» Tire Upgrade Garage
Old 05-11-2008, 10:34 PM   #1 (permalink)
Member Number: 45523
Default STAGE 3 Install ? ? ? ?
Hey guy well i finally got my Stage 3 kit last week and am really excited to get it on. I need some help, i remember seeing a thread on here about the stage 3 install and discussed helpful hints and stuff like that. Only prob is i don't remember the name of the thread, i have tried searching but have not came across it. Do any of you remember this thread or the title of it? Im sure someone knows and i appreciate the help
Old 05-11-2008, 10:47 PM   #2 (permalink)
Member Number: 8546
its not hard at all to install the shit is pretty straight forward hes some things i can remember off the top of my head.
When you order be sure to:
1)get the maxfab 3inch o2 housing for the stage 3 but make sure it isnt on backorder
2)get a big frontmount intercoole rlike agp or MPX make sure they arent on backorder
3) get a agp catchcan
4)make sure you get a 3inch turboback like from MPX with no cat and no resonator i like that stock look
5)dont touch the wastegate its perfectly calibrated the way mopar left it .
6) you may need a clutch later on if you decide to beat on the car like a madman
7) if you dont have agp motormounts get em now all of the the tranny the motor up and lower mount
8)when you take the headshiled off dont disguard it well the upper one anyways dont throw that out youll need it to prevent your coolant resevoir from melting
9) when you take the return oil like out youll need a long extension drive to reach it through the bottom.
10)make sure when you attempt to take the turbo and manifold out take out the battery first so that theres more room with the back end of the turbo coming out first after yo upull it away from the block and make sure nothing is snagged and or connected.
11) after you take out your coolant and oil lines after putting everything back together make sure its primed and that there are no leaks.
turbo installation is reverse of removal also CRITICAL!!!! MAKE SURE YOU MEASURE THE OIL RETURN LINE YOU WILL HAVE TO MEASURE TWICE AND CUT ONCE AND CUT IT EVEN BECAUSE IF NOT IT WONT GO ON CORRECTLY AND IT WILL LEAK!
12) then for the testdrive but before yo do that make sure you get t-bolt clamps and ziptie yor vacuum lines so that there are no boostleaks and reset your computer.
13) then after you get everything right have fun gettin traction unless you have drag radials
14) holding high octane mode is good only if you have meth injection
15) axles be prepared for the ride of your life.
16) evos and sti's wont know what hit em
Stage 3 with turbo toys,maxxfab 3inch o2housing,mpx3inch exhaust,no cat,mopar shortshifter w/booger bushings,mopar cai,agp motormounts,agp bfmic,coolingmist varicool hom stage3 hold it down kit.
srt-sparkle is online now   Reply With Quote
Old 05-11-2008, 11:39 PM   #3 (permalink)
Toofpaste39's Avatar
Member Number: 17599
Trader Rating: (20)
Search for my username on topics started. You're welcome & dont forget to post up on the thread if you have any questions, comments.
Toofpaste39 is online now   Reply With Quote
Old 05-12-2008, 05:35 AM   #4 (permalink)
master_1011's Avatar
Member Number: 3396
I'll make it easy for you...
Stage III Install Compilation
First SRT-4 sold on Guam
master_1011 is online now   Reply With Quote
Old 05-12-2008, 10:29 PM   #5 (permalink)
srt-sparkle - Thanks for the write up !
Toofpaste - Thats exactly what i was looking for !
master1011 - Thanks for making it idiot proof !
Old 05-12-2008, 10:31 PM   #6 (permalink)
can any of you guys give me an answer to this now? ? ? ? ?
S3 Rail pressure gauge ???
Old 05-12-2008, 11:26 PM   #7 (permalink)
Member Number: 8546
hmm dont know too much about that also in the end after you get everything perfectly in runnin order in tiptop shape be sure to get or borrow a codescrubber from off the n2mb website.
As it is essential to passing emmissions which is a pita. Im going through shit right now as we speak i just recently failed the emmissions test and got those bull shit codes so yeah definitely a codescrubber is in order for future reference.
Emissions Issues! - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 05-13-2008, 08:07 AM   #8 (permalink)
akmrue's Avatar
Member Number: 46876
^^ That sucks!
PERFORMANCE
AEM SRI/MSD 8.5mm Wires/3'' Needswings DP/MPx 3'' o2/Maddog STS/180 T-Stat/MPx FMIC/PTP WGA 17/15/PTP Check Valve/Street MM Inserts/Greddy Type-S/NGK 4306's .35 Gap/AEM WB/Map Clamp
DYNO 9/1/07:
248whp & 289wtq (15psi) MUSTANG DYNO
akmrue is offline   Reply With Quote
Old 05-13-2008, 11:10 AM   #9 (permalink)
Buy/Sell section Moderator
dojaman666's Avatar
Member Number: 3804
Trader Rating: (25)
i have the dodge how too for the service techs if you need it.
All items for sale will use the following format:
Name:
Contact:
Price:
Description:
If you have any questions please see here:
http://www.srtforums.com/forums/f27/...elines-352468/
Comming when i have time...
www.downsouthdomestics.net/forums
dojaman666 is online now   Reply With Quote
Old 05-13-2008, 01:43 PM   #10 (permalink)
Yep i already looked into that before i bought the S3 and i have a code scrubber sitting next to me as im typing. So now the only thing i have to change when i go to emissions is my downpipe
Old 05-13-2008, 05:03 PM   #11 (permalink)
svtsrt's Avatar
Member Number: 41942
You'll have fun putting it on. You might learn some new curse words too!
Just take your time. Having a friend helps but I did mines all by myself.
05 SRT-4
-Mopar stg3, Mopar BOV, sts, exhaust, CTI hotside pipe, JBM cc, Maxxfab dp w/ cat, AEM uego wideband, Aeroforce gauge-
to be installed...Mewth?!?
svtsrt is offline   Reply With Quote
Old 05-13-2008, 07:01 PM   #12 (permalink)
haha i already learned many cuss words when installing a 3" O2 house on the stock turbo! I plan on doing the install myself over the summer, so ill take my time with it.
SVTSRT - Im wondering what kinda power you are making with your setup and what kinda 1/4 miles times have u had?
Old 05-13-2008, 07:08 PM   #13 (permalink)
dojaman666's Avatar
Member Number: 3804
Trader Rating: (25)
pm me for the dodge stage 3 install pDF from mopar. Give me an email address.
File Type: pdf 2003-2004 SRT-4 Stage 3R Turbo I Sheet.pdf (511.6 KB, 9 views)
Old 05-13-2008, 07:48 PM   #14 (permalink)
svtsrt's Avatar
Don't know hp-wise but I was hitting 15.4 at the track. This was with a shitty tune. 6 KR, 9 degress timing and 14 psi of boost in 3rd is just a couple of problems I was having with my tune.
I got the stg3 pcm and the car runs like a raped ape. I will know 1/4 mile times once I get back to Jersey.
The car is a whole different animal now that I have everything stg3.
You won't be disappointed with it.
Old 05-13-2008, 08:26 PM   #15 (permalink)
Member Number: 63759
Only 15.4? I thought these cars stock run low 14's
