permalink)
bene's Avatar
Trader Rating: (40)
^^ shouldve gone to napa first
whats "I can't believe that partial throttle won't hurt the motor." mean?
Old 11-04-2009, 05:54 PM   #7 (permalink)
Out of habit I will accelerate partial throttle. I don't wanna go WOT but I don't wanna putt putt around. I have done some searches and my findings have resulted in the following, partial throttle is not good for the engine.
Basically, I was saying that partial throttle isn't good. It was supposed to be read, "I don't think partial throttle is good for your engine." I just said it kinda funny.
Also, Napa is on the total other side of town. I found them at O Reilly's.
Old 11-04-2009, 05:56 PM   #8 (permalink)
Monster's Avatar
Member Number: 48761
Trader Rating: (68)
Part throttle boosting is okay as long as you aren't seeing any detonation. Usually as long as you keep it under 8-10psi depending on turbo size you will be okay.
www.pt-performance.com
Tunes send your request to tunes@pt-performance.com
Old 11-04-2009, 06:00 PM   #9 (permalink)
Yeah... But I don't have a scangauge yet so I'm playing it safe until I get one. And I have a S3 turbo, and I can't afford another one so I'm gonna stay safe until I get a scangauge.
Old 11-04-2009, 06:05 PM   #10 (permalink)
Monster's Avatar
Trader Rating: (68)
It isn't the turbo that is in danger during ptb its the ring landings from detonation. Just keep the boost low during ptb and you will be fine. Sometimes its unavoidable you gotta pass people right?
Old 11-04-2009, 06:12 PM   #11 (permalink)
Won't too much PTB cause compressor surge as well?
Old 11-04-2009, 06:25 PM   #12 (permalink)
Monster's Avatar
Trader Rating: (68)
Yes you are right I forgot about that. By the time it surges during ptb you should be boosting pretty hard. Well at least with a s3 turbo thats the case. Not that it has happened to me before or anything on complete accident
Old 11-04-2009, 06:27 PM   #13 (permalink)
bene's Avatar
Trader Rating: (40)
yes but this is only with the stock turbo... bigger turbos dont have that problem.
PTB is not bad itself, its how people treat there cars during PTB that makes it baad
Old 11-04-2009, 06:37 PM   #14 (permalink)
Monster's Avatar
Trader Rating: (68)
Yeah they do My 50trim used to do it.
Old 11-04-2009, 07:27 PM   #15 (permalink)
I thought that bigger turbo's were more likely to cause compressor surge because of the increased air flow. I thought that the stocker WOULDN'T do it as easily because it's harder for it to make more boost than the engine can use.
Page generated in 0.17210 seconds with 13 queries
