Old 12-04-2008, 06:21 AM   #1 (permalink)
1B4dSRT's Avatar
Member Number: 43757
Trader Rating: (10)
Default Top speed question.
Well yesturday i filled up with race gas and had a great race with another srt i didnt notice but i was at 160 in no time but then the car started feeling like it was holding back or dying out.....is the stock pcm supposed to do this to the car or is something wrong? cuz the other srt just kept going...i guess its cuz of his aem ems.
1B4dSRT is offline   Reply With Quote
Old 12-04-2008, 06:29 AM   #2 (permalink)
fullofrage4u's Avatar
Member Number: 28533
Trader Rating: (18)
I thought it was ECU limited to 156 or something. I think I have seen people say that have gone a little over that but 160 sounds about right. Any system like the EMS or even the Diablo Pred. will allow you to adjust rev. limit and top speed though.
Hope you had some ZR's on
BRAVOPL POST ON HOW TO TEST FOR BOOST LEAKS:
"I'm sorry for an idiotic question. once i have this leak tester hooked up i start the car and then what? Do i just stand there and wait for some sort of whissle sound?"
SOLD
fullofrage4u is offline   Reply With Quote
Old 12-04-2008, 07:55 AM   #3 (permalink)
turboweasel24's Avatar
Member Number: 23118
Trader Rating: (15)
You will also run into the drag limitations around 170, which is were you need power and or aerodynamic mods at that point.
turboweasel24 is offline   Reply With Quote
Old 12-04-2008, 07:56 AM   #4 (permalink)
Member Number: 63342
the car has no mechanical or electrical limiters on it other than the rev limiter. the design of the car is what keeps the speed somewhat in check at 156mph due to drag(which means the car just won't go any faster unless more power is added), but that is in completely stock form. if you do anything, even something as small as just upping the boost on the stock turbo and that is it, you will be able to break that drag coefficient and bump it up according to what you have done to your car.
E1 turbo, PTP pnp e-mani, FM wga, 3" O2, 3" DP, 2.5 DP back exhaust, full 2.5" IC piping, Boomba BOV, AEM SRI, NGK plugs, MSD 8.5mm wires, AEM uego WB, Spearco DFFMIC, MM inserts, AGP tranny mount, ACT 6 puck, Maddog 80% sts;
best dyno 307whp/301wtq @ 19psi
13.676 @ 106 on 20spike, 16-17 redline.stocker
13.45 @ 103 ~18psi spike, 16 hold. pcm boost/stock WG
E1 at ~16 spike/hold psi 13.3 @ 105 w/pcm boost(can't launch/no driver mod ftl)
1fast4 is offline   Reply With Quote
Old 12-04-2008, 03:39 PM   #5 (permalink)
1B4dSRT's Avatar
Trader Rating: (10)
well im not stock, agp 3147 360hp lol...ecu problem right?
Old 12-04-2008, 03:47 PM   #6 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Never tried a stock pcm, but my stg2 car was electronically limited to 155mph. Pcm controlled everything, as soon as it hit 155, it dropped the boost to 7-8psi, like clock work.
Stg2 toys topspeed test. Yeah I have a helmet, I'- Video
Good news is my stg3 pcm is not electronically limited. 170mph is obtainable.
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 12-04-2008, 03:59 PM   #7 (permalink)
1B4dSRT's Avatar
Trader Rating: (10)
damn...lol u passed those cars like they were parked.
Old 12-04-2008, 04:04 PM   #8 (permalink)
Yeah, I've gone faster thou.........................
Mods are on the vid. 6400rpms in 5th. I said 165- Video
Old 12-04-2008, 04:12 PM   #9 (permalink)
this is why I said 165, because that's where the speedo stops...........Dodge Neon SRT4 Stage 3 top end pull- Video
1st stg3 attempt was this /\
Old 12-04-2008, 04:18 PM   #10 (permalink)
Super Moderator
STUDLEE's Avatar
Member Number: 54852
Hope you guys are careful. I won't say I haven't done it but all it takes is something as small as a broken exhaust hanger from another car to break your stability.
"In about three years, holla at me Miley Cirus!"
STUDLEE is offline   Reply With Quote
Old 12-04-2008, 04:20 PM   #11 (permalink)
ferguson's Avatar
Member Number: 50763
Trader Rating: (13)
why is that song on the last video
SOLD 04' Strawberry Skittle:jmb built motor, pwerks s2 trans,
dsp tuned, bolt-on's, stock turbo & pcm, pump only 295/330
ferguson is offline   Reply With Quote
Old 12-04-2008, 07:31 PM   #12 (permalink)
Smile
Because it's quality!!! Sole Glow FTW!!! Can U tell what city is in the background?
