stumbles bad, won't rev past 2500 rpm - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 05-01-2007, 08:03 PM   #1 (permalink)
Member Number: 51599
Default stumbles bad, won't rev past 2500 rpm
Hi Everyone. I just got done swapping an '04 SRT-4 motor into my '04 SXT. Basically the entire engine/tranny assembly including k-member, suspension, wiring harnesses, etc. I started it up for the first time today and it started on the first crank and idled perfectly.
But when I press on the gas, it will rev to about 2300 - 2500 rpm and start missing really bad and won't rev any higher than that. Let off on the gas and it goes back to a perfect idle. The best way to describe it is almost like bouncing off a rev limiter, but at 2500 rpm.
I've checked for leaks and everything looks tight. Anybody know what may be the problem?
Everything is stock except for a Stage 1 PCM.
rgsales2k is offline   Reply With Quote
Old 05-01-2007, 08:09 PM   #2 (permalink)
endlessheart666's Avatar
Member Number: 36526
Possibly coil or wires?
97 Miata Turbo
endlessheart666 is offline   Reply With Quote
Old 05-01-2007, 08:11 PM   #3 (permalink)
SRTchild's Avatar
Member Number: 32169
hmm, might be the camshaft sensor?
i know something like that happened to Korterhorse_210. and it sounds like the same problem that he had on his car.
Aem CAI, Agp WGA, Stage 1, Ndswngs V6, MPx BFIMC, Aeroforce Scangauge, AEM EUGO, MPx Dual Gauge Pods, Yellow Foglight Bulbs, Laminx, Bdjs Shorty Antenna, Eibach Pro Kit, Prothane Endlinks, ESMM, 20% Tint, PTP Coil HS, Taylor Wires, NGK 4306s, $20 Catch Can, Mopar Front Badge, SRT-4 V2 Badge, PTP Check Valve, ED Blitzz TT, TurboSmart MBC, Rota Slipstreams, Bridgestone Potenza RE-01 R's
SRTchild is offline   Reply With Quote
Old 05-01-2007, 08:12 PM   #4 (permalink)
Member Number: 4648
coil is bad
reed32 is offline   Reply With Quote
Old 05-02-2007, 04:46 PM   #5 (permalink)
Ok well I just replaced the coil and plugs and no change. I'll pick up a new set of wires and try that tomorrow.
Any other suggestions what it might be?
Old 05-02-2007, 05:00 PM   #6 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
check map sensor?
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 05-02-2007, 05:04 PM   #7 (permalink)
Member Number: 37525
reset ecu,
my fuel pump had recently gone out, and i had that problem, its like itting a brick wall
dgillie is offline   Reply With Quote
Old 05-02-2007, 05:09 PM   #8 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
Is there a check engine light on? Have you checked for CEL codes at all? Sounds like when I had a bad cam sensor.
'04 Dodge Neon SRT-4 Solar Yellow: 11.24@129.7 MPH (Stock block - R.I.P.)
'05 Dodge Ram 2500 QCSB Cummins Flame Red on 33's & 20" wheels: 12.27@111.7 MPH (Daily Driver)
chuck's_srt-4 is online now   Reply With Quote
Old 05-02-2007, 06:13 PM   #9 (permalink)
MoxhairR/T's Avatar
Member Number: 17662
Sounds like Limp Mode.
Mine went into Limp Mode when my Coolant line leading to the Turbo Leaked all over the Cam Position Sensor. p0340
Check your codes if possible.
Travis
2013 Mitsubishi Lancer Evolution X GSR
2011 Subaru Impreza WRX (SOLD)
2008 Mitsubishi Lancer Evolution X GSR (SOLD)
2008 Mazdaspeed3 (SOLD)
2004 Dodge Neon SRT-4 S3R (SOLD)
MoxhairR/T is offline   Reply With Quote
Old 05-02-2007, 06:36 PM   #10 (permalink)
Found the problem. It was giving code p0123 (TPS wiring) and sure enough the black wire at the TPS harness was broken inside the insulation so I couldn't see it without feeling it with my fingernail. As soon as I touched the wire back together I could hear the motor smooth out a little and then gave it some gas and it revved like a champ. Thanks for all the seggestions.
Old 07-11-2007, 01:30 AM   #11 (permalink)
all4srt's Avatar
Member Number: 28435
My cars are doing the exact same thing. I turn the key on-off-on-off-on and I get the p0340 error code. I hooked an OBDII scanner to it, same thing, but with the description "Camshaft Position Sensor". I couldn't go beyond around 2200 RPM in any gear. Then my other SRT-4 began doing the same thing the same week. The MIL has turned itself off, so not sure if it was just a temporary bug or it just decided to correct itself. Regardless, it's going in the shop for further investigation. Don't want to lose out on the warranty.
Stg 2 w/ toys, Stg 2 clutch
Mopar bov, MSD ignition
Mopar 3" Intake
all4srt is offline   Reply With Quote
Old 07-11-2007, 03:05 AM   #12 (permalink)
neonXonXsteroids's Avatar
Member Number: 52222
Thats weird cause my TPS has been broken for a long time now. Just haven't gotten around to fixing it. The wire is totally broken and just laying in 2 pieces, and it still drives and revs good. It's a little jumpy, but it revs just fine.
neonXonXsteroids is offline   Reply With Quote
Old 08-08-2007, 07:12 AM   #13 (permalink)
Stealth's Avatar
Member Number: 742
Any news on this? I've got the same thing
Stealth is offline   Reply With Quote
Old 09-09-2007, 05:36 PM   #14 (permalink)
mooseman0's Avatar
Member Number: 45861
I have same problem too i shut car off going down road wait a lil and its good for a lil then bang gatta shut off again haha these cars piss me off......
10.29@137 parted out
03 Cobra 2.9 whipple in the works ;D
mooseman0 is offline   Reply With Quote
