» Tire Upgrade Garage
Old 03-28-2008, 03:56 AM   #1 (permalink)
gq4life's Avatar
Member Number: 10297
Default tryin to fix all my cars problems
i just took my whole car apart.. so tired of problems.. going to fix everything..
i had turbo blowing oil.... re did pcv line and oil drain tube.. i think that fixed it not sure.. right after that started gettin tickin clankin noise so been takin it easy..
my coldside pipe was filled with oil.. and blowing oil on tranny.. guessing thats where it was comin from no oil anywhere else but bottom coldside pipe at throttle body and tranny area right nest to coldside pipe..
im going fix all i can now..
going to:
New seal at intermidate shaft
Hydraulic Throw Out Bearing
New Clutch ACT 6-puck w/ Lightweight flywheel from AGP Turbo
New Drain Tube ( a made a badass custom oil drain tube wrap in foil for heat protection by manifold and with SS braiding LoL but that one was just a temp)
gotta make new drain tube.. good rubber hose
AGP Tranny mount
Cut out balancing shaft.. might be whats making all that noise..
Puttin in Megan Coilovers
Yellow stuff brake pads w/ SuperBlue Brake fluid
DCR Head Oil flow mod
Pressure wash whole engine and engine bay..
oil and tranny fluid everywhere from leaks that arose
hope i can fix all my problems..
doing this out of garage got no money to hire someone..
prob something im forgetting..
i got pics too.. tried to email to myself but not showin up in my mailbox..
and i gotta go.. its 5am and i got to get up in 2 hrs for work..
2004 Dodge SRT-4
AGP 50trim (Great Turbo spools incredibly FAST!!)
PowerPaq, SRI w/ K&N Filter-RX-3990-1
MPx 3" TBE, CoolingMist TrunkMount W/A injection
Return line w/ 750 injectors, Lorenzo Fuel Rail
LC-1 Wideband
Dual Stage Boost controller:
Stage 1-AVC-R EBC; Stage 2-MBC set at 24psi
HP numbers coming soon
Old 03-28-2008, 07:57 AM   #2 (permalink)
Member Number: 58154
good luck with everything
slyguy15 is offline   Reply With Quote
Old 03-28-2008, 08:11 AM   #3 (permalink)
Flash_srt-4's Avatar
Member Number: 47084
going to:
AGP Tranny mount
I'm having the same problem with my coldside pipe let me know how you fixed yours.
Mods:
Custom 3" side exit exhaust
Cold Air intake
Stage 2 with toys
$20 catch can
Greddy TT
Solid motor mounts
Mopar STS
HKS blow off w/hard pipe
CCA FMIC
Flash_srt-4 is offline   Reply With Quote
Old 03-28-2008, 09:11 AM   #4 (permalink)
gq4life's Avatar
well at one point in time my turbo was spitting out oil.. especially at high boost..
i re ran pcv line and new oil drain tube but never got to check if it fixed it..
i got new catch can too when i did pcv lines to see if maybe my home made catch can wasnt catchin enough oil...
if i can figure out which i probably wont.. i'll just find out when i put it all back together if it still spitting out oil or not..
just been one thing after another with this car.. never had any problem with my red one(it was stolen)
this one is one thing after another.. suspension wore out, brakes wore out, wont go in gears like clutch doesnt disengage, makin a tinking clankin noise when cruising or deceling(gets loud after i drive for a lil bit), clutch feels like its going (got new one from agp already) , spark plugs takin a shit,
wish i just had money to send to mechanic and order a built block, head, and tranny and call it a day..
Is this StainlessSteel braided line good for oil draib tube?
Page generated in 0.16693 seconds with 11 queries
