Old 07-11-2008, 05:20 PM   #31 (permalink)
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (129)
Quote: Originally Posted by 1fast4 View Post
where in this entire thread does it say that he has a piggyback. he started his first post off talking about his plug gaps. don't be a jackass when i am just going off of what i have been given to work with, which was nothing, so i can assume that he doesn't have one. now if he were to give a list of his mods and then explain his situation, that would be a different story. not trying to start an ewar or anything just explaining why i responded the way i did.
it says it right here:
Quote: Originally Posted by DannySRT405 View Post
I jus got in from doin some datalogging and street tuning, and this is what I came up with.
Datalogg software- Zeitronix ZT2
Fuel Controller- SAFC2
RPMS - AFR - % pulled
4000 - 11.0 - 9%
4400 - 11.0 - 11%
4800 - 10.7 - 10%
5200 - 11.3 - 6%
5600 - 11.7 - 0%
5601+ - xxx - xxx
These are the starting RPMS when I hit full boost (20 psi). at 5601 and above is when the car cuts out.
I'm completely convinced my problem is a spark issue, whether its wires or a coil pack. My afr's arent too bad, and I would have finished leaning it out where I need to be but downpour FTL. Before the car cuts out she pulls really really hard too. Anybody have any input?
read the entire thread before making a suggestion ...
also, don't ever recommend using a map clamp with a big turbo & aftermarket injectors
Old 07-11-2008, 05:24 PM   #32 (permalink)
uncommon©'s Avatar
the only thing I agree with you on is the fact that he needs to clamp his map voltage ... it's the method that you're suggesting that I don't understand
just reading over all of this again, it's very obvious that the problem is the fact that he's pulling 0% at 5600 rpms ... the fact that the car breaks up & stumbles at 5601 is not just a co-incidence ... he needs to pull at least 3 or 4% then the car will stop stumbling
Page generated in 0.17764 seconds with 11 queries
